Author Topic: geekhack on crt vs. lcd  (Read 26719 times)
Offline typo
« on: Mon, 06 September 2010, 06:46:28 »
i had some real nice crt's and the orange lines on the front of the forum were clearly visible. i now have a very high end lcd that is calibrated with a colorimeter to srgb for web use. the orange lines are gone! are they meant to be seen? or did i just have the contrast too high on the crt's?
Offline instantkamera
« Reply #1 on: Mon, 06 September 2010, 07:33:38 »
screenshot? There is a lot of orange on the forum, and I don't know what the "front" of forum is.
Were they visible before you calibrated? Generally, the calibration/profiling process is not drastic as to significantly change an entire colour to something else. If it were, you would have noticed some messed up **** before calibrating.
What hardware/software are you using for calibration?
Realforce 86UB - Razer Blackwidow - Dell AT101W - IBM model MCST  LtracX - Kensington Orbit - Logitech Trackman wheel opticalAMD PhenomII x6 - 16GB RAM - SSD - RAIDDell U2211H - Spyder3 - Eye One Display 2
Offline typo
« Reply #2 on: Mon, 06 September 2010, 08:08:14 »
i did not use this monitor before i calibrated it with the i1 xtreme. it is calibrated to standard web srgb. i am talking about the main list of forums on this site. on the crt there were orange lines running horizontally under each forum title/name. with the contrast cranked on the crt they were highly visible. i am assuming the calibration sets the contrast where it should be. thus not allowing me to see these lines. i was just wondering if they should be seen on a properly set up display. if they should, something is wrong here. i am guessing that they are not visible unless the display is way out of adjustment though. it could be something that is improperly implemented or not ment to be seen. i am wondering.
« Reply #3 on: Mon, 06 September 2010, 09:14:22 »
Quote from: typo;220326
I think you are imagining things. I see none.
Offline erricrice
« Reply #4 on: Mon, 06 September 2010, 09:35:00 »
Yeah, it sounds like you had the contrast set too high on the CRTs and it was causing that 'light blur' effect with bright colors against dark ones.  And no, I don't see any vertical lines anywhere either.
I\'m selling all my Shizz! Please buy it!
White ALPS: Northgate Omnikey 101-NCS(Real-Complicated)****Filco Zero FKBN87Z/EB(Fukka Simplifieds)****Siig MiniTouch(XM Simplifieds)
Black ALPS: Black Dell AT-101W(Real-Complicated)****ABS M1(Modded Black ALPS, Linear)
Buckling Spring: Model M 1391401(1988 & 1993)
Cherry Blues: DAS III Pro
Cherry Blacks: Cherry G80-11900
Cherry Browns: 3X Cherry G80-8113LRCUS-2
Cherry MY: G81-7000HPBUS-2****G81-3000LANUS-0****Modded to 20g
Rubber Dome: HHKB Lite 2 (White & Black)
Logitech G5[/FONT]
Erricrice\'s Song of the Day: Gorillaz - El Maņana
Yup, Blatantly stealing this from you Kishy, hope you don\'t mind, it\'s a great idea.
« Reply #5 on: Mon, 06 September 2010, 09:42:08 »
Quote from: erricrice;220355
Does anyone know if there are diagonal lines?? We really have to cover every angle.
Offline erricrice
« Reply #6 on: Mon, 06 September 2010, 13:08:55 »
Quote from: instantkamera;220361
Lol I swear I looked twice at that post and he said vertical. Hahah, either way, I'm not seeing any lines of any kind.
Quote from: ripster;220364
I see dead people if I squint.
Is this a genetic thing?   I think I have it too...
Logitech G5[/FONT]
Offline WhiteRice
« Reply #7 on: Mon, 06 September 2010, 14:00:51 »
Quote from: ripster;220334
Not seeing any orange lines on my calibrated LCD display.
Is that zooey deschanel?
« Reply #8 on: Mon, 06 September 2010, 14:06:58 »
Yes, Rip has a crush.
Offline WhiteRice
« Reply #9 on: Mon, 06 September 2010, 15:54:22 »
I approve
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #10 on: Mon, 06 September 2010, 17:00:44 »
CRT's are better than LCD's. That includes forum browsing.
Offline Rajagra
« Reply #11 on: Mon, 06 September 2010, 17:50:37 »
Do you have ClearType enabled? It could be causing artifacts on a CRT where it is inappropriate.
Offline typo
« Reply #12 on: Mon, 06 September 2010, 21:42:16 »
the lines are there super faint if i use the lcd in a dark room. they were very visible with the contrast cranked on the crt. i am sure this display is set up properly. so, i only saw them brightly on a crt that was way out of adjustment. look real close in the dark, under each forum name there is a line going from side to side. it may not be visible at all on some displays. since i can barely see it on this one. i would not see it had i not known it was there on the crt. i would completely miss it on this display.
Offline EverythingIBM
« Reply #13 on: Mon, 06 September 2010, 23:06:18 »
Quote from: Rajagra;220530
Some cheapo acer LCDs are really bad with cleartype and just contrast the heck out of it. All of those bleeding colours... horrible. Cleartype on CRTs doesn't bug me that much. But I don't like it in general as I can faintly see it on CRT & LCD alike. I wish MS just used NORMAL dithering. Ugh.
It should be called "stupid colour bleeding type".
« Reply #14 on: Tue, 07 September 2010, 07:18:56 »
Quote from: typo;220619
please describe the line or take a screenshot indicating it's position and size. Is it one pixel thick, or substantial?
Offline itlnstln
« Reply #15 on: Tue, 07 September 2010, 07:49:54 »
Quote from: ripster;220473
Bangs are a dead giveaway.
Please do not reply with unpure thoughts.
I prefer a 1 on 2 bang ratio.  1 being me, of course.
Offline Zalusithix
« Reply #16 on: Tue, 07 September 2010, 22:17:44 »
I think more importantly, what are you using as a web browser? And on what OS? I don't see anything on Firefox 4 (B3), Chrome, or IE 8 on Win 7. Though the garbage that is IE8, improperly displays table borders that shouldn't be showing up - big surprise there.
And by not seeing, I mean not seeing normally, or by taking a screenshot and  going into Photoshop, zooming, and playing with all sorts of brightness/contrast/hue changes. Hell, there's not a single difference in the pixel color values.
Offline typo
« Reply #17 on: Wed, 08 September 2010, 01:03:44 »
they were one pixel thick under each forum name. it was just on a crt with the contrast all the way up in ie7. it was either a bad monitor or just completely out of adjustment. i think i was imagining i can see them very faintly on the high end lcd. they don't seem to be there now. it was something the crt was doing and maybe does not even exist. i don't know.
do you guys see the orange line at the top of each post in thsi thread? it was that on the main page with the bad crt. you will need very good eyesite and a calibrated monitor to see lines that faint most likely. they are not there on the forum selction page. at least not anymore. plus i have a good crt here now too and don't see them on that either!
bottom line: the crt where i saw that was obviously out of whack.
Offline Zalusithix
« Reply #18 on: Wed, 08 September 2010, 01:56:46 »
I see no orange line above each post... Nor do I get any value close to orange when inspected in Photoshop. Rather the opposite really - the red channel is slightly lower than the red and green, though still essentially grey-scale. I'm going with an IE7 rendering bug causing these things.
Offline typo
« Reply #19 on: Wed, 08 September 2010, 18:35:49 »
i am using firefox. it is profiled.  i am not talking about the line above "hours ago". there is a redish/orange line directly above the top line of text we type in each post of a thread. i have to mention, i have 5/10 vision! that is almost unheard of but i am serious. it might be that i can see something other people don't. that has never been the case before though. i just did not need binoculars when other people did at sporting events/concerts. i do see the lines in the main forum page still too. very faintly. even i could esaily miss it. i just know it is there because of when i had the messed up crt.
i am not claiming to be superman by any stretch. i just have better than average vision. if that is even the reason i can see this.
« Reply #20 on: Wed, 08 September 2010, 18:53:49 »
Quote from: typo;221060
Im totally lost now. You have described seeing this line in more than one place so far, amirite?
I think your eyes are unable to deal with the abrupt contrast of two colours or shades so your brain "invents" an intermediate "colour"... or something. Like an optical illusion of sorts.
« Reply #21 on: Wed, 08 September 2010, 22:10:35 »
5/10 vision?!?!
You might want to read a few vision exercises here and reduce your vision to a more normal state:
http://www.eye-exercises-for-good-vision.com/strengthening-the-eyes-chapter-7.html
Offline clickclack
  • Board Chow EXTRAORDINAIRE
« Reply #22 on: Wed, 08 September 2010, 22:37:42 »
When did we start stating visual acuity backwards??? Did I miss something?
It's either based on 20/20 or 6/6 (feet and meters respectively)
If you are writing 5/10 for some odd reason then your vision would be twice as bad as the "normal" eyesight.
It works like this-
I used to have about 20/10 vision, which means I could see a particular mark at 20 feet when the average person would need to stand at 10 feet to see it.
If you are at 20/20 you are considered "normal", if you are at 20/40 your eyesight is twice at bad at "normal". You would have to stand at 20 feet to see something that a "normal" sighted person could see at 40 feet.
Now back to the topic...
No one seems to see this odd phenomena on geekhack but you. Seeing a pixel thick line on a monitor is easy, it would only be hard to see if the color is very, very close to the surrounding colors. I can easily see the red, green, blue subpixels on all my lcd devices at well as all of my crt devices. My guess is either your monitor is so outta wack that its haloing images or your eyes are doubling and color shifting. I actually thought you were kidding since you woudn't post a pic/screenshot of the issue. But when you said
there is a redish/orange line directly above the top line of text we type in each post of a thread..
I just figured it was your browser (I use IE and see no orange line above our posts). But the more I think about it, I think your eyes are either getting tricked or having issues =P
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
« Reply #23 on: Wed, 08 September 2010, 22:43:31 »
Quote from: clickclack;221123
It works like this-
Actually some LCDs can do some whacky stuff. I'm not sure whether typo is using a CRT or LCD anymore... but LCDs *are* prone to drawing horizontal or vertical lines across the screens (HP *Cough cough*).
A teacher I know *had* 20/10 vision.
I'm working on fixing my vision a little, after resting my eyes, my sight does get better. But right now they're bloodshot, so, I don't think that'll do much =p
Offline typo
« Reply #24 on: Thu, 09 September 2010, 05:00:38 »
actualy you are probably correct. 20/10. they said i have twice as good, i have not been tested in years so it could have declined very likely. i have nystagmus. i tend not to look people in the eye so they don't think i am rolling my eyes at them. i was made glasses three times for that and i couldn't see right at all with them. that could be the cause of this seeming optical illusion i see here. i could possibly take a screen shot from a crt.  isn't that from the video card. not the actual crt? i swear anyone one could have seen it on that out of whack crt.
you guys really don't see the thin line directly above a post body here?
this is the most color acurate lcd in production and it is calibrated with an automated system(ione xtreme). it is very likely my eyes, i don't doubt that.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #25 on: Thu, 09 September 2010, 11:49:39 »
Quote from: typo;221162
I do. It's a thin grey line in dark theme, and a rather obvious blue one in light theme.
All that with a vision of like 4-5/10 (~20% incl. nystagmus), 19" 5:4 of rather decent color accuracy, viewing distance ~20 cm. Seamonkey 2.0.7, no font smoothing whatsoever.
Offline clickclack
« Reply #26 on: Thu, 09 September 2010, 14:11:22 »
Indeed the screen shot wouldn't be from what your monitor might be displaying but it would have given us a better idea of "where" you were initially seeing it. But I suppose that point is moot now anyways.
As far as seeing the line that you mention, this...
Quote from: keyb_gr;221254
I do. It's a thin grey line in dark theme, and a rather obvious blue one in light theme...
...is what we see. Calibrated or not we get no orange line that you mentioned.
Worst case scenario is that your (or someones) color profiles make the grey a very, very warm tint. But our calibrated and uncalibrated displays do not show it as orange.
So that monitor is wacky, if it's on another monitor that IS calibrated and believed to be ok then you are wacky =P hahaaa.
Have we beaten the dead horse enough yet? Many lawls XD
Offline NamelessPFG
« Reply #27 on: Thu, 09 September 2010, 19:26:28 »
I certainly didn't see orange lines on MY FD Trinitron G1s here.
As for the Eye-One colorimeters, I've had my eye on them, but it seems that the main differentiator is actually the software, not the hardware. Alas, I don't currently have $200+ to spend on one.
Which one should I go for? Seems it's mostly X-Rite and LaCie selling them, with very different software packages between the names, but less differences among one brand.
« Reply #28 on: Thu, 09 September 2010, 19:49:52 »
I don't know what kind of vision I got, but it's OK as long as it's not at night (I have very poor night vision).
Offline typo
« Reply #29 on: Thu, 09 September 2010, 22:42:24 »
ok, i am sorry i made such a big deal out of this. there is got to be something wrong with me then that i see this. i got an idea though. does anyone have a radeon card? go into ccc and crank the contrast. i think it is there but honestly it may not be orange. i could be color blind, i have no idea. i have not had my eyes checked(other than at the dmv) for over 20 years. anyways feel free to bury this thread.
on a side note,nameless  i'd get the colormunki. intrestingly the only full featured products are the munki(cheapest) and xtreme(most expensive). the xtreme just came with my  monitor. i paid peanuts for that and every other piece of hardware i have though. you just have to be in the right place at the right time to score a deal. i will say that a top of the line lcd right now is better than a top of the line,aging crt at this point. of course ymmv so we don't have to argue about it.
Offline Konrad
« Reply #30 on: Fri, 10 September 2010, 03:44:12 »
Quote from: ripster;221069
If you can see the CN tower in this pic you either have 5/10 vision or are Canadian.
Oh, THAT's what the CN tower looks like.  Never noticed it before.
« Reply #31 on: Fri, 10 September 2010, 07:29:13 »
my eye one sucks balls. Xrite products have not given me the most comforting experience. I also owned the "pink" huey pro. Not sure what the next purchase will be, after I get a new IPS display...
Offline timw4mail
    • https://timshomepage.net
« Reply #32 on: Fri, 10 September 2010, 07:33:04 »
Quote from: WhiteRice;220495
I approve
So is that a team Gurren seal of approval, or just a smiley with Kamina glasses?
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline Konrad
« Reply #33 on: Fri, 10 September 2010, 08:14:59 »
Definitely Kamina.
« Reply #34 on: Fri, 10 September 2010, 16:31:00 »
Sorry, but there's nothing manly about "Anime" cartoons. They're just 21st Century Nerdiness 101.
Offline Konrad
« Reply #35 on: Sat, 11 September 2010, 02:18:17 »
Quote from: microsoft windows
... there's nothing manly about "Anime" cartoons. They're just 21st Century Nerdiness 101.
No worse than 19th Century IBM computer Nerdiness 101.
« Reply #36 on: Sat, 11 September 2010, 06:43:13 »
Quote from: Konrad;221900
IBM was around in the 19th Century? Is there a Model M slide rule I dont know about?
Offline ch_123
« Reply #37 on: Sat, 11 September 2010, 06:52:24 »
The Tabulating Machine Company was found in the 19th century. A few decades worth of buyouts and mergers later, it became IBM.
Offline Konrad
« Reply #38 on: Sat, 11 September 2010, 07:17:47 »
I've learned about the Model F.  Was there ever a Model A?
Offline ch_123
« Reply #39 on: Sat, 11 September 2010, 07:20:32 »
There was. Read the IBM wiki.
« Reply #40 on: Sat, 11 September 2010, 08:39:11 »
I'm not a 19th-century nerd. I'm a Nineties Nerd!
« Reply #41 on: Sat, 11 September 2010, 09:10:15 »
Quote from: ch_123;221923
I did not know that, and here I was being silly.
However,
 Hollerith started his own business in 1896, founding the Tabulating Machine Company.
aka "turn of the century", and IBM proper is still firmly in the 1900's (20th century).
Offline Konrad
« Reply #42 on: Sat, 11 September 2010, 09:20:19 »
lol, actually I was being silly too.
But if you want to be technical, 1896 is still pre-1901 thus 19th century. Though, yeah the IBM company name (originally a spinoff) didn't exist until 1917.
Herman Hollerith patented the "Tabulator" concept in 1889. He built and sold a variety of ever-improved "Tabulators" prior to forming TMC. So says the interweb.
« Last Edit: Sat, 11 September 2010, 09:37:51 by Konrad »
Offline typo
« Reply #43 on: Tue, 28 September 2010, 19:26:34 »
i am sure i clearly see these orange lines(except now they are faint gray) on the lcd. ahh well, i wouldn't be here if i were not an oddball :)
Offline NamelessPFG
« Reply #44 on: Tue, 05 October 2010, 09:48:32 »
I just made an unexpected find yesterday.
NEC MultiSync XV29 Plus. Working. No scratches on the screen. $60. (No remote, though.)
As far as I can tell, it's basically much like the XM29 (Plus) I was hoping to find before, but this model also has an integrated pair of stereo speakers.
Now why the hell would I care about a shadow mask CRT like that, you ask? 15 KHz horizontal sync support, that's why. Just one of the reasons it's a sought-after retrogaming display for those who want to get a pure RGB image. There aren't any SCART/RGB21 connectors, just DE-15s (the same ones used for VGA), but I could probably splice my own adapter cable together.
Getting it into the house will be a pain, though, but it's going to be worth it when I do...
Offline NamelessPFG
« Reply #45 on: Tue, 05 October 2010, 10:36:22 »
Getting it into the house will be a pain, but it's going to be worth it when I do...
Offline Konrad
« Reply #46 on: Tue, 05 October 2010, 11:41:40 »
I don't quite understand your 15KHz requirement, Nameless.
(To be honest, I do remember MultiSync and VGA monitors.  And CGA, EGA, 8514, and Hercules Monochrome.  I used them all.  I remember they all sucked compared to any modern LCD, lol, sorry.  Maybe that's because anything less than 1280 widescreen is "crippling" and useless ... gawd I hate Safe Mode.)
But, uh ... aren't DE-15 connectors (aka VGA connectors, called D-SUB by modern fashion) still commonly available?  Many, if not most, LCD monitors/TVs still come with them.
Wouldn't this be a better solution to an antique monitor?
Offline NamelessPFG
« Reply #47 on: Tue, 05 October 2010, 13:18:12 »
Old consoles like my SNES, Genesis, Neo-Geo CD, and Saturn have their best outputs in 15 KHz RGB, usually through a SCART/RGB21 cable since that was the only TV standard connector that allowed for a pure RGB output. No degredation of the signal that way. The output resolution on these older platforms is also generally not the typical 480i, but 240p, which may confuse some signal upscalers/converters/processors.
Arcade boards that run in low-res mode also output 15 KHz, and those that use medium-res mode run 24 KHz. 31 KHz (VGA) is actually considered high-res.
The problem with most VGA monitors is that they can't sync below 31 KHz. It's still RGB, yes, but if they can't go that low, then they're not of much use for retrogaming like that.
I was originally planning on an RGB SCART-to-component (Y/Pr/Pb) converter with a SCART switch before it that had RCA outputs for the audio, but upon seeing the cost of that XV29 Plus, decided that it would actually be a tad more affordable if I'd just spliced my own cables. As you say, DE-15s are common, and the various DIN connectors used for the Model 1 Genesis, Neo-Geo, and Saturn should be fairly easy to find as well. (The SNES will be trickier, though...damn proprietary A/V ports!)
Offline Konrad
« Reply #48 on: Tue, 05 October 2010, 14:56:30 »
lol, the signal converter in my link costs much less than a MultiSync.  Still, $92 seems a little steep to me.  Maybe you need clear (non-interlaced) video from all those ancient devices?
Offline NamelessPFG
« Reply #49 on: Tue, 05 October 2010, 17:40:45 »
$60 (price of my particular XV29 Plus) vs. $92 (15 KHz RGB to 31 KHz RGB upscaler)? Pretty big difference there in favor of the MultiSync, but that converter would give me greater freedom in display choice (like my beloved FD Trinitron G1s). On the other hand, I haven't seen it mentioned on any retrogaming forums yet to review its quality compared to the usual renowned upscalers like the Micomsoft XRGB-2 or XRGB-3 (which are well beyond my budget).
I'm definitely looking for a sharp image that shouldn't be interlaced due to the low resolutions those consoles output in (generally 240p), as well as the best color reproduction. Composite is a blurred mess. S-Video sharpens things up a lot, but still has some color issues due to a unified chroma line.
