Author Topic: [IC] CU21  (Read 7431 times)
Offline CAPS UNLOCKED
    • capsunlocked
[IC] CU21
« on: Wed, 27 October 2021, 15:20:52 »
Hi Everyone!
Excited to officially announce the CU21!
The CU21 is a high-profile Aluminium numpad. The PCB features per key RGB-LEDS, hotswap sockets and is supported by QMK/VIA.
Photos of Prototypes
277787-0
277789-1
277791-2
277793-3
Included in the Base Kit
- Aluminium Case.
- Hotswap PCB
- Screws
- 2 x Rubber Feet
Optional Extras
- Switches (TBD)
Pricing
Base Kit is expected to be  | £58.33 ex VAT | £69.99 inc VAT
Dates
Launch Date: 1st November 2021 (possibly a few days later)
End Date: 1st Dec 2021
Expected Fulfilment: Q2 2022
Proxies
TBD
    • capsunlocked
Re: [IC] CU21
« Reply #1 on: Wed, 27 October 2021, 15:23:33 »
reserved
Offline nFaiz
Re: [IC] CU21
« Reply #2 on: Wed, 27 October 2021, 15:27:18 »
will the qc be better than the cu7
    • capsunlocked
Re: [IC] CU21
« Reply #3 on: Wed, 27 October 2021, 15:29:38 »
Hi!
Really happy with the quality of the CU7s, out of all of the orders sent out there have only been a handful of errors, many of which were caused during shipping.
Have you experienced an issue with your CU7? If so, please let me know: https://caps-unlocked.com/contact-us/
Offline nFaiz
Re: [IC] CU21
« Reply #4 on: Wed, 27 October 2021, 15:33:37 »
Hi!
My bad I was thinking about another GB. glwic
Offline MIGHTY CHICKEN
Re: [IC] CU21
« Reply #5 on: Wed, 27 October 2021, 15:35:19 »
It would've been nice if we could have split the 2u keys into 1u
Offline of_sam
Re: [IC] CU21
« Reply #6 on: Wed, 27 October 2021, 15:50:41 »
This is nice. I really wish you would raise the edges to cover the sides of the caps more so you can't see the switches underneath.
Typing on: HHKB Pro 2 - Stock :aware:
Collection: F1.69, Police, Jubi, RF 87U, En Dash, Rosenthal, Soulless, Frog, Calliope, GAF 910, Sabre, W1-AT
Offline mvkb
  • Designer
    • MVKB
Re: [IC] CU21
« Reply #7 on: Wed, 27 October 2021, 15:51:24 »
Was hoping the same thing.
Offline 000Metatron000
Re: [IC] CU21
« Reply #8 on: Thu, 28 October 2021, 07:00:56 »
The smaller version with eh rotary encoder is absolutely adorable 😍😍😍
Offline Anthixious
Re: [IC] CU21
« Reply #9 on: Fri, 29 October 2021, 12:19:34 »
Bruh, THIS. Also will the numpad be at an angle or is this a 0-degree case?
Offline oilpapers
Re: [IC] CU21
« Reply #10 on: Sat, 30 October 2021, 06:49:36 »
Oooo, will this match the angle of the CU65?
    • capsunlocked
Re: [IC] CU21
« Reply #11 on: Mon, 01 November 2021, 07:38:35 »
The case is 0-degrees. :)
Offline Saru
Re: [IC] CU21
« Reply #12 on: Mon, 01 November 2021, 14:45:57 »
+1 on raising the edges or if there's space to have the PCB sit slightly lower to hide the switches underneath.
Any clarification on how it's mounted?
Offline SmitH1y
Re: [IC] CU21
« Reply #13 on: Tue, 02 November 2021, 10:14:47 »
I like this!!
    • capsunlocked
Re: [IC] CU21 - GB is LIVE!
« Reply #14 on: Mon, 29 November 2021, 09:15:07 »
