Author Topic: [IC] Krado66 - A "Destaggered" 65% Ortholinear Keyboard  (Read 23456 times)
Offline Narf
    • Krado Industries
« on: Sat, 02 October 2021, 09:55:35 »
I am pleased to present the result of my first custom keyboard design project:
Krado66
A "Destaggered" 65% Ortholinear Keyboard that accepts standard-sized keycaps
Group Buy is Live!
The idea was to take the popular 65% layout and make it ortholinear while still be able to use standard-sized keycaps. I also tried to maintain an aesthetically balanced layout. I know I am not the first to make this kind of layout (SPRH, Fold KB, ZT60, Spacey, etc.) each one was missing something for me, so I made my own.
I have been an ortho user for a few years now. Ortholinear boards themselves are great, but it has always been difficult to source keycaps because most of the beautiful custom keycap sets out there are designed to accommodate a few of the most common layouts in order to hit the required numbers. 40s kits are becoming more common, but many 40% keyboards are staggered layouts, and ortholinear 40s use smaller 1u keys. Ortholinear keyboards with larger mods tend to use Ergodox style 1.5u modifiers, but Ergodox kits are very niche, even compared to 40%. As a result, Ergo kits are rarely offered for custom sets. I would rather have keycap makers lower their MOQ so that designers could make all kinds of rare kits for unique and interesting custom layouts, but that seems unlikely to happen anytime soon. I also wanted to make this a sort of an easy gateway into ortholinear, and because of it's compatibility with 65% and standard ANSI layouts, people will be able to use just about any MX-compatible keyset that they may have lying around.
I have several functional prototypes that I have been daily-driving for the past few months. In fact, I am typing this post on the one in the picture! I have a few extra functioning PCBs as well.
PCB
Features:
  • QMK compatible
  • USB-C (Center mount)
  • ESD Over-Current Protection
  • Khail Hotswap
  • Encoder support (two locations, but only one supported at a time)
  • Stepped caps lock support (Stepped caps lock switch is south facing, normal is north facing)
  • Split backspace support
  • Supports three different bottom row mod/arrow cluster configurations
Layouts
The Case
The case in the picture features:
  • Stacked clear acrylic with special chamfered edge and countersunk screws for a smooth surface. (Production models would have shallower countersinks for closer to flush fit.)
  • 7o typing angle
  • Layout options to two top layers to accommodate blockers for arrow cluster and encoder(s)
  • High profile
  • 17mm front height (desk to first chamfered edge)
  • Can accept CNC Aluminum Cone Feet
This is a fairly early stage Interest Check. I am mostly just putting out feelers to see if enough people would be interested in buying one, and to get feedback on the design. Price and expected run dates are not set yet. I have been working with a local plastics company to get the beveled and countersunk pieces. Their turnaround times have been pretty good, but their QC has been a bit lacking. Fortunately, they are responsive and will redo pieces quickly. I have also designed an FR4 skeleton case for a lower cost option if people just want to give the layout a try. I would be interested to see what people think of this board. If it does go to groupbuy stage, it would likely be a very limited run at first, as this would be my first time running a GB and I would like to be able to closely oversee quality control and keep things at a more manageable level.
Interest Check Google Form: https://forms.gle/YvoeAmW29bkJSYPc8 (4-5 minutes)
Anticipated questions:
Will ISO support be offered?  No. Due to the ortholinear nature of the layout, ISO enters cannot be used.
Typing test?  Maybe. I do not have a fancy streamer setup. To be honest this board is more about the layout than the sound experience. It would really only be to showcase functionality.
Price?  TBD (probably around or under $200 for acrylic and sub $100 for FR4 skeleton. Maybe over $100 for carbon fiber skeleton if people are interested.) $135 for acrylic case, $40 for Skeleton Case, $55 for PCB
GB Date?   TBD (probably within the next 6 months, Q1 2022) July 2022
MOQ/Limit?   Going to try to keep the first run around 20~25 Units for acrylic. Might go higher for skeleton.
RGB?   Not in the current iteration. I am considering redesigning the pcb with a duplex matrix for added encoder and RGB underglow support for a future build, but that will take a while. Maybe in a R2, if this gets past a R1. Underglow Added. No per-key backlighting.
VIA compatibility?   Working on it. I typically don't use VIA, so I have to read up on implementation. I have added VIAL support. You can also use VIA by sideloading a .json, but rotary encoders are not supported in VIA.
Any plans for an aluminum version?   Down the road, yes. If a first GB round is successful, I plan to design an aluminum board with an updated PCB. For now, I am trying to keep things simple and (relatively) inexpensive.
Will there be any other colors besides clear for the acrylic case?    Maybe. If there is sufficient interest, I could see making the layer under the top most acrylic piece an accent piece as 3mm acrylic is widely available in many colors. The rest of the case, specifically the top piece would likely need to stay clear, as that is the only color available from the plastic company I am using. I don't really want to complicate orders too much. Options for Clear, Matte Clear, Black, and White will be available.
Will you share the plate files?   Maybe after first round GB concludes.
Discord
UPDATE
GB and Pricing Update
Thanks for looking!
« Last Edit: Fri, 29 July 2022, 11:14:06 by Narf »
Offline misononyan
Re: [IC] Krado66 - A "Destaggered" 65% Ortholinear Keyboard
« Reply #1 on: Sat, 02 October 2021, 19:37:15 »
Probably the nicest looking iteration of  base kit Ortho I've seen, awesome job!
Offline vishydesigns
« Reply #2 on: Sat, 02 October 2021, 22:42:33 »
really cool great job! :thumb:
Offline hark
« Reply #3 on: Sat, 02 October 2021, 23:01:41 »
I actually love the way this looks,  GLWIC!
Offline lush_bunny
« Reply #4 on: Sun, 03 October 2021, 01:31:44 »
Interesting and pretty. GLWIC!
Offline oestrogen8r
  • I SERVED 2 TOURS OF DUTY IN THE LEMURIAN TIME WAR
« Reply #5 on: Mon, 04 October 2021, 10:29:17 »
GLWIC! I just wish this were slightly wider so I had a delete key behind the pipe key
Offline YMwoo
« Reply #6 on: Mon, 04 October 2021, 21:29:54 »
Love this!
It'd be even better if it supports split spacebar.
I'm also more interested in alu case, even better if you can make it looks unique without being too much.
Offline Juan.
« Reply #7 on: Mon, 04 October 2021, 23:00:01 »
this looks like my sleep paralysis demon
rubber cup
Offline Loquerish
« Reply #8 on: Thu, 21 October 2021, 09:10:17 »
GLWIC! Very interesting layout and i like it
Offline Parva Ovis
« Reply #9 on: Thu, 21 October 2021, 10:37:14 »
Looks great! Split spacebar support (with 1.25u on the left) is a must for me, though.
Offline Sup
« Reply #10 on: Wed, 27 October 2021, 16:32:42 »
Looks awesome. I wouldn't mind picking one up but, the price of 200 ish for a acrylic board is pretty steep they are supposed to make stuff cheaper. I assume its because of the low MOQ.
current
Coming soon
Offline Narf
    • Krado Industries
« Reply #11 on: Mon, 06 December 2021, 23:32:09 »
Just a quick update on this project:
There seems to be sufficient interest in this board, so I plan to run at least one GB.
I am finishing up the redesign of the PCB with the following features added: Split spacebar (two different layouts), RGB underglow, additional encoders spots, and a few additional layout options. I will be making a few final checks this week, and then hopefully ordering prototypes the following week. Once I get some functional prototype PCBs in hand I will make a larger update.
Offline Narf
    • Krado Industries
« Reply #12 on: Fri, 14 January 2022, 23:11:18 »
 Hello Everyone,
Thank you to everyone that filled out the interest check survey. As a result of the survey, as well as several suggestions from Reddit, I decided to completely revamp the PCB.
Two Split Spacebar Configurations are Now Supported
Considering it is an othro keyboard, I probably should have added split space in the first place, but due to the large Atmega32u4-AU footprint being located under the spacebar, it was not possible. Changing the MCU to the smaller Atmega32u4-MU allowed me to relocate it.
I am happy to say that I was able to add two different split Space layouts: 2.75u – 1.25u – 2.25u and 1.25u – 2.25u – 2.75u. There are a few areas where hotswap sockets may interfere with stabilizer screws in the  1.25u – 2.25u – 2.75u configuration, but it seems to work fine.
RGB Underglow Added
I wanted to add RGB in the first iteration of the board, but it was all I could do to get a basic matrix and traces correct. I had never designed a pcb, and I didn’t want to bite off more than I could chew. Plus, I ran out of pins on the MCU because I didn’t know how to duplex matrix. Using the more efficient [10x8] instead of [5x16] matrix, I had enough pins for RGB. I added 14 ws1218 leds. I thought about adding per-key backlighting, but decided it would be too much work for something I wasn’t really interested in. I have no plans to add it to the board.
Additional Encoders
Most people indicated that if they did install an encoder, it would in the top left location. After converting redoing the matrix gave me some extra pins, so I decided to add some more encoder spots and channels. I really wanted to see about adding one to the top right of the board, but the 2u Backspace stabilizer holes make it impossible. Instead, I added one for the 1u keys to the left of the arrows, one in the center 1.25u split Space area, and one to the 1.25u left control spot. Obviously, adding encoders to a 1.25u footprint is not ideal, but I figured I would add them in case anybody wanted them there. The top left has its own channel, left Control and center Space share a channel, and right Control and FN share a channel.
VIAL Support Added
I was finally able to get encoders working in VIAL. VIA is not officially supported at the moment, but you can sideload a .json and use VIA to reprogram the board. However, VIA does not support encoders.
True Ortho – Align Right Modifiers
I added the ability to move the right-side modifiers (2u Backspace, Pipe, Enter) over to align with left edge of the right Shift key. This layout was an idea that I had for a smaller version of this board, the Krado60, which would have eliminated Minus, Plus, the Brackets, and Quote/Apostrophe altogether. Someone raised concern that the destagger put Backspace even farther way, which is something I definitely noticed when first typing on this layout. It wasn’t too difficult for me to get used to it, but then I thought, “well, I did split backspace support for that 2u Backspace, why not make the two keys next to that a split backspace too?” Then I figured, “why not align Pipe and Enter?” I don’t know if anyone will use this feature, but I will be interested to try it out. *Note that for the Enter row, aligned Enter key switch will be north-facing and the apostrophe key will be west-facing (rotated 90o) so there may be some interference with certain keycap/switch combinations.
Daughterboard Support Added
I have added a JST connector footprint and breakout pins. I'm still deciding whether I should actually have the JST connector soldered on the board for an initial skeleton/acrylic run as it would necessitate either a cutout on the bottom or higher pcb height.
 Next Steps:
For now, the plan will be to definitely run a skeleton FR4 kit in the near future. I would like to do an acrylic version as well, but I need to make sure the manufacturer has the ability to make the top piece (with beveled edged and countersunk screws) to exact specification. Either way, the skeleton case parts will have the ability to be used in the stacked acrylic case.
There seemed to be a decent amount of interest in an aluminum/polycarb version. I would also like to see this happen, so I am busy designing it. Don’t hold your breath, though. It could be 6 months before I am finished with a CNC design.
I will post some pictures of built skeleton protos with the new layouts in a few days.
Discord
« Last Edit: Wed, 19 January 2022, 00:27:39 by Narf »
Offline lazaret
« Reply #13 on: Tue, 18 January 2022, 17:32:28 »
Discord
Discord link is broken in this update post, but works in the main post
Offline Narf
    • Krado Industries
« Reply #14 on: Tue, 18 January 2022, 17:43:02 »
Discord
Should be fixed now. Thanks!
Offline Narf
    • Krado Industries
« Reply #15 on: Mon, 24 January 2022, 20:55:14 »
Posting some prototype build and layout pictures.
Apologies for phone picture quality.
Offline te-ce
« Reply #16 on: Mon, 07 March 2022, 15:23:08 »
I am so stoked for this board!
can't wait
Offline Narf
    • Krado Industries
« Reply #17 on: Tue, 17 May 2022, 00:05:33 »
Hi everyone,
I just wanted to give an update on the project. I am planning to run the GB in the next month or two.
I have finally settled on a case design. I increased the bezels slightly to make the top edge bevel farther from the screw holes. The acrylic manufacturer was able to make countersunk holes within spec, so the top screws will be properly countersunk to be flush. I redesigned the feet to be stacked so that people can choose different typing angles. I plan to offer white and black in addition to clear acrylic. There is a matte finish acrylic with limited thicknesses that I am checking on as well. (The matte texture is only on one surface and would be the same as clear on the side edges.) Pricing for the acrylic case (without PCB) should be under $140. I am working on getting quotes for the PCBs this week. Figuring out final pricing in the next few weeks.
An FR4 case (plate and bottom with standoffs) will also be offered. These pieces are the same size as their acrylic counterpart and therefore can be used with the acrylic case parts. I will also offer acrylic space/diffuser parts if people want to add those to their skeleton cases. There will also be the option to buy an extra top piece if you want a different color or if you want a blocker vs no blocker.
I am currently experimenting with a gummy o-ring gasket mount for the acrylic board. I still need to prototype it, but if it works I will also offer that configuration as well.
Edit (Jun 19, 2022): after messing around with o-rings I have concluded that I would need to do several rounds of prototyping to get it right. For now, this idea is on hold and will not be offered during GB.
« Last Edit: Sun, 19 June 2022, 16:03:45 by Narf »
Offline Wonderfool
« Reply #18 on: Tue, 17 May 2022, 15:48:19 »
Hooray!
Offline condorman
« Reply #19 on: Thu, 09 June 2022, 14:58:39 »
I pray I don't miss the group buy for this! This is exactly what I've been looking for!
Offline Narf
    • Krado Industries
« Reply #20 on: Thu, 30 June 2022, 20:51:43 »
Hi everyone,
I plan to start the group buy in July.  Final dates TBD.
Format
I was initially going to accept orders through Google forms with PayPal invoices, but I am looking into setting up a proper online store. As soon as I am satisfied with the site, I will start the group buy.
  + FCFS 50 Acrylic cases
  + FCFS 50 Skeleton cases
The GB will close early if numbers are met. While I would love to make it unlimited, this is my first time running a GB and I want to be able to fund the manufacturing out of pocket in the event that payment processors withhold funds. I will order a few extras, but in general I would like to keep the total number of orders around or below 100.
Shipping ETA is Q4 2022
Prices
$55 PCBs
$135 for Acrylic case kit (Sandwich mount, Black, White, and Clear) – PCB not included
$40 FR4 Skeleton case Kit – PCB not included
$40 RGB Underglow Diffuser Kit for FR4 Skeleton case (Black acrylic with translucent white acrylic)
$45 Extra Top Pieces (matte black, matte white, clear, matte clear. Consists of 2 acrylic pieces)
Skeleton Case Kit
- FR4 Switch Plate and Bottom (black)
- M2 Brass Standoffs and M2 Screws
- SKUF Silicon Clear Feet- PCB not included
Acrylic Case Kit
- High profile case design (7.5mm from plate to top piece)
- 9 Piece Clear Acrylic (10 pieces for black and white)
   - Top and bottom pieces have matte texture for white, black, and matte clear. The matte texture will be on the outer surface only (i.e. top of top piece and bottom of bottom piece). All other surfaces, including the sides, will be normal.
   - Top piece has a beveled (chamfered) edge and countersunk screw holes while the bottom piece has a beveled edge for a more premium feel.
   - All case colors will have clear acrylic feet
   - The acrylic feet will have 3 tiers, and the case kit will come with hardware to do either a 3 tier or 2 tier foot.
- M2 Brass Standoffs and screws
- SKUF clear silicone feet- PCB not included
Other/Extra Parts
Extra Top pieces (blocker and no blocker) will be available if you want to try both configurations, or if you want a different color. A diffuser kit for the FR4 Skeleton kit will also be available.
« Last Edit: Fri, 01 July 2022, 12:46:18 by Narf »
Offline treeleaf64
    • treeleaf64
« Reply #21 on: Thu, 30 June 2022, 22:22:57 »
Why this name? why not call it "Destaggered 65% ortholinear keyboard" it makes much more sense than saying "i bought a krado66" and have to look it up
Pet pet Happy pet I like it!
Everyone must pay the cat tax
Offline SDKCAMPING
« Reply #22 on: Thu, 30 June 2022, 23:30:13 »
you have to b a troll to comment this but not a funny one
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline LumiP
  • A lil Faedude on the net. Fave layout is FRLTKL!
    • Sometimes I do builds on Twitch! :3
« Reply #23 on: Fri, 01 July 2022, 04:18:05 »
Not for me but I love the concept! GLWIC
Current Boards: Aaru TKL (Old Dark Sand) | Drop + Planck (Purple) | Mr Suit WKL (Black w/Gold Chamfers) | Sangeo60 (Black) | KBD67Lite (White) | D45 (E-Grey) | Wind X (Pink) | NCR 80 (Beige) | QK65 (Dark Green) |Av4 Claymore | TGR x Monokei Tomo (Suave Blue) | Heracles80 (Holy White) | Snake60 (Rust) | Array (E-White) | Capsule (E-White) | QK75 (E-White) | | QK80 (Black) | Envoy 65 (Clear PC) | Mode Sonnet (Ice Blue) | Cycle 7 (Lavender, E-White) | Neo70 (Retro White, Black) | Reflection (Chocolate) | Matra Alice 90 (Glossy Red) | Haven TKL (Silver/Red) | Baldur64 (Black) | XOX70 (Bonsai) | SWISS | Cycle 80 (Zeal)| QK80 MKII (Pink) | Polygon 7 (Grey) | QK75N (Smile Yellow) | Han80 (Beige) | THE BASE (Black) | NV-70 (Silver) | Matrix Carnival (Asagao Purple)
Offline Narf
    • Krado Industries
« Reply #24 on: Tue, 26 July 2022, 11:54:58 »
Thank you for all of your feedback!
Group Buy thread up!
Offline niakulah
« Reply #25 on: Mon, 05 September 2022, 00:20:02 »
I would be very very interested if you could have a 2U key in the bottom row, slightly to the right of the middle. Then a 1U key to its immediate right.
Then you could have exactly a numpad layout for the right hand in a layer.
Offline Narf
    • Krado Industries
« Reply #26 on: Mon, 05 September 2022, 12:37:52 »
A 2u key and this exact layout are not possible, but you can achieve a similar result using either of the split space configurations. The bottom row will just be shifted a bit to the left.
This is what I use and it works well.
