Author Topic: [IC] GMK Deep North  (Read 27248 times)
Offline micho
Re: [IC] GMK Deep North
« Reply #50 on: Fri, 04 February 2022, 15:34:07 »
I'm sad the manu changed to GMK and the mono rune kit was removed. GL with IC
Offline vindfrisk
« Reply #51 on: Fri, 04 February 2022, 17:05:50 »
I really hope you will add NORDE kit, it would complete this set. =))
Offline wahfuhls
« Reply #52 on: Fri, 04 February 2022, 18:03:42 »
gib
Offline linell
« Reply #53 on: Fri, 04 February 2022, 20:39:23 »
I'm over gmk but I understand the change
reverse dye sub and all
nice chonky base kit
hope the price is kept on the lower side
GLWIC  :thumb:
bro this a **** set, just be thankful you even getting 1 base running fr
Offline thomen
« Reply #54 on: Sat, 05 February 2022, 04:54:33 »
Sign me up when/where can we preorder!
Offline konstantin
  • Formerly constexpr
« Reply #55 on: Sat, 05 February 2022, 14:09:05 »
This set is missing R3 PgUp, R4 PgDn keys for 65% support. These keys should be added to the base kit based on the popularity of 65% layouts in the community.
Accent-colored R2 Esc is not a strictly necessary key and as such can be removed from the base kit.
Since proper spacekeys are included in the base kit, the usefulness of the second 2.25u Shift is relegated to physical support for 660 layouts, which are quite rare nowadays. Therefore, the second 2.25u Shift should be moved from base to the extensions kit.
As a final note, I don't think that including a full set of macro keys in the extensions kit is a good idea. It bloats the price of the kit while not providing that much extra utility. Consider: a) splitting them out into a separate kit, b) reducing the number of columns down to two (two columns is still useful for covering ortho boards), or c) dropping them altogether.
« Last Edit: Sat, 05 February 2022, 14:29:58 by konstantin »
Offline OJtheTiny
« Reply #56 on: Sat, 05 February 2022, 21:31:45 »
Moving the shift is a good point. 65% boards can be kitted perfectly with the base kit as is but I'll consider adding the additional keys. As for the macros and r2 esc, those are something I'm not willing to compromise on personally, thank you for the suggestions though
Offline konstantin
« Reply #57 on: Sat, 05 February 2022, 21:43:53 »
In that case, moving the Shift and adding the two additional keys (essentially swapping out 2.25u for 2u) should be the way to go.
Offline sup3r170va
« Reply #58 on: Sat, 05 February 2022, 23:01:36 »
Very nice set. I’m in.
Offline nvh2092
« Reply #59 on: Sun, 06 February 2022, 07:27:41 »
Please consider adding mod color iso + numpad enter to base kit with R3 PgUp + R4 PgDn. A novelty kit would be nice
Offline HappyB0T
  • I'm a Piggie
« Reply #60 on: Sun, 06 February 2022, 21:02:02 »
Interesting set & alternate kit. Are shine through caps always pad printed or can those be doubleshot?
Offline Draxion
« Reply #61 on: Tue, 15 February 2022, 00:08:28 »
I hope the mono rune returns
Offline Keybjorn
« Reply #62 on: Tue, 15 February 2022, 04:50:24 »
I hope mono rune alt alphas come back. Sköl!
Offline dacostajs
« Reply #63 on: Thu, 17 February 2022, 13:44:47 »
I wish the accent arrows were in the base kit or in the spacebar  :(
Offline sup3r170va
« Reply #64 on: Thu, 17 February 2022, 17:59:00 »
Delete
Offline thomen
« Reply #65 on: Tue, 01 March 2022, 18:23:14 »
Reserved please :)
Offline hongoo
« Reply #66 on: Thu, 03 March 2022, 09:06:38 »
The 40s looks good.
Offline mr_foggy
  • neue = nope
« Reply #67 on: Fri, 04 March 2022, 06:09:12 »
why gmk
Offline dankthock
« Reply #68 on: Mon, 18 April 2022, 02:20:41 »
if it has runes i need it
