Author Topic: Post your travel board  (Read 3155 times)
Offline _rubik
« on: Thu, 16 September 2021, 19:42:32 »
I'm curious. Do you folks take a keyboard with when you have to work + travel?
If I need to work from another office or travel to a conference, I usually bring my HHKB Pro JP. It's pretty light, the plastic is durable/flexible enough, and I still enjoy typing on it.
Offline livewirerc
Re: Post your travel board
« Reply #1 on: Sat, 02 October 2021, 00:16:00 »
Not too dissimilar here. US layout HHKB Hybrid Type-S with swapped caps, domes (pink Deskeys BKE), lubed stabilizers and sliders. I needed the bluetooth.
Prior to this I used an HHKB BT with 55gm realforce domes and type-s sliders swapped in, but the ability to pair to multiple devices and re-program with their software won me over to the Hybrid.
« Last Edit: Sat, 02 October 2021, 00:18:18 by livewirerc »
Offline _rubik
« Reply #2 on: Sat, 02 October 2021, 00:26:23 »
Are those dyed Biip 2048 caps? Did you do the dye yourself?
Offline livewirerc
« Reply #3 on: Sat, 02 October 2021, 21:52:11 »
No, they're the "stealth" ones, which are grayer than the stock charcoal on black keycaps.
https://kbdfans.com/collections/electrostatic-capacitive-keycaps/products/kbdfans-x-biip-extended-2048-black-keycaps-set
Offline kajahtaa
« Reply #4 on: Sun, 03 October 2021, 09:40:57 »
traveling with board
Offline Kaisung_24
« Reply #5 on: Sun, 03 October 2021, 11:38:28 »
Just got this board but will be my travel board when needed.
