Author Topic: [CLOSED][GB] KEYFIRST BLING SWITCH LINEAR PRE-LUBED  (Read 6511 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Fri, 12 November 2021, 00:04:58 »
SPEC
  • Brand:keyFirst
  • Model: bling switches
  • Clours: bling pink,bling blue, bling green,bling yellow, bling purple
  • Mould: The moulds are made of Japanese Elmax steel,feature high mould accuracy,
    low wobble and good smoothness
  • Feeling: Linear Feedback,Pre-Lubed,glides smoother than stock switches
  • Material: Housing-PC; Stem-POM
  • Spring: Gold plated two-part spring and made of high-quality Korean KOS
  • Mount: 5-pin PCB mount
  • LED support: Support for SMD RGB LED, 2 Leg LED and 4 Leg RGB LED
  • Transparent housing with shiny powder
  • Stem to match the colour of the housing
  • Travel: 2.0 mm pre-travel/ 3.8 mm total travel
  • Press life:6000w
Groupbuy Ended on  23rd November (PST)
Estimated Delivery in Feb 2022.
JOIN NOW!
« Last Edit: Sun, 28 November 2021, 21:49:38 by KPrepublic »
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: [GB] KEYFIRST BLING SWITCH LINEAR PRE-LUBED
« Reply #1 on: Fri, 12 November 2021, 00:07:11 »
278429-0
278431-1
278433-2
278435-3
