Author Topic: So.. brand new... HI!  (Read 3637 times)
Offline Joxe
« on: Wed, 03 November 2021, 10:20:26 »
Hi Everyone! Super new to the hobby.. but pretty excited to dip my toes in the water. Bought a few tools, plus some lube to start modding switches! Saving up for a Kit to sodder. I know there are hot swaps, but I feel comfortable giving a full send into this.
I know this is a little of pot stirrer, but....
EPBT OR GMK?! xD
Offline spingo
Re: So.. brand new... HI!
« Reply #1 on: Sat, 06 November 2021, 07:56:34 »
Similar story here. Just finished my first build with a solder board. Highly recommend taking your time step by step and make sure everything's right. Had to desolder a few switches due to bent pins I didn't notice at 2am. Built it with EPBT but did jump into a GMK GB and waiting for that to finish to know if it matters. So far the EPBTs are nice but I'm sure when I get my GMKs I'll be a snob about it afterwards and be like "EPBTs? Pah, has to be GMK".
After my build though I want to see if hot swap is just as nice and maybe do a hotswap board. The idea that you can just swap switches when you want is nice.
What switches are you gonna buy?
Offline Joxe
« Reply #2 on: Mon, 08 November 2021, 16:01:43 »
So I gotta say I ended up getting Halo Trues and just lubed them up this past weekend. It took maybe 6 hours for a 65%.. It wasnt fun the whole time, but let me tell you... when I put the last switch in and test the whole board its a HUGE difference.
Hotswap actually isnt bad at all because if I mess up buying one switch I dont like, I can always get the other!
Offline spingo
« Reply #3 on: Mon, 08 November 2021, 19:41:37 »
...After my build though I want to see if hot swap is just as nice and maybe do a hotswap board. The idea that you can just swap switches when you want is nice.
Took me about 6+ hours to lube a 75% too. Wait until you find the joys of QMK and start googling "best keyboard macros".
Things I learned the hard way:
1. Make sure the switch housing is closed all the way before pressing into the PCB/tray mount.
2. Opened housings can actually make it difficult to install a switch onto the PCB
 2b. This will lead to numerous bent pins
3. Buy a switch puller
4. Buy a solder puller
5. Cheap key caps are definitely cheap for a reason
6. No one around you cares about keyboards the way you care about keyboards and if you find that one person and they end up liking clicky switches; it's ok, let them like clicky switches - you're not going to find another one.
