Author Topic: Which keyboard should I use for Norbaforce Mark II?  (Read 2398 times)
Offline AW_Keyboard
« on: Sun, 26 September 2021, 09:00:36 »
Hello, I am new to this community, sorry if I asked a duplicated question.
I am looking for my goal - Norbaforce Mark II, MT3 keycap, probably with BKE redux light domes and deskey#3
If I am going to mod anyway, should I start with RF R2 RGB TKL instead of R2 TKL due to the cherry MX keycaps compatibility? I am not sure if R2 is better than R2 RGB in terms of build quality?
Thank you for your advice!
Offline _rubik
Re: Which keyboard should I use for Norbaforce Mark II?
« Reply #1 on: Sun, 26 September 2021, 14:04:48 »
I'm going through this process myself actually. I'm starting with an 87u, painting the plate white, swapping deskeys sliders, domes, and o-rings -- the works. Here's the thread if you're curious. I'm waiting on the Deskeys stabs to be released and Norbaforce to ship before making any other changes.
That said, I would recommend starting with an R2 RGB just for MX compat like you mentioned. I haven't had the chance to type on one myself, but they seem fairly well received. I'm just going the "long way around" because I love my 87u and want to carry the typing experience over.
If you're not trying to replicate a typing experience, I'd just jump straight to the newest revision.
« Last Edit: Sun, 26 September 2021, 14:06:24 by _rubik »
Offline AW_Keyboard
« Reply #2 on: Sun, 26 September 2021, 23:38:09 »
Thanks Rubik :)
I think I will go for R2 since I am quite worried about the RGB will affect the typing experience and I will wait for the deskey slider to be released.
Thank you for your advice.
Offline _rubik
« Reply #3 on: Mon, 27 September 2021, 00:17:56 »
Thanks Rubik :)
I'm not sure how different the R2 and R2 RGB are in terms of typing feel (I'm guessing they aren't that different), but I might go with the RGB if I were you. MX compatible Topre stabs have always been sub-optimal, and we have no promises the new Deskeys stabs will be any better. Not to mention spacebar support  :eek:
I'd recommend you hop onto the Deskeys discord and ask around in the des-sliders channel. You'll probably find someone with more hands-on experience with R2 boards that can better address your concerns.
