Author Topic: Wired Mechanical Keyboard with CNC Aluminum Case - 65% (68 Key) Gaming Keyboard  (Read 1928 times)
Offline Mech_DIY
Wired Mechanical Keyboard with CNC Aluminum Case - 65% (68 Key) Gaming Keyboard Hot-Swap Switches RGB LED Backlighting US Layout - Brown Switch Keyboard with PBT Keycaps for PC Gamer Computer
Features:
.GAMING EXPERIENCE: For a better gaming experience, we combine a stylish yet functional design with CNC machined Full Aluminum Body to bring you a versatile mechanical switch keyboard that will offer more durability. CNC aluminum case makes the whole keyboard more calm and more textured, it can handle daily use even in the long run.
.A COMPACT LAYOUT: The mechanical keyboard features 68 keys with US Layout . Absent of function keys, it wastes no space—It's made for gamers and professionals that want performance without any ghosting. It supports FULL-key rollover and features a curvature design so you can use it comfortably from any angle.
.BROWN SWITCHES MECHANICAL KEYBOARD:Each switch is with durability of 50 million times, and it compromises both tactile and low noise two supreme merits and offers you the most friendly and satisfying experience. Customize this amazing keyboard with ease thanks to hot-swappable switch sockets, which allow you to swap switches in seconds—no soldering required.
.WIDELY COMPATABILITY: Wire mechanical keyboard, stronger connect to meet the speed requirements of competitive games, support USB online update.The compact keyboard is compatible with Windows , Linux, Mac OS and other systems.
.RGB BACKLIT: Full keyboard independent RGB lighting design, 16.8 Million Color combinations,8 monochrome backlight modes and 1 full color backlight. PBT keycaps are made with thick walls and are resistant to wear, friction, and solvents and to let more light through, making your keyboard’s RGB lighting even more stunning.
Specifications:
.Material: Aluminum Alloy
.Product Dimensions: 34 x 12 x 2.6cm
.Product Weight: 1500g
.Package Dimensions: 37.5 x 15.5 x 5cm
.Package Weight: 1650g
.Packing: Box
