Author Topic: [IC] Kamo60 ( 鴨 60) Top-Mount 60% Keyboard (Updated price)  (Read 16748 times)
Offline wandering_duc
« on: Mon, 04 October 2021, 06:46:38 »
Kamo60
A 60% top mount
New IC-form: https://forms.gle/dssuNoC7nKHoL9Ff7
IC form: https://forms.gle/m8TxC7y8hgRnxaRt9
Update 5:
Possibility of a price drop to 150USD if there is enough interest. MOQ is 50 for this price.
Update 4:
The Kamo60 will be compatible with all universal 60% PCBs. (hot-swap PCB not recomended as the plates are multi-layout)
Plate files will be made public after GB.
Weight will be roughly 1kg without PCB.
Update 3:
Updated price. New price will be 250 USD.
Update 2:
Got quote from manufacturer. Price will be 350 USD with projected order quantity of 20 units. Price still subject to change depending on interest.
Update 1:
Revised placement for mounting tabs.
The Kamo60 is a top mount 60% keyboard with burger-mount compatibility.
Being a car enthusiast I wanted to incorporate some design traits from one of my favorite european sedans, the 1995 BMW M5 Touring.
With that being said I present to you...
The Kamo60
276864-0
276997-1
276999-2
276870-3
276973-4
276975-5
276872-6
276874-7
As mentioned, the design is inspired by the 1995 BMW M5 Touring. With its sharp angles and sleek wagon shape, it is truly a beautiful car.
I tried to incorporate the sloped rear windscreen and the aggressive stance of the car into the bottom rear design of the Kamo60.
Specs:
Plate material: Aluminium, Brass, Polycarbonate
Colors: Blue, Pink, Grayish, Black
Mounting style: Top-mount with burger-mount compatibility
Layout: ANSI, ISO, split backspace, split right shift, stepped CAPS
Bottom row: 6.25U and 7U
Typing angle: 7 degrees
PCB: TBD, but currently compatible with WT-60D and WT-60C from wilba.tech
GB details:
GB date: TBD
Price: 250 USD (still subject to change)
Vendors: TBD
To do list:
Review results from 1st IC-form
Contact vendors
Review results from 2nd IC-form
Order 1st prototype
Designed in Norway
« Last Edit: Fri, 08 October 2021, 11:26:38 by wandering_duc »
Offline The0rigina1
  • fumoposting
Re: [IC] Kamo60 ( 鴨 60) Top-Mount 60% Keyboard
« Reply #1 on: Mon, 04 October 2021, 08:07:49 »
If this is below maybe 250 I'm all for it
Offline Rafa_n
  • stuffforrectangles.etsy.com
« Reply #2 on: Mon, 04 October 2021, 08:30:58 »
you shouldn't have a mounting point right under the spacebar
« Reply #3 on: Mon, 04 October 2021, 08:45:38 »
Thank you for the feedback, I will change the mounting placement before ordering prototypes.
« Reply #4 on: Mon, 04 October 2021, 08:46:52 »
I'm still waiting on a quote from the manufacturer, but price will also depend on interest.
Offline Neptune Keys
« Reply #5 on: Mon, 04 October 2021, 09:09:44 »
Looks a little similar to mode65.
« Reply #6 on: Mon, 04 October 2021, 09:47:55 »
Yes, I was kinda worried about that, but some of the key differences are the chamfers and of course the 60% layout. But I see where you're coming from.
It's also kinda hard to differentiate one self while still keeping a sleek design language since there are so many keyboards out now.
Edit:
As of now I'm also trying to keep the cost down, and adding more design features would raise the machining cost.
« Last Edit: Mon, 04 October 2021, 10:16:50 by wandering_duc »
Offline eddieboyemo
« Reply #7 on: Mon, 04 October 2021, 10:18:46 »
looks alright if its around 250, ne wkl avail?
« Reply #8 on: Mon, 04 October 2021, 10:32:21 »
I was considering adding WKL and HHKB as an option, but that would increase the manufacturing cost slightly. I will update the IC-form, and if there is any interest for it I might add it as an option.
Offline The0rigina1
  • fumoposting
« Reply #9 on: Mon, 04 October 2021, 12:41:56 »
Edit:
Don't mind too much about visual similarities. Focus on feel, make it feel better than the mode65  :thumb:
Offline unusuaL_
« Reply #10 on: Mon, 04 October 2021, 14:46:15 »
nice side profile and back. slightly scuffed formatting?
collection: hibike 1/1, garderie tkl, casper60, hhkb pro2, matrix 2.0additional, f1-8x og
« Reply #11 on: Tue, 05 October 2021, 05:53:18 »
Fixed ;)
Offline Dyto69
  • 420 blaze it but dont forget 69
« Reply #12 on: Tue, 05 October 2021, 06:06:35 »
The only thing that will make this interesting is the Price, it looks like every generic I just learned Fusion360 Keyboard. Good luck with IC
« Reply #13 on: Tue, 05 October 2021, 08:25:02 »
I totally agree with the design being generic, but since this is my first IC I didn’t want to make a $500+ keyboard with more intricate and interesting design features. However if this IC goes through and the GB goes well, I might end up trying to get some of my other designs to GB too.
Offline TheNeonKnight
Re: [IC] Kamo60 ( 鴨 60) Top-Mount 60% Keyboard (Updated price)
« Reply #14 on: Mon, 08 November 2021, 09:06:38 »
I can appreciate the more "generic" look, keeps the costs down while still being a top mount/well made. Not many 60% that aren't tray mount at this price point.
Offline 77kyl
« Reply #15 on: Wed, 10 November 2021, 16:40:07 »
wkl plz
Offline nick779
« Reply #16 on: Mon, 22 November 2021, 11:58:12 »
Update 5:
At this price point I can't imagine not hitting MOQ if this runs late Q1 or Q2 2022. I wish we had more colors though, a nice forest or even olive drab green and/or purple. I'm in for one or two if shipping doesn't kill me and pcb compatibility is good.
Offline The0rigina1
  • fumoposting
« Reply #17 on: Mon, 29 November 2021, 09:15:28 »
Update 5:
That's a pretty decent price. You should order a prototype to test your design after interests has been gathered.
Offline noorejji
« Reply #18 on: Tue, 30 November 2021, 04:51:58 »
Interested. What type of aluminium? What kind of manu are you in talks with?
Offline stidal
  • milo#3939
« Reply #19 on: Tue, 30 November 2021, 04:59:42 »
at 150, this would be a solid buy. the world needs more entry level top mounts
transition tkl // aksara ce // bully // valhalla // voyager // rs60 // adiuvare // ciel60 // jules // prime e // ut47.2 // sequence // bumper // q1 // gaff60
Offline Tweec
« Reply #20 on: Tue, 30 November 2021, 05:20:02 »
$150 would be  great for this entry-level board, definitely interested :thumb:
Offline duanekurt
« Reply #21 on: Wed, 01 December 2021, 12:26:31 »
reserved
Offline Neely_12
« Reply #22 on: Wed, 01 December 2021, 12:30:36 »
What alu will this use?
Offline angelmoder
« Reply #23 on: Tue, 25 January 2022, 10:36:18 »
i really hope to see hotswap compatibility, new to the hobby and i'd be scared lf screwing up a more expensive solder pcb
Offline ___LUNK
« Reply #24 on: Tue, 25 January 2022, 11:26:36 »
Why does an "inspired by bmw M5" keyboard have a random Japanese word as a name
Offline Keeblet_257
« Reply #25 on: Wed, 26 January 2022, 14:15:48 »
yeah if price changes to the 150-170 range you will for sure have my interest, however the option to order maybe HHKB and/or WKL layout seperately if offered while offering a PCB which supports all layouts (WK, HHKB (if offered) and WKL (if offered) would be a guaranteed buy from me.
having the option to try HHKB and WKL  without needing to pay 400+ is a big plus if it happens
Offline DaaDaa
« Reply #26 on: Wed, 26 January 2022, 14:25:40 »
IC submitted. 150 es bueno
piggy60 red upgraded PVD w/ GMK umka zaku | tiramisuit w/ GMK noire JWK silk emerald | mr.suit black/chrome glossy chamfers w/ GMK minimal cow POM stem | jelly epoch w/ SA oblivion zaku | mode80 deco w/ gmk boneyard alpaca | mode 80 imperial with ePBT origami alpaca| MODE80 viridian /w CRP boba LT | RAMA thermal kuro w/ GMK muted 2 pewter | BBox60 C64 wih marshmellows and c64 keycaps | MODE Sonnet green /w MW voynich gateron ink box pink
Offline Keeblet_257
« Reply #27 on: Thu, 27 January 2022, 10:22:10 »
yeah if price changes to the 150-170 range you will for sure have my interest, however the option to order maybe HHKB and/or WKL layout top piece seperately if offered while offering a PCB which supports all layouts (WK, HHKB (if offered) and WKL (if offered) would be a guaranteed buy from me.
Offline DJ Clicks
« Reply #28 on: Fri, 28 January 2022, 01:08:49 »
Agreed with the previous posts, WKL and hotswap pcb would be great. You could possibly make a multi layout plate and a WKL/hhkb/tsangan plate like Vega. Proto sound tests would also help a lot
