Author Topic: [IC] DOMIKEY X GLOVE TIGER SA PROFILE ABS DOUBLESHOT KEYCAPS  (Read 7284 times)
Offline GLOVE
« on: Fri, 29 October 2021, 09:26:21 »
About Design
With repeatedly trying and thinking, we eventually finished the above design of Novelties.
The figure of Tiger has a deeply and strong image in Chinese Folk custom.
By adding rich culture meanings generation by generation, the image of tiger is simplified and symbolized by Chinese people for Exorcism and Benediction.
As Tiger is given a image and meaning as scaring away bad evils and guarding the house, Chinese people usually make their wares and articles with a tiger face.
In Folk custom, the Tiger is treated as a Child guardian. Children wear tiger-head hats and shoes, sleeps on tiger pillows.
Therefore, the image of Tiger is designed powerful and lovely.
It carries people’s wish to their children that to grow up like tiger and keep healthy and strong.
Dual usage of 1.5u Keycap
Two 1.5u lucky cloud Novelties are able to use as Tab key and backslash key.
Colour pallet of Keycaps
The above is the three colours used in design.
The yellow is close to the colour in SA 00 set by Domikey.
The white is close to the normal PBT warm white.
The coffee colour is close to the MOD kit colour in Chocolate theme keyset.
TIGER-T Coffee Transparent keycap
The craft isn’t very clear in render image, the final keycap is similar to SA APES Black transparent keycap.
KITs
Yellow Tiger All-in-one
White Tiger All-in-one
White&Yellow Tiger All-in-one
SPEC
Manufacturer: Domikey
Material: ABS Double-shot
Profile: SA Profile
Customize your Tiger gear
When you buy Yellow Tiger All in one or White Tiger All in one, you are able to combine and assemble two keyboards with different layouts.
The above is a group of Layout Samples. More layout groups waiting for your ideas.
Some renders
Keycaps will be shipped with unique customized package.
Kailh Tiger Amber Switch
Tiger Amber switch is linear switch sharing same module of KAILH MASTER switch series.
The upper cover is PC plastic, the stem and the lower cover are POM plastic.
The switch features long springs and its force weight designs to 45g.
The final switch tech data and touch feeling will be updated when sample is produced.
[Production] Estimated within 2 or 3 months
[Switch option] 70/90/100/110
[price] undecided
The Amber switch will be shipped with unique customized package.
The following are sample photos
Update Date: November 16, 2021
1.Yellow tiger standard
2.white tiger standard
3.White mod & coffee colour alpha
4.Yellow mod & White alpha
Vendors
   USA: kprepublic.com
AU: najakeys.com
Welcome everyone to join our Discord: GLOVE.STUDIO
Welcome all to comment for your valuable suggestions!!
« Last Edit: Tue, 16 November 2021, 05:03:27 by GLOVE »
Offline Bub
    • big bub's beepers
Re: [IC] DOMIKEY X GLOVE TIGER SA PROFILE ABS DOUBLESHOT KEYCAPS
« Reply #1 on: Fri, 29 October 2021, 09:43:56 »
the set doesn't really do it for me, but MAN this IC is very high effort. well done there.
Offline Surefoot
« Reply #2 on: Fri, 29 October 2021, 10:08:50 »
IC and packaging quality are both top notch. Also Domikey SA sets are almost as good as SP ones. Black & yellow theme is always nice.
Offline ravenousrhino
« Reply #3 on: Fri, 29 October 2021, 11:50:57 »
Being born on a Ram year, I'm excited to see you guys do that one. But man this is an awesome set.
Offline JohnYYZ
  • KanataKeys.co
« Reply #4 on: Fri, 29 October 2021, 14:15:41 »
Hey GLOVE, amazing work as always! GLWIC!
Offline ZongZiWang
« Reply #5 on: Sat, 30 October 2021, 01:09:45 »
After Ape, another wonderful IC, especially the animation to explain how 1.5u novelties can be reused and how all-in-one kit can cover two boards, we need more motion design like these to help people understand.
Offline HappyB0T
  • I'm a Piggie
« Reply #6 on: Sat, 30 October 2021, 13:57:48 »
I don't use SA but I really like the IC and the designs. Also +1 to any set with brown done well!!
Offline GLOVE
« Reply #7 on: Sun, 31 October 2021, 09:11:51 »
Thank you for your attention! ^-^
« Last Edit: Sun, 31 October 2021, 09:14:08 by GLOVE »
Offline GLOVE
« Reply #8 on: Sun, 31 October 2021, 09:14:36 »
Thank you for your approval! ^-^
Offline DericT
« Reply #9 on: Tue, 16 November 2021, 08:04:07 »
Absolutely looking great
Offline nickthaskater
« Reply #10 on: Tue, 16 November 2021, 15:21:58 »
Would be all over this if it were PBT. Great effort.
Offline Dorlin
« Reply #11 on: Thu, 18 November 2021, 02:02:27 »
WOW! Wonderful IC.  GLOVE YYDS
Offline DerBonk
  • I'm just this guy, you know.
« Reply #12 on: Thu, 18 November 2021, 02:51:39 »
Amazing work. The theme and colors don't really vibe with me, but I love the strong vision and execution. Might spring for some white alphas, always handy to have.
