Author Topic: Edge65: Customizable and Magnetic  (Read 3747 times)
Offline koopatroopa
« on: Tue, 12 October 2021, 18:35:31 »
The Edge65 is a keyboard that can be customized in the way of material and finish. Some sample materials could include aluminum, brass, titanium, and copper. Sadly, polycarbonate/other plastics will have to be excluded due to required changes to the design and machining limitations. It will also include toolless magnetic access to the poron gasket-mounted plate, available in brass, aluminum, titanium, copper, and magnesium (with reduced flex cuts). It has been designed with the DZ65RGB V3 in mind, although any standard 65% PCB should work well. There are no prices yet available, but I hope to get quotes for manufacturing and materials soon. This design is also not finalized and is subject to change.
Gallery of Sample Options:
277211-0
277213-1
277217-2
277215-3
