Author Topic: Mx spos  (Read 4683 times)
Offline Phaedrus2129
Mx spos
« on: Sun, 05 September 2010, 11:06:33 »
So I traded my review sample of the XArmor U9BL for Ricercar's last NIB Cherry SPOS MX keyboard which I've been wanting for a while.
Oh crap, did Ace Ventura deliver my package?
Seems ok...
It is!
It seems to me that one either loves or hates the layout of the SPOS. Personally I love it, it's compact and the only things in weird places are the things I never use. The only thing that took getting used to was the small enter and backspace keys and small right shift. It definitely eats up less desk space than my G80-8200, though I did have to push my monitor back a couple inches due to its height.
But I'm not done yet...
Oh yes. Yes yes yes.
I found a place for all my extraneous escape keys, and it solved the odd location of the arrow keys for me.
I think it even looks better this way. Certainly there's more visual interest than there was before.
Mine is serial #000038. Wooo!
Feel? It feels like brown cherries, duh. Ok ok. I will say it certainly feels different. My MX11800 had very worn browns, which were essentially linear, and they were just alright. My G80-8200 has a very "soft" feel; call it typing on clouds. Very pleasant and soft feeling. The SPOS on the other hand has a more "precise" feel, and they feel like they take maybe a smidgen more force. It's what I originally thought brown cherries would feel like. They're quite good, I like them, but maybe not quite as much as the G80-8200. But the 8200 took almost a month of use for the switches to break in and achieve that great feeling, so maybe these will end up feeling similar, or at least better than they do now. They're not bad by any means though; just not as delightfully soft as the G80-8200.
The programming was a bit of a let down, I thought this board was hardware reprogrammable like the 8200. My fault for not doing research. Still it's useful. I've programmed the entire top row of keys to report scancodes e0x00 through e0x10 (top far left being Esc, key labeled Esc being alt+F4). I'll program Autohotkey to do stuff with them later.
It doesn't have NKRO, but it does have a variation on the IBM matrix which is adequate for gaming. The function keys being right above the number keys and with no gaps is a plus, since I can  hit quicksave (F5 most games) very easily. I rarely use macros in games, but I may start since I have so much macro power.
It had a few defects. The F4 switch is mounted crooked and I'm going to have to touch that up with a soldering iron. Also one of the relegendable keycaps was defective, the cap wouldn't stay on. No biggy, I displaced it with a beige key. I sent an email to Signature Plastics asking what the price of 30 black Cherry MX-compatible relegendable keycaps and two double-length ones would be; waiting for a response. I've also got those doubleshot G81-7000s on the way. :)
Overall it's a good board and I like it. Main benefit is finally having PCB-mounted MX browns in a truly compact layout with lots of reprogramming capability. These are good boards and it's a shame they're so rare.
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline TexasFlood
Mx spos
« Reply #1 on: Sun, 05 September 2010, 11:18:11 »
Oh man, I'm sad now.  My ricercar SPOS fell through some time back.  Haven't found one yet but hope springs eternal, :wink:.  Congrats, looks great and sure it feels great as well! (I like Cherry browns as well)
Offline washuai
    • http://home.earthlink.net/~haruai/
Mx spos
« Reply #2 on: Sun, 05 September 2010, 14:06:23 »
Congrats.
One of the main reasons I want one of those is to get the G80-8200 feel in a compact form.  I'm a little sad to hear it isn't quite the same.  Although what I like about my 8200 over my Filco is that the keys feel bouncier, so I'm not quite sure that means the same thing as "soft clouds".
Kind of a good thing that one of these isn't currently available, since my budget says I shouldn't be that kind of bad, now that I've got an 87U on the way.
⌨(home)Realforce 87U ⌨(backup) Filco Majestouch 104 Brown ⌨(backup)Cherry G80-8200LPDUS ⌨(work)Leopold FC200RT/AB
☛CST L-Trac-X ☛Logitech Wireless Optical Trackman ☛ Razer 3500 dpi ☛MS Explorer DeathAdder
Lay-a-bouts:  ⌨Full 109 Key Virtually Indestructable  Keyboard ⌨Compaq Radio Quack GYUR84SK
Wishlist: ⌨KBDmania Pure ⌨Déck 82 ice/frost/toxic/royal ⌨Ricercar spos G86-62410EUAGSA ☠ ✞⌨miniGuru(s) ☠
 ✐Intuos or Cintiq
Mx spos
« Reply #3 on: Sun, 05 September 2010, 14:34:51 »
I think it has to do with PCB flex. The 8200's PCB is half again as long as the SPOS PCB, so it flexes and bends more easily. That probably contributes to the feel.
Offline elbowglue
Mx spos
« Reply #4 on: Mon, 06 September 2010, 20:21:42 »
Yeah - the Ricercar spos has no flex, the PCB is very small and firmly attached to the base.  My prior experience with a large MX 8100 was not great as there was so much keyboard flex that keys Y though O would move away when I tried to hit them, it was no good. :(
I preferred the ricercar over all other cherry brown switches I have tried for what it's worth.
I have bought a total of 3 ricercar SPOS's now, 2 from the initial offering, another one off ebay recently.   I have given one away as a present, another I sold, and the last one I'm gonna keep :P
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline ricercar
  • mostly abides
Mx spos
« Reply #5 on: Mon, 13 September 2010, 16:35:14 »
Quote from: Phaedrus2129;220169
Realizing the MX SPOS PCB is bolted to the shell, I stiffened up my G80-8200 clone PCB (G80-6955 HPDUS) by bolting the PCB to the lower plastic shell, inserting rubber things between PCB and top shell near the mounting posts, and adding rubber feet for desktop stability. It's very nice. Try drilling holes in inoccuous places for Bolt Mod nuts&bolts. There's a world of difference.
But even with double shots, G80 browns still don't feel as good as the laser caps in my MX SPOS browns.
« Last Edit: Mon, 13 September 2010, 16:58:16 by ricercar »
Offline itlnstln
Mx spos
« Reply #6 on: Mon, 13 September 2010, 16:38:01 »
The SPOS browns are pure awesome.  They seem to have a little more tactility to them.
