Author Topic: [GB] Coarse60 - Alu Leaf-Spring Alice for $210 | LIVE NOW  (Read 10311 times)
Offline seh0nk
    • tech advantage blog
« on: Mon, 04 October 2021, 03:26:59 »
COARSE 60%
276835-0
by sehonky + Keebsforall
A $210 Alice 60% with a premium experience.
Leaf-Spring Mounting (that actually works)!
A bouncy and energetic typing experience combined with a crisp, sound (without needing foam) is one of my favorite things about this board.
Flex demonstration: https://www.twitch.tv/videos/1158988347?t=01h31m02s
Typing Test: https://www.twitch.tv/videos/1158988347?t=01h45m09s
Aluminum Shell
Providing noticeable weight and premium feeling. Finished with a beautiful electrophoresis coating of white, navy, or black. (price is not raised from what it would be with anodization)
276837-1
Multi-Layout Hotswap PCB + RGB Underglow
The PCB with the Coarse60 supports all alice positions with hotswap except split backspace (solder support), as well as full backspace, full right shift, both left spacebar positions, and stepped and normal caps lock with no interference (tested by Andy V Nguyen). It also has a row of downwards-facing RGB LEDs that will illuminate the frosted acrylic bottom.
276839-2
276841-3
Note: the final production PCB has top USB port.
QMK Support, VIA Support pending (will def be ready by the time you receive your board)
Photos and Renders
Photos by sehonky, renders by Pwade
276857-4
276859-5
276855-6
276849-7
276851-8
276853-9
276847-10
GB Details
Vendors
US: Keebsforall: https://keebsforall.com/collections/group-buys-and-pre-orders/products/coarse60
Canada: Ashkeebs: https://www.ashkeebs.com/product/coarse60-keyboard/
UK: Keebcats: https://keebcats.co.uk/products/coarse60-keyboard
EU: Keygem: https://keygem.store/collections/group-buys/products/group-buy-coarse60
OCE: DailyClack: https://dailyclack.com/collections/keyboards/products/coarse60-keyboard-kit
SEA: ZionStudios.PH: https://zionstudios.ph/product/groupbuy-coarse-60/
What's in the box?
 - Aluminum Shell
 - Acrylic Panel
 - Plate (POM or Alu)
 - Mounting hardware
 - PCB
 - O-rings + extras
 - Rubber bumpons
 - Small foam sticker for PCB (preventing bottom-out)
Extras Available
 - Plate Foam
 - Extra Case
 - Extra PCB
 - Extra Plate (POM or Aluminum)
Specifications
Front Height: ~20.5mm
Typing Angle: 6.9 degrees
Weight (fully built): 1.2kg or 2.65lb
Required beyond kit: 4-6 2u stabilizers (depending on your layout), your choice of ~70 switches, and compatible keycaps.
Pricing
Kit: $210
Case Only: $120
Plate Only: $24 (alu and POM)
PCB Only: $70
Delivery: Q2 2022
Note About Plates
If you want flex, go for aluminum. That is the only option with leaf-springs. POM is too flexible inherently, and not only can it not support leaf-springs, but requires extra mounting points. POM would be more desired for its sound. Neither plates are hollow sounding in our tested configurations (JWK linears or tactiles).
ALU PLATE
276845-11
Middle mounting holes (circled in red) are optional, leaf-springs and acoustic cut.
POM PLATE
276861-12
No leaf-springs or acoustic cuts, middle mounting holes required.
Concerns?
There was a concern that Andy V Nguyen brought up about bottoming out when typing roughly. We brought the keyboard's height up by an mm, shortened the leafsprings slightly, and are adding a foam sticker to the bottom of the PCB to address this concern. We'll keep you updated!
Remarks
Locked IC post: https://geekhack.org/index.php?topic=112218.msg3036171#msg3036171
Big Thanks to:
Cansu at keebsforall.com
Rhuk.Tech for file review
pwade for great renders
Everyone in the Keebsforall discord server - support! https://discord.gg/dRjsAh5jMX
other designers who have inspired me
Friends/family
I hope you consider this board, I designed it myself and really do believe it is the best you can do with $210.
Have a good day.
-sehonky
« Last Edit: Tue, 05 October 2021, 20:02:08 by seh0nk »
Offline seh0nk
Re: [GB] Coarse60 - Alu Leaf-Spring Alice for $210
« Reply #1 on: Mon, 04 October 2021, 10:07:32 »
Reserved
Offline FallenCow
« Reply #2 on: Mon, 04 October 2021, 22:38:27 »
Keyboard looks great! Point of clarification- does the PCB support split backspace? It looks like it did, but your description says "except". Probably a typo, but wanted to double-check.
Offline seh0nk
« Reply #3 on: Tue, 05 October 2021, 00:36:38 »
Hey! Sorry that was badly worded. It supports split backspace, but only with solder.
-sehonky
Offline Gvalch_ca
Re: [GB] Coarse60 - Alu Leaf-Spring Alice for $210 | LIVE NOW
« Reply #4 on: Tue, 05 October 2021, 14:18:26 »
Will plate files be posted in the future? I am interested because US vendor offers case only for 120 usd, which is a great deal for building an Alps alice-style board (I don't need to waste 70$ on MX PCB and 25$ on MX plate).
Lead Keyboard Cringeneer.
Alps and Space Invaders enthusiast.
Offline seh0nk
« Reply #5 on: Thu, 21 October 2021, 03:09:12 »
Probably, but not until after the groupbuy has been concluded.
-sehonky
Offline seh0nk
« Reply #6 on: Sun, 14 November 2021, 23:18:45 »
Hi All,
some were concerned about the bottoming out issues mentioned in Andy's video, but these have been fixed in the new prototype! Here is a sound test:
-sehonky
Offline whyjay03
« Reply #7 on: Sun, 06 March 2022, 05:08:12 »
I'm curious as to the exact width of the keyboard. (thinking wrist rest...)
