Author Topic: Notched key for Cherry browns?  (Read 1460 times)
Offline asfogh
« on: Mon, 06 September 2010, 11:03:38 »
I have a Filco Tenkeyless Otaku Black. I was hoping to get a few more notched keys so I could set up the notches where I want (specifically on the numrow up top, which I noticed are a different key size than the F and J so while I could move it they are a different height).
Is it possible to buy these somewhere?
Offline WhiteRice
« Reply #1 on: Mon, 06 September 2010, 14:04:18 »
You forget to label nsfw
that's hysterical, not a bad idea. Would make for a good poll, "What kind of keyboard bumps do you like?"
Offline asfogh
« Reply #2 on: Mon, 06 September 2010, 15:44:26 »
any others you know of besides those?
alternatively, maybe just being able to buy slightly different keys (for example, if i switch the 5 and D keys, the D is a lower profile and though theres no bump, it's still easy to tell which is which) would work for me without having to get stickers...
Offline wellington1869
« Reply #3 on: Mon, 06 September 2010, 19:56:31 »
I still use velcro, works like a charm for function keys and number row and etc.  You'll never second guess where your finger is.
Between furry velcro and stick-on nipples, well, you know. Lets just say I finger my keyboard with great confidence.
using: ms 7000/Das 3
