Author Topic: Ducky VS Filco  (Read 16721 times)
Offline Kira
  • <3 <3 <3 <3
Ducky VS Filco
« on: Thu, 02 September 2010, 15:30:10 »
Hey guys, I'm pretty new  on this forum. I've been doing a LOT of research on mechanical keyboards trying to decide which would be the best for me. I game just as much as I type so no doubt I went with the Cherry MX Brown switches over the Blues which I hear have trouble with double and triple taps. Since I play a lot of UT3, this would not be ideal.
Anyways, I purchased a Majestouch Tactile Touch "Otaku" NKRO and will be receiving the keyboard this Saturday.
But then I came across these "Ducky" keyboards which apparently have much better keycaps than Filco's which I hear start to shine after only a month of use. But what really drew me towards the Ducky keyboard was the fact that it has a detachable cable which means if the cable ever breaks, I can always replace it with a new one. And if I am to use a keyboard for 5+ years, the Ducky would definitely be more durable. It's also much cheaper than the Filco keyboard.
The Filco costs 120-134 while the Ducky 'tenkeyless' costs only 87 dollars. But now the real problem is getting it into the states! I dunno how much shipping would cost from China but that would probably bring the price even.
I'd like to know what you guys think about these two keyboards. Should I just wait for my Filco? Maybe even "mod" it so it too could have a detachable cable, or should I cancel my order and get the Ducky keyboard (which I probably won't have for another 2 weeks).
I'm really anxious to try out a mechanical keyboard! Right now I type 90WPM on a Razer Tarantula. I already feel like I'm being held back by the rubber domes so I should see the benefits of a mechanical keyboard.
Here's the link to the Ducky keyboard that I'm planning on getting.
http://babelfish.yahoo.com/translate_url?doit=done&tt=url&intl=1&fr=bf-res&trurl=http%3A%2F%2Fitem.taobao.com%2Fitem.htm%3Fid%3D7284573558&lp=zh_en&btnTrUrl=Translate
Anyone know what kind of switches this keyboard uses?
Offline Phaedrus2129
Ducky VS Filco
« Reply #1 on: Thu, 02 September 2010, 15:31:40 »
I did research on this too. I'd prefer the Ducky over a Filco, but expect shipping to push it north of $150.
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline washuai
    • http://home.earthlink.net/~haruai/
Ducky VS Filco
« Reply #2 on: Thu, 02 September 2010, 15:48:40 »
Depending on the Ducky, it can come with blacks, blues, or browns.  Yea, buying service, returns issues, etc. - I'd stay stick with the Filco.  It'll cost you less overall and be more supported.
⌨(home)Realforce 87U ⌨(backup) Filco Majestouch 104 Brown ⌨(backup)Cherry G80-8200LPDUS ⌨(work)Leopold FC200RT/AB
☛CST L-Trac-X ☛Logitech Wireless Optical Trackman ☛ Razer 3500 dpi ☛MS Explorer DeathAdder
Lay-a-bouts:  ⌨Full 109 Key Virtually Indestructable  Keyboard ⌨Compaq Radio Quack GYUR84SK
Wishlist: ⌨KBDmania Pure ⌨Déck 82 ice/frost/toxic/royal ⌨Ricercar spos G86-62410EUAGSA ☠ ✞⌨miniGuru(s) ☠
 ✐Intuos or Cintiq
Ducky VS Filco
« Reply #3 on: Thu, 02 September 2010, 15:52:48 »
Cables are easy enough to replace if you have to.
Personally, I'm more interested in that HHKB-like thing with cherries that we've only seen pictures of so far.
Current collection: HHKB Pro 2 black on black, HHKB Pro 2 white/grey blank, [strike]Dell AT101W[/strike] (sold to SirClickAlot), 1992 Model M, Key Tronic Ergoforce KT 2001, BTC 5100 C. Dead boards: MS Natural Elite, MS Natural 4000.
Offline WhiteRice
Ducky VS Filco
« Reply #4 on: Thu, 02 September 2010, 15:55:16 »
We should get in touch with deal extreme and see if they can get keycaps
Offline Kira
  • <3 <3 <3 <3
Ducky VS Filco
« Reply #5 on: Thu, 02 September 2010, 16:00:00 »
Thanks for the quick reply guys =)
I think I'll stick with the Filco then and maybe order some keycaps in the future.
Quote from: Superfluous Parentheses;219295
Cables are easy to replace on the filco? I guess taking it apart won't be much of a hassle but I'm a nub when it comes to keyboard internals.
Let's say my cable did break somehow (which probably won't happen), how would I replace it?
« Last Edit: Thu, 02 September 2010, 16:03:02 by Kira »
Offline Kira
  • <3 <3 <3 <3
Ducky VS Filco
« Reply #6 on: Thu, 02 September 2010, 16:22:41 »
Here are some pictures of the Ducky Keyboard...
The main reason I want this keyboard.
Now I'm having doubts xD That is one good looking keyboard!
Ducky VS Filco
« Reply #7 on: Thu, 02 September 2010, 16:43:25 »
Quote from: Kira;219301
I'm not familiar with filco internals, but at a guess, they probably use some kind of cheap standard connectors to fix the cable to the PCB, or solder it down directly. In either case, you can fairly easily get a new cable and solder it back onto the PCB or solder/whatever it to a compatible connector, or just spice a new cable internally to the old one, [or get a new cable that includes the connector, but that would probably require some searching].
Sure, it's not as easy as getting a new mini-usb cable, but it shouldn't be hard to do, and basic soldering irons are cheap.
Offline Kira
  • <3 <3 <3 <3
Ducky VS Filco
« Reply #8 on: Thu, 02 September 2010, 16:55:02 »
Quote from: Superfluous Parentheses;219309
I wish I knew how to solder xD I'm sure I can get it done but it would be pretty messy. Now imagine if I could fit a USB-MINI USB converter right inside the keyboard so that it would work just like the Ducky keyboards!
Ducky VS Filco
« Reply #9 on: Thu, 02 September 2010, 17:25:40 »
Quote from: Kira;219311
AFAIK, a mini usb connector is just a smaller connector for the exact same signal, so you can probably do that (though I thought Filcos are actually PS/2, I'm not sure - if they are, it's certainly possible to put a PS/2 bus in there). I'd guess modifying the case and providing a stable fitting for the connector are going to be more work than just soldering, whatever the connector is.
« Last Edit: Thu, 02 September 2010, 17:28:13 by Superfluous Parentheses »
Offline jnsjr
Ducky VS Filco
« Reply #10 on: Thu, 02 September 2010, 22:22:40 »
@ripster - I lol'd at the rubber ducky. great pic.
@kira - thanks for all the great ducky pics.  i'm in a similar situation to you, and will probably break down and get a filco as well. let us know your impressions of the filco when you can!
Current Keyboards
Unicomp Space Saver (white) ~ HHKB2 ~ White Filco Red Cherry Limited Edition (Imsto Grey on White PBT + Group 3 keys + Awry keys)  ~ Realforce 87U 45g + Realforce 87U Variable + Realforce Numpad :biggrin1:+ MJ2 White Blue Cherry 87key
Keycaps
ClickClack Red Eye Skull *(2)* *(3)* *(4)*~ Black Eye Skull *(2)* *(3)* ~ Closeup ~  Topre WASD (Thanks Yak & DB!)
WTT & WTS
WTS White Filco Red Cherry Limited Edition (still deciding!)
Sold ~ Filco Blue Cherry; Majestouch 104 nonprinted keycaps; Noppoo Choco Mini 茶轴 (brown switches);  Topre 87u Variable ; Topre 87u 55g ; MY7000 Doubleshots ; Round 1 Doubleshots
[/FONT]
[SIGPIC][/SIGPIC]
woody
  •  Guest
Ducky VS Filco
« Reply #11 on: Fri, 03 September 2010, 05:53:32 »
Ducky seems to suffer from mold nubs on the keycaps.
I'd stay away from mini/micro-USB connectors, but that is more of a personal grudge.
But the OP touched an important question - is there source for non-shiny keycaps for the Filco/MX blue? Just want to know what backup solutions are there.
________
medical marijuana card
« Last Edit: Sat, 05 February 2011, 13:33:06 by woody »
Offline MissileMike
Ducky VS Filco
« Reply #12 on: Fri, 03 September 2010, 08:08:33 »
You could search ebay for a cherry board with lasered keycaps.  You should be able to pick one up for around 30$.  Looking at them right now, the filco caps seem a bit taller, though.  Has anyone tried this?
I have had my filcos for a couple weeks now, and no shining so far.
As for the Ducky, it's probably just a matter of time before they show up here in the states.
BS: 5 Space Savers  ||  9 42H  ||  10 1391401 or similar  ||  1x 1390131  || AT&T 305b  ||  Dell Model M
Cherry: Leopold FC200RC/AB  ||  3 Ducky 1087  ||  PLU ML87 ||  Cherry G80-8113LUVEU-2  browns
Alps: Filco Zero Tenkeyless (fukka)  ||  ABS M1  ||  3x Dell AT101w  ||  Ancer KF-191  ||  6 Vivanco Compact
Misc: NMB RT6855T+  ||  NMB RT101 Space Invader  ||  Dell Quietkey  ||  Ge Fanuc Industrial Metal
Offline WhiteRice
Ducky VS Filco
« Reply #13 on: Fri, 03 September 2010, 08:15:34 »
You know where I think there is a market? DIY keyboard kits. Order a bunch of cases, pcbs, keyswitches and caps. Let people pick and choose what they want.
For instance, "I want a red tenkeyless, so I get a red case and pcb, pick the switches I want, keycaps too."
Send it in pieces let the person solder it together, or for a premium build it and send it.
Offline pang0011
Ducky VS Filco
« Reply #14 on: Fri, 03 September 2010, 23:04:36 »
Quote from: MissileMike;219502
Cherry 2-shot keycaps and Filco's are compatible despite the difference in height, in my case I could replace all keycaps of my Filco with Cherries except the CapsLock key.
Quote from: ripster;219522
You mean like the squirrelly KBTalking keyboards?  Actually those never did appear here.
Distribution remains a big problem for the more exotic keyboards, even in the age of globalization.
Honestly, for those MIC/MIT keyboards I would always suggest waiting for reviews to see the comments first before you actually consider buying them.  I don't mean to say there are problems with these keyboards, in fact I will buy one anyway, but this is just a personal suggestion to our American friends.
They remind me of my exams when I was a student, we called them "necessary evil" : P
« Last Edit: Fri, 03 September 2010, 23:14:53 by pang0011 »
Offline Kira
  • <3 <3 <3 <3
Ducky VS Filco
« Reply #15 on: Sat, 04 September 2010, 00:37:43 »
Quote from: jnsjr;219399
Good to know I'm not the only one =) I'm getting it tomorrow, can't wait! Only thing bothering me right now is the key caps but we'll see how the keys turn out after a good 2-3 weeks of use.
Quote from: pang0011;219756
That's exactly what I want to do once I get the Filco. Just curious as to what Cherry board you purchased. Looking around in the forums I believe ripster had a thread up on replacing the Filco keyboard with Cherry key caps but I recall him needing to use more than one board for all the keys.
BTW, that keyboard looks AMAZING!!
« Last Edit: Sat, 04 September 2010, 00:41:27 by Kira »
Offline pang0011
Ducky VS Filco
« Reply #16 on: Sat, 04 September 2010, 01:20:11 »
Quote from: Kira;219773
The keycaps are pulled out from a G80-3000, you could try searching on ebay, I believe there are more choices on ebay than where I bought mine.
Offline skartt
Ducky VS Filco
« Reply #17 on: Sat, 04 September 2010, 01:51:05 »
I bouhgt a ducky with mx black - need to check the model number in the office on monday.
(Fullsize + 4 extra keys above numblock. black with black legend.)
They seem to have some sort of keycap problem, as i got a second set of keycaps for free due to some known issues.
Offline Kira
  • <3 <3 <3 <3
Ducky VS Filco
« Reply #18 on: Sat, 04 September 2010, 04:23:56 »
Quote from: skartt;219785
Nice, make a review of the keyboard if you can =) I think that's the only thing this forum is missing, a Ducky keyboard review.
Offline pang0011
Ducky VS Filco
« Reply #19 on: Sat, 04 September 2010, 10:59:52 »
Quote from: ripster;219829
I saw a Ducky with a funky misaligned spacebar.  Might have just been the pic though.
That one is in the USA now in possession of one of the Geekhackers, I have got 2 Ducky 108, both had been shipped to North America in June already.
As told, Ducky will release a white Ducky87 very soon with various choices of keycaps, this one is what they call "apple white", I am planning to buy one, but indeed after reviews are available.
Offline pang0011
Ducky VS Filco
« Reply #20 on: Sat, 04 September 2010, 11:56:44 »
Quote from: ripster;219853
When she squeezes my Rubber Ducky it makes noise...
I think she’s just like many of us who work very hard to learn English and western cultures.  Speaking of western culture, I like Homer Simpson so much, boorish but ingenious, I’ll never feel boring with him : )
