Author Topic: [IC] GMK Hooty (Live Nov 1st)  (Read 34840 times)
Offline SDKCAMPING
Re: [IC] GMK Hooty
« Reply #50 on: Wed, 06 October 2021, 19:43:30 »
I'm a fan!
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline Kinesiologist
Re: [IC] GMK Hooty
« Reply #51 on: Wed, 06 October 2021, 20:55:27 »
very hoot set
Offline totalemon
  • good morning :)
Re: [IC] GMK Hooty
« Reply #52 on: Wed, 06 October 2021, 23:44:32 »
Unique and subtle, I like it!
Offline tngpq
Re: [IC] GMK Hooty
« Reply #53 on: Thu, 07 October 2021, 00:04:06 »
Looks great! Love the grey and pink combo. Also, I like how you didn't add the ㅃ ㅉ ㄸ ㄲ ㅆ ㅒ ㅖ sub legends for the hangul. It looks cleaner! Honestly we don't even need them there anyways. It's implied lol
Absolutely. You don't need double consonants.
Offline Winther
Re: [IC] GMK Hooty
« Reply #54 on: Thu, 07 October 2021, 04:21:59 »
What about a norDE/EU set?
Sendt fra min SM-A528B med Tapatalk
Offline Stilou Studio
  • Formerly Seo
  • Danish Designed Keyboards
Re: [IC] GMK Hooty
« Reply #55 on: Thu, 07 October 2021, 05:11:43 »
Looks very good
GLWIC!
Offline HappyB0T
  • I'm a Piggie
Re: [IC] GMK Hooty
« Reply #56 on: Thu, 07 October 2021, 10:49:54 »
I quite like the kitting. Hooty.
Offline SmilingCurse
    • Twitch Channel
Re: [IC] GMK Hooty
« Reply #57 on: Thu, 07 October 2021, 17:49:26 »
i love this so much... omg the grey colour, the pink, the owls, the moon and stars. i am in loveeee
Offline sourmk
Re: [IC] GMK Hooty
« Reply #58 on: Fri, 08 October 2021, 10:46:39 »
Hi all, wanted to thank everyone for the lovely feedback, I'm quite excited about this project and it's very nice to see you all might be as well! <3
Here are some thoughts after going through feedback from here and reddit.
Extra B in base - doesn't make sense to add to spacebar / expansion kit as the only key with UV. (Will remain in base.)
Pink on grey (legend accents) will be moved to accent kit - Grey on pink accent caps (Esc + Enters + Arrows) will be moved to base kit
Hangul - to be corrected and updated. Will be adding missing legends / consonants.
1.75U enter - supposed to be 1.5U (to be corrected and updated)
Thinking about cutting the current expansion kit, and moving a few of the keys into base. 3 key 40's, 2.25u shift, F13.
Spacebars will not be added to base, because I worry about pricing. Spacebar only kit will be added including 6.25U / 7U accent bars. (Maybe split pink bars as well - depending on quotes)
1U Alt Gr in base and accent kit to be replaced with Alt
Let me know what you all think.
Cheers!
Some Work: GMK Wasabi | GMK Pono | GMK Dandy | ePBT DuO | GMK Hooty | Petals Sixty
Some Collabs: ePBT Ivory | GMK Deep Navy | GMK Fundamentals | GMK Polybius | GMK Blurple | GMK Deepwell | GMK Fuji | GMK Pacific
Some Boards: Daji Seis Cinco, Ocho Quattro, Seis Cero | MatrixLab 2.0 ADD + CP, 2.0 Xmas + CP, 1.2OG | Keycult 1/60 | Hiney Ladybird | QXP | Noxary 268.2
Discord - https://discord.gg/j3PxfJ4rBC | Instagram - https://instagram.com/sourmk | Web - https://www.sourmk.com/
Offline XiXora
Re: [IC] GMK Hooty
« Reply #59 on: Fri, 08 October 2021, 11:52:56 »
Would cutting the Ext kit mean that the set would lose the 1.5U Supers? It just needed an extra 1u alt to make those useful in that kit. Sad times.
Offline Ooga Booga
Re: [IC] GMK Hooty
« Reply #60 on: Fri, 08 October 2021, 13:31:46 »
Please don't move the pink on grey legend accents out of the base kit, it looks too good
Offline CookieFlow
Re: [IC] GMK Hooty
« Reply #61 on: Fri, 08 October 2021, 13:56:53 »
Agreed.
The pink on grey looks so good.
The current Hootcents Grey on Pink kit makes sense the way it is. Not sure why you would move some of those keys to the base kit.
Does that mean the Pink on Grey Esc/Enter/Arrows will be move to the Hootcents kit or a separate accent kit? (either way personally not a big fan of that change).
Even though I would prefer Alice support in Base as I feel there are more Alice users than 40% users, a dedicated spacebars Kit is still a better option than the massive Hootspansion kit.
« Last Edit: Fri, 08 October 2021, 15:41:42 by CookieFlow »
Offline kuromi
  • kuromi is typing...
Re: [IC] GMK Hooty
« Reply #62 on: Fri, 08 October 2021, 18:28:32 »
are there gonna be any keycap collabs for this?
Offline syxwsh
Re: [IC] GMK Hooty
« Reply #63 on: Sat, 09 October 2021, 11:55:10 »
looks really good  :cool:
Offline bkrownd
Re: [IC] GMK Hooty
« Reply #64 on: Mon, 11 October 2021, 03:29:31 »
This is so hooting cute.  I've sworn not to buy any more GMK sets tho....   :rolleyes:
Offline baka jiken
Re: [IC] GMK Hooty
« Reply #65 on: Mon, 11 October 2021, 03:31:42 »
Hooting awesome. Hooting cute :-*
Offline sourmk
Re: [IC] GMK Hooty
« Reply #66 on: Wed, 13 October 2021, 11:00:24 »
Hello! Some updates and news
Base and expansion kits have seen some tweaks and changes.
Base now has F13 instead of B.
Expansion kit has been made quite a bit smaller, now features extra B and accent 6.25U + 7U spacebars
Hibi collab reveal!!
Deskmat samples came in. Mostly pretty happy with Sleepytime Hoot. Hootweave will for sure be getting a second sample as things move forward.
Cheers!
Offline spacecables
    • Space Cables
Re: [IC] GMK Hooty
« Reply #67 on: Wed, 13 October 2021, 11:39:56 »
Cheers!
HIBI HYPE!
Offline Ciantha
Re: [IC] GMK Hooty (Kit updates & HIBI Collab!)
« Reply #68 on: Wed, 13 October 2021, 11:51:35 »
The TMO render seems to be using an enter key that doesn't exist.
Offline CookieFlow
Re: [IC] GMK Hooty
« Reply #69 on: Wed, 13 October 2021, 13:41:34 »
Cheers!
Really liking the changes, I hope the kits stay that way :thumb:
And the Hibi collab is awesome
Offline baka jiken
« Reply #70 on: Thu, 14 October 2021, 16:40:48 »
That owl is hoot :))
Offline bkrownd
« Reply #71 on: Thu, 14 October 2021, 18:22:19 »
  I think the "enter" key in the novelty set should say "hooter"
Offline mikestah
« Reply #72 on: Thu, 14 October 2021, 22:01:19 »
That hootwave deskmat hurts my eyes... count me in!
Offline Winther
« Reply #73 on: Fri, 15 October 2021, 00:36:03 »
I havent been around for long, so forgive me if it's a dumb question, but is there any chance a kit like this will have a norde/EU kit added before a GB..?
Offline vishydesigns
« Reply #74 on: Fri, 15 October 2021, 09:45:21 »
no pink accents in base? disappointing, will be expensive to get accents and base, especially since its gmk and base and accents are both pretty chonk, good work on the set tho
Offline sup3r170va
« Reply #75 on: Fri, 15 October 2021, 10:30:26 »
i second pink accents in base!
Offline krugerlive
« Reply #76 on: Fri, 15 October 2021, 12:03:33 »
Love those Hibi caps!  Such a cute owl.
Offline CookieFlow
« Reply #77 on: Fri, 15 October 2021, 21:21:18 »
There is a pink accent in the Novelties kit also, it's not just in the Hootcents kit.
Offline bert039
« Reply #78 on: Sat, 16 October 2021, 11:30:05 »
Hootie hoo! Love this set!
Offline Synergist
« Reply #79 on: Mon, 18 October 2021, 12:35:51 »
I would die for Hooty.
Offline sourmk
« Reply #80 on: Thu, 21 October 2021, 14:06:37 »
OP has been updated with USD pricing.
Hoping to have another super cool announcement for this GB very soon! Cheers!
Offline sourmk
Re: [IC] GMK Hooty (Live Nov 1st)
« Reply #81 on: Sun, 24 October 2021, 10:11:05 »
Big announcement! :cool:
Gateron Hooties - Nylon tops and bottoms - POM stem
