Author Topic: CM Storm QuickFire Rapid TKL top case replacement  (Read 2868 times)
Offline estux
« on: Sat, 16 October 2021, 11:51:48 »
Hi,
years ago a bought this keyboard and it came with a rubberized top case that hasn't aged well. I don't want to sand it and paint it and I wonder if there is a replacement top that would fit this keyboard, some plastic black top would do the job. Do you know any web where I can buy it? I am in Europe, and the keyboard is a TKL.
Offline user 18
Re: CM Storm QuickFire Rapid TKL top case replacement
« Reply #1 on: Mon, 18 October 2021, 11:21:42 »
Several years ago, CM sold replacement top cases for these boards. It's possible that some of those are still floating around somewhere as old stock?
Avatar by ashdenej
Offline estux
« Reply #2 on: Mon, 18 October 2021, 16:30:58 »
Yeah I know, but I couldn't find any...
Offline Maledicted
« Reply #3 on: Tue, 19 October 2021, 10:42:54 »
I'm pretty sure that these aluminum cases on Aliexpress should work, if you want an upgrade. The LED holes just aren't used on the CM boards.
I have at least 3 of these cases, and a Quick Fire Rapid, so I could test to verify this evening.
