Author Topic: Edge65: Customizable and Magnetic - Looking for feedback  (Read 3428 times)
Offline koopatroopa
« on: Tue, 12 October 2021, 19:53:27 »
The Edge65 is a keyboard that can be customized in the way of material and finish. Some sample materials could include aluminum, brass, titanium, and copper. Sadly, polycarbonate/other plastics will have to be excluded due to required changes to the design and machining limitations. It will also include toolless magnetic access to the poron gasket-mounted plate, available in brass, aluminum, titanium, copper, and magnesium (with reduced flex cuts). It has been designed with the DZ65RGB V3 in mind, although any standard 65% PCB should work well. There are no prices yet available, but I hope to get quotes for manufacturing and materials soon. This design is also not finalized and is subject to change. Any feedback or suggestions are greatly appreciated in this beginning stage of design. Thank you!
Gallery of Sample Options:
277227-0
277229-1
277231-2
277233-3
Please note that the colors of the metals in render form may not be exact and need some work, but for now this is all I have.
« Last Edit: Tue, 12 October 2021, 19:55:23 by koopatroopa »
