Author Topic: [IC] GMK 1520 | GB Announced!  (Read 196922 times)
Offline Neely_12
Re: [IC] GMK 1520 | GB Announced!
« Reply #200 on: Wed, 07 February 2024, 00:57:43 »
Hark and I are super excited to announce that the groupbuy for GMK 1520 will start March 1st and end on the 29th!
Finalized kitting, estimated pricing, and vendors are all listed in the OP.
We would like to thank each of you for your continued interest in the set. It's been a long journey, but it is finally happening so make sure to grab a set when the groupbuy is live!
Offline Rhienfo
  • Why is everything I want here so expensive :(
« Reply #201 on: Wed, 07 February 2024, 07:19:32 »
oh it's happening soon :eek:
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline takuto
« Reply #202 on: Wed, 07 February 2024, 17:02:21 »
LET'S
@#$%IN'
GO
OOOO
Thanks for getting this to GB, Neely! Shoutout to those of us that kept the faith :thumb:
Offline mr_foggy
  • neue = nope
« Reply #203 on: Fri, 09 February 2024, 19:47:14 »
I'm so in
Offline stomaha
« Reply #204 on: Fri, 09 February 2024, 22:34:42 »
in in in
Online Rob27shred
  • Insane in the Membrane! 👻
« Reply #205 on: Sat, 10 February 2024, 09:29:18 »
Nice
Offline h40
    • h40.io
« Reply #206 on: Sat, 10 February 2024, 09:30:23 »
Super excited for this. Thanks for sticking with it.
Offline vheissu
  • Pragmatic Geometrist
« Reply #207 on: Thu, 15 February 2024, 12:20:05 »
Is it March yet?
Offline Neely_12
« Reply #208 on: Mon, 19 February 2024, 21:55:24 »
Little Update:
The 1.25u Fn will also have the blocks on either side of it like the 1.5u. Both of these will be doubleshot, not UV printed.
Offline ideus
  • Björkö.
« Reply #209 on: Tue, 27 February 2024, 14:16:09 »
Heads up!: The final kitting images are not available.
Offline Neely_12
« Reply #210 on: Tue, 27 February 2024, 21:22:56 »
Thanks for the heads up! Will fix asap  :thumb:
Offline Trackpoint
« Reply #211 on: Wed, 06 March 2024, 09:26:23 »
Is there a GB thread for this? I missed that it had started, seems like most vendors have it up now.
Offline avtar
« Reply #212 on: Sat, 09 March 2024, 19:45:25 »
GB page: https://geekhack.org/index.php?topic=122578.0
