Author Topic: [IC] ePBT Yukihana | GB Post live!  (Read 79812 times)
Offline Chuttau
  • Formerly botallu
« on: Sun, 03 October 2021, 17:06:18 »
GB post is live
Vendors
WW:KBDFans
NA:Mekibo
EU:Candykeys
UK:Proto[Typist]
CA:Deskhero
SEA:ThicThock
OCE:Dailyclack
GB Date: 11th December, 2021
Inspiration
Yeah.
Kits (Updated 10/6)
Pricing: TBA
Hiragana Base
¥ sublegend is a mistake, new render will be made before the GBfixed
Latin Base
Novelties
Numpad
Spacebars
40s
The backspace with legends is an error and will be fixed soon
Macro/UKISO
Collaborations
HIBI x Yukihana Metal Artisans
There will be 2 Variarions available- Snowglobe and snowman
Melonkeys x Yukihana Artisans
Melonkeys and us brings you DM&DMG&Tamagos in Yukihana Colorway!
Make sure to check out their Instagram and Discord for more cute artisans!
Renders
LAMY TKL blue by Fuyu.owo
LAMY TKL E-white
AKI-S by senryo
Others
https://imgur.com/a/hMv6Y9B
Special thanks to Kig and rnviz for the amazing renders
All the vendors who supported the project
Kibou.store
and the weebs
Signature:
Code: [Select]
[url=https://geekhack.org/index.php?topic=114832.0][img width=360 height=120]https://i.imgur.com/N9O2v6t.png[/img][/url]
« Last Edit: Fri, 10 December 2021, 11:10:36 by Chuttau »
Offline Chuttau
  • Formerly botallu
Re: ePBT Yukihana
« Reply #1 on: Sun, 03 October 2021, 17:06:38 »
reserved
Offline chung
Re: [IC] ePBT Yukihana
« Reply #2 on: Sun, 03 October 2021, 17:11:11 »
nice.
Offline Sicowa
« Reply #3 on: Sun, 03 October 2021, 17:12:36 »
I remember seeing this in GMK before?
 any reasons why you wanted to change manus?
cool set though
Collection: Khajit 60, Leopold FC980C, Pepper, Ex. Visa, Daedalus
pfp:https://twitter.com/kuroseP/status/1305179874429079553?s=19
Offline Vorge
« Reply #4 on: Sun, 03 October 2021, 17:13:06 »
Are you planning on doing deskmats/artisans/metal keycap or something like that? Other than that Im buying this like all the other "yes" inspired keycaps. Gotta think about that lamy board tho.
Offline The0rigina1
  • fumoposting
« Reply #5 on: Sun, 03 October 2021, 17:13:12 »
reverse dyesub hehe
Offline Chuttau
  • Formerly botallu
« Reply #6 on: Sun, 03 October 2021, 17:14:24 »
cool set though
GMK slow
ePBT stronk
and they make it faster!
Def not I like pbt more
Offline Chuttau
  • Formerly botallu
« Reply #7 on: Sun, 03 October 2021, 17:15:42 »
They are in the works! Will announce when I can show some renders
Offline dededecline
    • Linktree
« Reply #8 on: Sun, 03 October 2021, 17:16:12 »
ePBT is not a 1:1 GMK swap in. Your kitting needs work to be advantageous for ePBT. Please look at previously run sets, and feel free to drop into Keycap Designers and/or 40s discord for kitting help.
Offline Sicowa
« Reply #9 on: Sun, 03 October 2021, 17:18:52 »
cool set though
GMK slow
ePBT stronk
please consider gmk.
gmk is slow.
also reverse dyesub
Offline yqqdrasil
« Reply #10 on: Sun, 03 October 2021, 17:21:21 »
This. 40s kit needs work!
Offline Chuttau
  • Formerly botallu
« Reply #11 on: Sun, 03 October 2021, 17:23:33 »
Yep I actually plan to seperate the numpad from the basekit(pretty sure it is the norm for epbt)
but other than that I am not planning to change anything else because too many kits will just make it confusing.
but if many people wanted the kits become more seperate please let me know in the IC form!
Offline dededecline
    • Linktree
« Reply #12 on: Sun, 03 October 2021, 17:23:49 »
That's part of it but just scratching the surface. Numpad in base kit, dual base kit instead of alpha kits and a mod kit or base kit/alt alphas, no alpha colored 3u spacebars...
Offline dededecline
    • Linktree
« Reply #13 on: Sun, 03 October 2021, 17:26:13 »
I'm not necessarily advocating for more kits, but for better kitting of the existing kits. Realistically you're shooting yourself in the foot here if you don't change anything but numpad, not taking advantage of the ePBT MOQ and pricing structure.
Offline Baka Bot
« Reply #14 on: Sun, 03 October 2021, 17:30:16 »
this is a vtuber
Offline AASH
« Reply #15 on: Sun, 03 October 2021, 17:35:56 »
Please listen to dede.
In the current iteration you're not taking advantage of the advantages of ePBT, and shooting your MOQ in the foot with a second base kit.
Your novelties, 40s kit, base and alternate alphas all needs work. Take a peek in kcd or 40s' keyset-design channel, people will be happy to help you!
40s, with love
40s, with love
Offline yoot
    • none
« Reply #16 on: Sun, 03 October 2021, 17:41:36 »
I'm a fan
Offline Sax_______
« Reply #17 on: Sun, 03 October 2021, 17:47:42 »
This is not a vtuber
Offline Vorge
« Reply #18 on: Sun, 03 October 2021, 17:49:02 »
this is a vtuber
Nono, this is "definetly not a vtuber set" with definetly not a vtuber keeb in a render  ;)
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #19 on: Sun, 03 October 2021, 19:13:14 »
kitting needs work
Offline shima
  • keeb weeb
« Reply #20 on: Sun, 03 October 2021, 19:35:05 »
pog
boards: anura
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #21 on: Sun, 03 October 2021, 21:15:39 »
cool set though
Proof? They haven't shipped a single set that has used reverse dyesub. Skadi has taken over a year.
The only person who is confused with kitting is you.
The only thing keeping everything about this ic from being gmk is the topic title. This is incredibly lazy and an obvious heel turn to noticing gmk backlash thinking you'll get more people on board with epbt. Good luck.
« Last Edit: Sun, 03 October 2021, 21:28:06 by Kokaloo »
Offline Krolyk
« Reply #22 on: Sun, 03 October 2021, 21:26:54 »
Polar is probably dead for good so I'm fully in and supporting this. Kitting could use some work but looks great!!
Sent from my SM-N986U using Tapatalk
Offline Cylent
  • Formerly cylentshadows
« Reply #23 on: Sun, 03 October 2021, 21:57:59 »
I'm a blue fan so I like this, but I have concerns:
-Why are the keys floating in the kit renders?
-there isn't any accent iso available, even in novelties
-40s kit could use a LOT of work
-Spacebars kit doesn't have any normal alpha spacebars, which means you're either covered by the base or you're screwed
-You don't have any colors indicated, which makes me concerned that this is just hex code
I'd like to note that we've seen samples of ePBT's new reverse dyesub molds with the samurai sample images and they look really good. I'm sure some reverse dyesub sets will ship in the next few months and we'll get to see them ourselves, but the quality based on those sample images looks good.
« Last Edit: Mon, 04 October 2021, 12:19:19 by Cylent »
Offline fuyuowo
  • Formerly Kanzuiii
« Reply #24 on: Sun, 03 October 2021, 22:08:50 »
Beautiful keyset :p  need it for my LamyTKL
Offline Ella
  • Why is it called an oven
« Reply #25 on: Mon, 04 October 2021, 00:27:41 »
weebs out
Offline kylekwong1
« Reply #26 on: Mon, 04 October 2021, 03:56:56 »
Sake novelties doko
Offline The0rigina1
  • fumoposting
« Reply #27 on: Mon, 04 October 2021, 04:46:02 »
Floating keys, very important issue, after fix 100% buy no problem.
Offline The0rigina1
  • fumoposting
« Reply #28 on: Mon, 04 October 2021, 12:41:00 »
cool set though
Take a closer look at the 6, it's ePBT 6
Offline ad4m
« Reply #29 on: Mon, 04 October 2021, 15:03:57 »
40s, with love
This. Im going to be nitpicky, but if i am correct ePBT splits 2 basekits to a 100 MOQ each. It’s still an MOQ of 200, it’s just combined. Having Latin and Weeb base is absolutely fine (for reference, ePBT origami is a recent example).
Offline AASH
« Reply #30 on: Mon, 04 October 2021, 16:49:19 »
40s, with love
Didn't know about that! Thanks for the clarification, makes more sense
40s, with love
40s, with love
Offline C.
« Reply #31 on: Mon, 04 October 2021, 17:38:09 »
You say Yukihana, but this is a perfect match for a certain war criminal rabbit board I've got in mind.
Offline Fardesu
« Reply #32 on: Wed, 06 October 2021, 08:18:58 »
Take my money.
Offline Chuttau
  • Formerly botallu
Re: [IC] ePBT Yukihana | Updated Kitting (10/6)
« Reply #33 on: Wed, 06 October 2021, 11:04:19 »
Updated the kits to make it more fit for ePBT (I hope)
« Last Edit: Wed, 06 October 2021, 14:10:46 by Chuttau »
Offline Chuttau
  • Formerly botallu
« Reply #34 on: Wed, 06 October 2021, 14:08:36 »
Signature for Yukihana is also available, please feel free to use it to show support to the set!
Code: [Select]
Offline chung
« Reply #35 on: Fri, 08 October 2021, 12:34:39 »
nice blue object
Offline Swim To Central
« Reply #36 on: Sun, 10 October 2021, 10:15:25 »
nice.
Offline kychiii
« Reply #37 on: Tue, 12 October 2021, 03:51:53 »
More weeb sets please
Need Suisei set
Offline WilsonWan
« Reply #38 on: Wed, 13 October 2021, 04:30:25 »
perfect kit with Lamy TKL
Offline Vorge
« Reply #39 on: Wed, 13 October 2021, 11:01:11 »
Need Suisei set
There was KAT Comet, GB ended in November last year if I remember correctly. Extras are always an option, you just have to be quick in buying them.
Offline kychiii
« Reply #40 on: Thu, 14 October 2021, 03:39:47 »
Need Suisei set
i pray to gacha gods
Offline Dotnick
« Reply #41 on: Thu, 14 October 2021, 04:38:45 »
Is it possible to add accent arrow keys in somewhere?
Offline vishydesigns
« Reply #42 on: Fri, 15 October 2021, 09:53:58 »
40s could be a lot better especially since its epbt, look at kavala or acadia(kavala without the extra gradient support keys) for inspiration looks pretty good otherwise
Offline Chuttau
  • Formerly botallu
« Reply #43 on: Sat, 16 October 2021, 06:00:41 »
demand doesnt seems really high for that but I will see where I can shove them in.
Offline The0rigina1
  • fumoposting
« Reply #44 on: Sat, 16 October 2021, 12:58:30 »
Very nice self plug bro, I love self promotion in other people's IC threads
Offline kylekwong1
« Reply #45 on: Thu, 28 October 2021, 23:54:29 »
Yen on bar looks bad
Offline JohnYYZ
  • KanataKeys.co
« Reply #46 on: Fri, 29 October 2021, 01:08:51 »
Really like the novelties on this one!! GLWIC
Offline Chuttau
  • Formerly botallu
Re: [IC] ePBT Yukihana | GB Date 11th Dec | HIBI Collab
« Reply #47 on: Sat, 30 October 2021, 10:44:03 »
Updated post with GB Date, Collab with HIBI.MX and Melonkeys
Offline hali
  • OHHHH MY GODDDDDD
    • hali.studio
« Reply #48 on: Sat, 30 October 2021, 11:31:31 »
are you still not confident in the 40s kit? you should probably join a discord about that
Offline TaleOfABunny
« Reply #49 on: Sat, 30 October 2021, 12:07:12 »
Gb on my birthday? Count me the **** in
Sent from my Pixel 4a using Tapatalk
