Author Topic: How do I replace springs on a model m?  (Read 2585 times)
Offline KillerBee
« on: Fri, 03 September 2010, 13:31:05 »
I was swapping space bars between my M's and teh spring bent and bnow its not the same?
How can I replace the spring? do I just pull one out and set in the space bar hole?
Thanks
IBM Model M 1386304 Nov. 1985
« Reply #1 on: Fri, 03 September 2010, 13:45:51 »
Quote from: KillerBee;219602
Thanks
You can pull them out, but without tools you won't get them fitted back in. Both are best done using an easy to make tool like this: http://geekhack.org/showpost.php?p=156128&postcount=12
Current collection: HHKB Pro 2 black on black, HHKB Pro 2 white/grey blank, [strike]Dell AT101W[/strike] (sold to SirClickAlot), 1992 Model M, Key Tronic Ergoforce KT 2001, BTC 5100 C. Dead boards: MS Natural Elite, MS Natural 4000.
Offline ch_123
« Reply #2 on: Fri, 03 September 2010, 13:53:46 »
Is this on the 1985 one?
Offline KillerBee
« Reply #3 on: Fri, 03 September 2010, 14:04:46 »
Quote from: ch_123;219606
no it was the IBM Model M 42H1292 from 12/1995
Offline KillerBee
« Reply #4 on: Fri, 03 September 2010, 14:05:48 »
i'll try tonight
