Author Topic: Help with my Corsair K70 Rgb Rapidfire Mk1. Please.  (Read 1514 times)
Offline Derek09
« on: Tue, 16 November 2021, 16:13:38 »
Hi,
To begin with,
I have a Corsair K70 Rgb Rapidfire Mk1 keyboard.
Recently the A key decided not to work anymore, so I decided to replace it with the right Win R key.
But when I unsoldered the A key I made a mistake, and so I melted the little ring that acts as a contact...
But Win R no problem everything went well.
I soldered the key A to the resistor because it was not sticking on the initial place because of my mistake.
But nothing worked...
So I analyzed and I saw that the keyboard works in series by line.
So I soldered the key on another key on the same line, but when I click on the key it does anything (aeftfjf) for example...
I know that the work is not very beautiful unfortunately, but I can not do more beautiful with the equipment I have.
Do you have a solution? I would really appreciate it!
Thank you!
[Win R key](https://ibb.co/8XKgWY1)
[A key soledered to the other key](https://ibb.co/9qMpgG1)
Here is my second attempt and the pcb
« Last Edit: Tue, 16 November 2021, 16:23:05 by Derek09 »
