Author Topic: What's in your "PC repair" toolkit?  (Read 24091 times)
Offline Konrad
« on: Wed, 01 September 2010, 10:11:27 »
Once it becomes known that you possess mastery over the arcane lore of building and fixing PCs, everybody in town suddenly starts to invite you over because their crappy-slow PC needs attention.
What tools do ye bring along?
Myself, I never (well, hardly ever) am caught without my (modified) Leatherman multitool and a good MagLite.  On some days, when I expect to encounter hordes of dying PCs, I end up decking out what feels like a Bat-Belt full of toolage.
Offline vils
« Reply #1 on: Wed, 01 September 2010, 12:14:18 »
Quote from: kishy;218828
On a good day:
  • Bit driver with 4 bits: 3 sizes of philips and one slot
  • Small clip-mounted flashlight
  • Dental-like mirror (larger though)
  • Software kit (small CD/DVD binder) including all major OS disks, OEM restore versions, UBCD, DOS boot floppy just for kicks)
  • External hard drive
  • Where feasible, my laptop
  • Only when above has been brought, also a flash drive (save the external HDD all the spin ups and spin downs just to get files from one machine to another)
Although I've had to use ripster's trick a few times with specific people.
and compressed air on can.
It\'s the glass pipe fallacy. You can only believe that if you\'re on crack.
Offline didjamatic
« Reply #2 on: Wed, 01 September 2010, 12:22:32 »
In pocket:
Leatherman Squirt S4.  There is very little that cannot be fixed with it.  I have carried one in my pocket for nearly 10 years and it has made carrying many other things unnecessary.  If I could only have 1 tool, this will always be it.
USB flash Drive.
Iphone.
In car:
Blank DVDs/CDs
Crimpers
Cat6 or 53 Cable
Screwdriver
Misc zip ties, cables and connectors
« Last Edit: Wed, 01 September 2010, 12:26:18 by didjamatic »
Offline ch_123
« Reply #3 on: Wed, 01 September 2010, 12:23:02 »
Bible, Jack Daniels, and a Colt 45.
Offline Phaedrus2129
« Reply #4 on: Wed, 01 September 2010, 12:26:01 »
#1 and #2 phillips head screwdrivers
Small and large flathead screwdrivers
Needlenose pliers
Compressed air can
91% isopropanol
Q-tips
CDs for GParted Live, Memtest86+, Ubuntu 10.04
Flash drive with CoreTemp, RealTemp, Prime95, GPU-Z, CPU-Z, etc.
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline Konrad
« Reply #5 on: Wed, 01 September 2010, 12:51:52 »
Quote from: kishy
... DOS boot floppy just for kicks
The legendary 3½" MSDOS 6.22 disk ... I stopped lugging that sucker around somewhen around the 10th anniversary of never using it.
Quote from: kishy
Ripster's solution is elegant and magnificent.  I've already added it to my toolkit.  Although a Colt .45 seems like a useful tool too.
Offline Konrad
« Reply #6 on: Wed, 01 September 2010, 13:51:11 »
Quote from: ripster
At OCN you lose 100 rep points for admitting you've called "The Geek Squad".
Yeah, in real life you lose 100 dollar points. So some twit gamer can rape your machine.
See How He Uses A Spanner!
I'd give you Rep, Rip.  But I don't have any so - as Welly would say - pooh-pooh to you.
« Last Edit: Wed, 01 September 2010, 14:12:11 by Konrad »
Offline Konrad
« Reply #7 on: Wed, 01 September 2010, 14:22:49 »
Konrad's Computer Chemicals ...
  • Anhydrous isopropyl (never go near that awful perfumed drugstore crap, it breaks electronics)
  • 1,1,1-Trichloroethane - er sorry, Limonene
  • Adhesives: Krazy Glue (cyanoacrylate) and "kicker", Epoxy, resin, potting compound
  • Lubricants: WD-40, Teflon, precision oil
  • Conformal sealant
  • Midel-7131 (liquid immersion only!)
  • Stabilant-22
« Last Edit: Wed, 01 September 2010, 14:26:02 by Konrad »
Offline chimera15
« Reply #8 on: Wed, 01 September 2010, 14:29:14 »
One great tip I learned from watching custom pc builders and case modifiers on youtube is to get a bunch of zip ties and zip tie double stick mounts.  It really helps to leave a clean wirefree case for both heat and a professional look.  It's really a great mark of professionalism to leave a good looking orderly interior on desktop units.
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline chimera15
« Reply #9 on: Wed, 01 September 2010, 14:38:27 »
Quote from: vils;218861
At the pc repair place I worked at we had a compressor just for blowing out dust ridden units.  Some of the insides of the computers I worked on there looked more like the lint filter in a dryer than computers.  The smokers machines were the worst, and the smell was horrific.
Alps boards:
Offline Konrad
« Reply #10 on: Wed, 01 September 2010, 14:45:59 »
I found smoking doesn't contribute much to lint and debris.  But it does leave that awful, stinky, sticky, toxic yellow residue on everything.  After enough smoking for a long enough time it stains plastics, coats electronics (makes a wonderful thermal insulator to keep them toasty warm), actually contaminates exposed semiconductors (changing their values), and seizes moving parts.
What I found particularly offensive for causing debris is pets.  We'd actually use a shopvac fitted with soft brushes and the blown air from the airtool compressor (probably an ESD risk, I guess).
Offline williamjoseph
« Reply #11 on: Wed, 01 September 2010, 15:37:35 »
why its better to know nothing about computers...... see link.
http://theoatmeal.com/comics/computers
Offline chimera15
« Reply #12 on: Wed, 01 September 2010, 15:40:16 »
Quote from: Konrad;218915
yup
Alps boards:
« Reply #13 on: Wed, 01 September 2010, 18:32:19 »
Quote from: ripster;218827
My biggest tool is lying.  If they ask if know anything about PCs I tell them "no".
That. And a swappable philips/straight (large) screwdriver. Anything that can't be fixed with that is worth paying me for.
Current collection: HHKB Pro 2 black on black, HHKB Pro 2 white/grey blank, [strike]Dell AT101W[/strike] (sold to SirClickAlot), 1992 Model M, Key Tronic Ergoforce KT 2001, BTC 5100 C. Dead boards: MS Natural Elite, MS Natural 4000.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #14 on: Wed, 01 September 2010, 19:20:26 »
My computer repair tool kit: Half a basement full of computer stuff. Got just about everything down there.
Offline Konrad
« Reply #15 on: Wed, 01 September 2010, 22:34:06 »
What do you use the other half of the basement for, mw?
Quote from: didjamatic
I've often wondered exactly what half of my Leatherman gizmos are called or are designed to do.  The Really Useful Pointy Thing is, uh, really useful ... and pointy.
« Last Edit: Wed, 01 September 2010, 22:39:18 by Konrad »
Offline ricercar
  • mostly abides
« Reply #16 on: Thu, 02 September 2010, 02:02:38 »
thumbscrews and zip ties.
Offline firestorm
« Reply #17 on: Thu, 02 September 2010, 08:07:15 »
Repairing PCs was my career for a while, but now it is a very small part of it.
The most commonly used tools used here at work:
- #2 Phillips
- Canned Air
- ESD free Vacuum
- Files and Settings Transfer Wizard
- Ghost or Windows disc
- Wire cutters and zip ties
- Tube of precision oil for fans
- Malicious software recovery (e.g. Malwarebytes, Combofix, or whatever is the latest and greatest.)
- Hiren's Boot Disk (aka. HBoot) on USB for diag and utils
- Windows PE on USB for diag and utils
I personally have a toolkit that has 11 Craftsman Pro precision screwdrivers of various types and sizes.  I serviced Compaq desktops and notebooks for a while, so those include torx drivers (#8, #9, #10, #15).
FWIW, I've had compressed air from an air compressor kill the PSU in the same machine twice (years apart.)  This is in another building of ours where we don't always have canned air available, and this compressed air is routinely and exclusively used to blow out electronics.  Although the system already exhibited signs of being unstable on both occasions, it appears that the compressed air was damaging enough that I would be leery of using it again.  I had hoped the first PSU was simply on its way out anyway, but I was extremely careful the second time and it still failed.  If I did it again, I'd be sure to ground the case, if nothing else by at least leaving it plugged into power.
Offline instantkamera
« Reply #18 on: Thu, 02 September 2010, 09:12:02 »
Nothing, because I try really hard not to repair PCs. I spent the better part of my youth building and repairing PCs, and now I wont waste my time.
I understand how hard it is to do this job RIGHT, and serious kudos to the guys who still stick with it, but like a lot of things, the market is flooded with Joe Blow PC repair guys. When your competition consists of large retail chains with incompetent employees, it's time to find a new line of work.
Realforce 86UB - Razer Blackwidow - Dell AT101W - IBM model MCST  LtracX - Kensington Orbit - Logitech Trackman wheel opticalAMD PhenomII x6 - 16GB RAM - SSD - RAIDDell U2211H - Spyder3 - Eye One Display 2
Offline EverythingIBM
« Reply #19 on: Fri, 03 September 2010, 02:23:51 »
Quote from: firestorm;219128
I use compressed air in all of my computers -- and even in the PSUs. I never had any issues once.
That was just a crappy computer then, let me guess; Dell, HP, e-Machines, acer, gateway? It has to be one of those.
Offline Konrad
« Reply #20 on: Fri, 03 September 2010, 03:13:51 »
(you forgot to mention Compaq)
« Reply #21 on: Fri, 03 September 2010, 03:29:59 »
Quote from: Konrad;219450
Compaq is HP now though.
Quote from: ripster;219453
I think it must have been an IBM.  God those things were overpriced and crappy.  No wonder they left the biz.
I find IBMs to be really reliable. None of mine have broke and are still working years later. Nice American computers... like American-built Fords, instead of those cheap "Honda" vehicles that some people buy.
The only computer that failed on me was my lenovo T60p due to the GPU overheating and killing the system board; to be honest I thought it was tougher than that. Not many computers had pure copper heatsinks (bad sign right there, usually manufacturers just make cheap aluminum things: but in this case they HAD to resort to copper)... even the T61s had a lighter aluminum/copper mix (yellow in colour) as they could get away with something cheaper due to the absence of the FIRE GL.
Offline Konrad
« Reply #22 on: Fri, 03 September 2010, 03:58:31 »
I'm almost ashamed to admit it, but I still have a few IBM mobos. Just the mobos, combined with real parts, not the rest of the IBM ****. Only because these beasts use TPM hardware and Phoenix BIOS versions that offer bulletproof paranoid overkill security, passwords, and authorization. What for? Not because I'm particularly paranoid, though it's nice to have the option. But they're incredibly useful for stripping access passwords off other pieces of hardware from other machines; they can meet or exceed any security level present in any BIOS. They use entire tiers of security that most consumer PCs don't bother to incorporate, following cryptic official security paradigms and standards (which IBM itself has largely created). For example, it's amazing how a single mobo jumper can wipe hardware passwords off many HDDs, or how the BIOS can change DVD RPC as a "vendor" even after the "user" has made the maximum 5 changes, or how many pieces of problematic hardware respond to otherwise inaccessible "firmware reset" commands. I don't know with certainty, but they say that even the onboard firmware itself is also encrypted to prevent unauthorized forensic extraction of passwords. Can't beat that.
All these excessive security controls, user level this, administrator level that ... I've been able to get as many as 11 passwords (some prompted, some invisible) between power-on and Windows logon, heehee ... it seems to me this is an extension of IBM's obsolete unworkable "one big brain supercomputer attached to lots of dumb terminals" mentality in the real distributed computing world where people (well, at least some people) are not the retarded blundering incompetents that IBM execs believe. Their corporate model is all about controls, glacial bureaucracy, hierarchies, established procedures, following the rules. Maybe this concept worked in the 1960's but in the modern world things have changed while IBM hasn't kept up. They were a technological world leader yesterday but today they're just an overbloated patent troll which sells vague things like "consulting" and "infrastructure". The only hardware they have left to sell is all made by their competitors.
The real problem with these IBM mobos is that the manuals (the real manuals that contain actually useful technical data instead of stupid setup posters, instructions about how to install a stick of RAM, and childish warnings) are bloody impossible to find. Tech support is unhelpful and occassionally hostile (after all, only an IBM certified tech could possibly do the ridiculous things I expect are possible; it's both astonishing and inconceivable that I'd want to use an IBM mobo in a homemade non-IBM computer, and if the all-knowing IBM documentation doesn't properly explain things then it certainly cannot be done). Mobos are made by Intel but to IBM specs, same features as generic Intel boards using the same chipset, but all the connector headers are screwy custom arrangements. Normally compatible RAM and processors don't always work because IBM hasn't seen fit to include parameters for the parts in the authorized hardware database within the BIOS. Overclocking is utterly impossible, plain and simple. There are still minor issues: for example, I haven't got a clue how to attach front panel USB ports and digital audio into the unmarked undocumented unstandard 2x10-pin headers.
Other than that ... IBM PCs suck. They're vastly overpriced. Some parts (like the mobo) are IBM badged, built to IBM OEM spec. Other parts are IBM rebadged; sometimes they just obscure the markings with their own IBM part number sticker, sometimes they construct tamperproof subassemblies which do the same, sometimes they actually attempt to remove the ODM markings. IBM part numbers, PNUs, FRUs, ORUs ... big bureaucratic beehive busyness that doesn't accomplish **** except protect their jobs earning money as a parasitic middleman. Whenever the hardware isn't sufficiently dependent on the IBM mothership, they make sure that the software, OS, and the drivers all are - they probably pay a small army of people to rewrite the rewrites of all the IBM notations they use to obscure the real parts. It's near impossible to obtain drivers and firmware through IBM (unless you subscribe to their business model and get what they want to give to their tiers of techs to trickle down to you, all at great cost) ... at least until you identify all the re-badged parts and go right to the proper OEM sites. I'd never recommend IBM systems for anybody, anywhere, in any business. Except maybe the NSA, CIA, or some other kind of spies and secret police.
« Last Edit: Fri, 03 September 2010, 05:18:33 by Konrad »
Offline keyboardlover
« Reply #23 on: Fri, 03 September 2010, 10:39:58 »
Quote from: ripster;219536
Honda.  I only pick the best.
Like my keyboards. The difference is I don't get all anal about it and stick to only one manufacturer.  That's kinda weird.
Funny that it shows Toyota's reliability as so high...
Offline Konrad
« Reply #24 on: Fri, 03 September 2010, 10:43:21 »
So how many Yugos or Gremlins do you type on, rip?
Funny, it shows Volkswagon is better than Mercedes.
Offline itlnstln
« Reply #25 on: Fri, 03 September 2010, 11:20:56 »
Quote from: keyboardlover;219553
Research from the National Highway Whatever-it's-called found that "problems" like the "sticky accelerator" were user errors.  You sure don't hear about that like you did with the up-roar when "it" was happening.
Offline firestorm
« Reply #26 on: Fri, 03 September 2010, 11:36:58 »
Quote from: EverythingIBM;219436
It was actually an HP Workstation and I wouldn't classify it as "crappy".  Business class Dell, HP or Compaq have always been decent.  I'll agree that Gateway and e-Machines are junk, and Acer to a slightly lesser extent.  This appeared to be a well built machine; the PSU had a nice hefty weight.  I would attribute its double demise to the harsh environment, being in a room just off our bus maintenance facility.  Since we're understaffed, it never got cleaned out, and it was actually a farebox tech that cleaned it the first time.  After a few years, the PSU would get clogged full of diesel soot, dirt, etc...
I should clarify... the compressed air used was shop air with fairly high pressure, with no regulator.  They use it to clean out fareboxes and other similar electronics, but not computers.  I don't know if they have an in-line dryer or not, 'though I doubt moisture in the air was an issue.  As to not contaminate this room any more than necessary, I took it out in the hallway, thus the machine was not grounded.  I suspect the air flow was either too forceful or possibly generated static electricity, especially with the fuzz and dust in the machine.
« Reply #27 on: Fri, 03 September 2010, 19:20:45 »
Quote from: firestorm;219573
Many business-class Dell's were junky. Faulty motherboards, burning laptops (Those Inspirons were geared probably more towards the home market). Hewlett-Packard's are good though.
You're right in saying that Gateway is junk. But remember, the Gateway computer of today is just some plastic box from China. NOT the Gateway2000 of yesteryear. My Gateway2000's 14 years old with all stock parts and still works great. Now, if you'd taken a Dell Optiplex GX270, it'd only last a year or two before the motherboard failed.
« Reply #28 on: Fri, 03 September 2010, 21:33:21 »
It looks like Porsche is the best ;)
Oh and I don't believe Honda is better than BMW. That is pure BS.
My step mom's honda was made so poorly that the cheap electronics started making the vehicle beep in the middle of the night. Honda didn't know what to do about it and basically said "tough luck sucker".
Quote from: Konrad;219459
I've had no issues with getting drivers. IBM still has BIOS updates for 1996 PC 300 computers. A lot of the drivers are automatically installed by windows so you don't even need to install the drivers at most times (although I do for better performance).
Overpriced? Wait until you can snag one used. Don't like used stuff? The only two desktops I ever bought brand new were the only two that failed on me... (HP & custom built). There's nothing wrong with used computers once you know how to clean & upgrade them up.
I'm not into overclocking computers. If you're that desperate, just get a faster processor. I don't like the idea of reducing lifespan of electronic components.
Offline wellington1869
« Reply #29 on: Fri, 03 September 2010, 21:57:21 »
Quote from: EverythingIBM;219720
lol
i had a honda for 18 years and the damn thing would not die. I finally killed it tho and its ghost haunts me now because i killed it before its time (no not an accident, i'm a great driver ;) just neglect)
that said, i wont ever buy a honda again.  you know why? it was like driving a four-wheel scooter. Its engine was basically a motorcycle engine. Have to rev up to 6k to get any pulling power out of it.  Actually that honda has forever biased me towards high-torque engines, i'm even considering a diesel because i want torque so badly after that honda experience.
and that said, it was a blast to drive. But i'll still choose torque over everything else in my next car.
using: ms 7000/Das 3
« Reply #30 on: Fri, 03 September 2010, 22:01:20 »
In fact here she is on the way to the morgue.
she was pretty and fun and tiny. I do miss her sometimes. But for my next one I want a big fat german one with wide birthing hips.  ;)
« Reply #31 on: Fri, 03 September 2010, 22:09:13 »
I might just be getting old, but i kind of like the way the upcoming chevy cruze looks.
supposedly they're considering a diesel version, hoping to compete with the ford focus and golf.
« Reply #32 on: Fri, 03 September 2010, 22:11:24 »
Quote from: kishy;219730
Argh, my friend's first car was that generation of Civic. As base model as could be, with a manual transmission and bad clutch.
yup, this was my first car out of college :) Didnt have the heart to trade it in.
Despite the bad clutch, he managed to drive it without much of a problem. Seriously sucky engine though.
:) Tell me about it.  Tho I did get quite adept with the four-speed (yea -- four! The last four speed sold in america) in wringing everything possible out of it.  With no passengers, luggage, or hills, it could be peppy around town. :)
The real trick is to redline it in second and shift directly into fourth.  That third gear was one seriously tall gear.
Funny thing is, I sold its carcass to some ricer dude who was going to turn it into a street racer, lol.  So it probably met a fiery death on some lonesome adirondack mountain road.
« Last Edit: Fri, 03 September 2010, 22:16:12 by wellington1869 »
« Reply #33 on: Fri, 03 September 2010, 22:14:13 »
That almost sounds like the Ford Pintos! They had clutch issues too if I'm not mistaken.
Low-end vehicles, but they sure look nice. Better than these ugly boxes of plastic:
Offline Konrad
« Reply #34 on: Fri, 03 September 2010, 22:14:24 »
My first car was a 1970-something Volvo ****ing ugly yellow piece of ****, much like this one
I bought it for about all of $200, partied for a few years, sold it for $200. Bloody thing was indestructible but as gutless as a golf cart. I remember buying gas all the time, don't recall changing the oil even once.
My new Civic was a massive upgrade, although it cost more in maintenance. ;)
« Last Edit: Fri, 03 September 2010, 22:16:30 by Konrad »
« Reply #35 on: Fri, 03 September 2010, 22:19:31 »
Quote from: Konrad;219737
dude, that car has serious personality.  I'd miss the modern day comforts but i'd be proud to drive that ;)
« Reply #36 on: Fri, 03 September 2010, 22:23:02 »
Quote from: kishy;219735
I seriously dislike the current trend in pretty much all vehicles (elimination of a proper view out the rear window).
When one reverses, they should be looking out the back window and two rear quarters, not dividing their attention across the three mirrors.
ya there's a lot of current trends in cars that i despise. Along with back windows: bug-eye "stretch" headlights. Damn i hate those with a passion but everyone is jumping on board, even BMW with its tear-shaped headlights.
I couldnt believe BMW would abandon its classic circular headlights which were the face of bmw for like 30 years. I thought that was a huge mistake on their part.
Same with tail lights now, i've noticed. No one makes dignified tail lights any more. They're all warped and wrapped around the corners in weird angles, so angular.
« Reply #37 on: Fri, 03 September 2010, 22:25:33 »
EDIT: "66 GL" is that supposed to be PC 66 series or something? Well maybe that's where 300GL came from.
« Last Edit: Fri, 03 September 2010, 22:30:53 by EverythingIBM »
Offline ricercar
  • mostly abides
« Reply #38 on: Fri, 03 September 2010, 23:03:50 »
Your toolkits must be huge. Mine won't come close to holding an automobile. Well, maybe a fiesta.
« Reply #39 on: Fri, 03 September 2010, 23:16:26 »
Quote from: ricercar;219755
oh, i misunderstood! I thought the thread was "whats your pc toolkit in?"
Offline Konrad
« Reply #40 on: Sat, 04 September 2010, 01:06:45 »
Quote from: wellington1869;219738
I was there man. You really don't know what you're talking about, trust me.
For instance, the speedometer was basically a red plastic indicator that slid sideways across a ruler, the reported value was only theoretically associated with actual speed. The odo had been rolled so many times that I don't think it was meaningful at all. Heat and air-conditioning were simulated by opening small flaps to direct airflow from the front of the vehicle to the passenger's face, although one could choose whether it was "fresh" or pulled from across the radiator. The glove compartment was not compatible with uphill travel. Once the windows were rolled down you had to frantically fight gravity when attempting to roll them back up. The rearview mirror would not adhere to the windscreen, it would fall off every time you accelerated or hit a bump so I eventually just let it sit on the floor and became a bit of a blind ******* driver. (A valid strategy, since every other driver had a car worth real money so they'd back off.)
A previous owner had replaced the ignition system with one extracted from some John Deere machine; you only got one shot off the battery, but it never failed even in the worst Vancouver winter. The shocks, too, were upgraded by a previous owner, though less successfully: they were parts from a Ford Bronco and gave this puny yellow lemon more jolting bounces than a pokemon on a cocaine rush. I should probably mention that the gear-shifter handle, too, had been lost and replaced by a previous owner - there's nothing quite like the experience of driving a 5-speed "stick" made from a pair of vice-grips. Did I mention that the steering wheel would sometimes randomly slip off the column when turned a full 360? Duct tape was a partially successful solution.
The main reason I sold this beast (other than the fact that it was obviously such a superior wagon for attracting babes) was that it would cost more to upgrade the exhaust system to pass Air Care than the vehicle was worth.
« Last Edit: Sat, 04 September 2010, 01:25:24 by Konrad »
Offline WhiteRice
« Reply #41 on: Sat, 04 September 2010, 10:56:31 »
What's this? A power supply?
Perhaps not...
Tools
TIM
TIM remover
Lapping kit
DVD lense cleaner
Cables
Spare hardware
Foot
Offline ch_123
« Reply #42 on: Sat, 04 September 2010, 10:58:57 »
What software is that beside the lense cleaner?
Offline chimera15
« Reply #43 on: Sat, 04 September 2010, 11:15:20 »
This is more than likely a result of there being water vapor in the compressor air.  It's important to use a water trap with a compressor if you use it for this kind of thing.
« Last Edit: Sat, 04 September 2010, 16:58:56 by chimera15 »
Alps boards:
« Reply #44 on: Sat, 04 September 2010, 11:25:50 »
Quote from: EverythingIBM;219736
You haven't seen the worst!
I don't like to drive vehicles that look like they were made out of recycled garbage bags.
Offline ch_123
« Reply #45 on: Sat, 04 September 2010, 16:04:44 »
Quote from: chimera15;219852
This is more than likely a result of their being water vapor in the compressor air.  It's important to use a water trap with a compressor if you use it for this kind of thing.
AFAIK, there can be issues with the air generating static, or just simply blowing stuff away.
"It hasn't happened to me, so everyone else must be doing it wrong"... The last words of the guy who relies on coitus interruptus, amirite?
Offline chimera15
« Reply #46 on: Sat, 04 September 2010, 17:00:13 »
Yeah but it's most likely the water thing.  I've used a compressor with no water trap on it that just blew out streams of water instead of air, almost like a water hose.  I put a water trap on that one, and it was too much for even the water trap to handle, and still had water in the line.  It can be especially bad depending on the dew point and humidity.
« Last Edit: Sat, 04 September 2010, 17:03:47 by chimera15 »
Alps boards:
Offline Konrad
« Reply #47 on: Sat, 04 September 2010, 17:28:17 »
I've always been aware of the possibility of ESD from air blasts.  After all, some electronics compressed air cans proudly proclaim their ESD safety while others don't.  If there's a possibility a sealed product can cause ESD then a nasty blast of polluted garage/machine-shop air can too.  I've used compressor air quite a lot, cautiously, and suffered no ill effect that I know of (other than choking dustclouds in my face).
When you think about it, even electrically inert gasses (like, say, pure Neon or Argon) can interact with a rapid bombardment of electrons (thus, flourescent bulbs) ... so a rapid bombardment of anything (even Argon) can interact with electrons.
Er, anyhow ... I suspect the actual risk depends a great deal on contaminants.  (How many of us put automotive-airbrush quality particle filters on our "normal blast of shop air" attachment?  Conductive metal attachment, I'll point out.)
I suspect it depends a great deal on humidity.  Never in the sort of climate I get (rainy Pacific Northwest - said to be similar to Scotland and Ireland), except during cold snaps in midwinter.  Maybe it can be a significant problem in hotter/drier regions like midwestern USA, all seasons of the year.
Offline ch_123
« Reply #48 on: Sat, 04 September 2010, 17:40:18 »
We have almost no humidity, except in the middle of summer. Definitely nothing like when I've been in the US in summer.
« Reply #49 on: Sat, 04 September 2010, 17:45:32 »
I'd have quite an allergy problem if I lived where you live.
