Author Topic: Xd87 steel bent case screws  (Read 1609 times)
Offline Kaisung_24
« on: Sun, 03 October 2021, 11:34:21 »
Hello there,
I am somewhat new to geekhack and heard this is where to go to get help. I have the xd87 steel bent case and when i was putting it together i noticed that i only have two screws to mount the case pcb and acryllic piece all together and was wondering what screws i need that will fit. Thank you
Offline Maledicted
Re: Xd87 steel bent case screws
« Reply #1 on: Wed, 06 October 2021, 12:10:47 »
Hi Kaisung_24. Welcome to Geekhack. I have been in hibernation a while now myself.
Have you got a hardware store around? I would just take the screws you need more of to a local hardware store and see if they have a tool for determining what sort of threading you need. It is usually a plate with various threaded holes that labels them all. If the screws thread in, then that's what you need. You may not find the exact same length of screw, or head type. Just get as close as you can.
If you want, once you know the specifications you need, you might be able to find something closer online.
