Author Topic: [IC] ePBT Yukihana | GB Post live!  (Read 79619 times)
Offline Chuttau
  • Formerly botallu
Re: [IC] ePBT Yukihana | GB 11th Dec | HIBI Collab | DM/DMG raffle TODAY
« Reply #50 on: Thu, 04 November 2021, 00:13:22 »
bump for the DM/DMG collab with melonkeys
click the photo at the top to join
Offline konstantin
  • Formerly constexpr
« Reply #51 on: Thu, 04 November 2021, 10:56:05 »
Since this is EPBT, I suggest adding a second 2.25u Shift (physical compat for 660 layouts), as well as 2× 1.5u Code + second 1u Alt (Mac and OG HHKB bottom row compat) to the base kit.
I also suggest using System or Super instead of Code as the OS key legends.
R2 1.5u \|む, like the other pipe keys, should not have a ¥ sublegend in the top right.
Consider adding a R1 1u = key to the numpad kit.
Accent-colored spacekeys other than 6.25u, 7u and sometimes 2u, 2.25u, 2.75u aren't particularly popular. You should remove the following blue spaces from the spacebars kit: both 1u, both 3u, 6u.
In their place, add 1u, 1.25u and off-centered stem 6u in white, and you'll be good to go.
« Last Edit: Thu, 04 November 2021, 11:10:35 by konstantin »
Offline Chuttau
  • Formerly botallu
Re: [IC] ePBT Yukihana | GB 11th Dec | USD Price announced
« Reply #52 on: Sun, 14 November 2021, 09:34:50 »
Pricing announced (for KBDFANS, Mekibo and ThicThock)
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #53 on: Mon, 15 November 2021, 19:04:16 »
so are all kitting suggestions being ignored now? 40s kit still needs some work and kon's suggestions should be considered too
Offline The0rigina1
  • fumoposting
« Reply #54 on: Sun, 21 November 2021, 11:08:38 »
Runners have the right to reject suggestions though, no?
Offline Chuttau
  • Formerly botallu
« Reply #55 on: Mon, 29 November 2021, 18:41:10 »
Update!
We are collaborating with Thic Thock to bring you Yukihana switch!
Specs:
Top Housing: Custom Nylon blend (Transparent Blue)
Bottom Housing: Custom Nylon blend (will be colour matched with keyset)
Stem: POM
Spring: Thic Thock Spring V2 (JWK) - 20mm - 58.5g
Nature: Linear
Factory Lubrication? No
Price: $3.75/10
MOQ:60K
A draft render for how the switch will look
« Last Edit: Wed, 01 December 2021, 02:49:19 by Chuttau »
Offline Chuttau
  • Formerly botallu
Re: [IC] ePBT Yukihana | GB 11th Dec | All prices announced!
« Reply #56 on: Wed, 08 December 2021, 02:57:41 »
GB is in 3 days!
Prices for all vendors announced
Offline Chuttau
  • Formerly botallu
Re: [IC] ePBT Yukihana | GB Post live!
« Reply #57 on: Fri, 10 December 2021, 11:09:41 »
GB post is live
Thread locked
