Author Topic: [GB] 60% Z60-Evolve, Gasket, split-top enclosure with 60%, WKL or HHKB layouts  (Read 10084 times)
Offline tommyamoszhao
Hi, Geekhack! We are introducing the market's first split-top enclosure concept, this enabling detachable blockers design to be implemented, means the options of default 60%, WKL or HHKB layouts is now available all in one keyboard. This split-top mounting mechanism not only cuts down manufacturing costs making the price for Z60 stays in a budget build region, also enabling it to have a contrast of different material textures aesthetically.
Build and Review videos of Z60-Evolve engineering samples
                MechMerlin channel build & review
                Wan Syazlina channel build & review
                Andy V Nguyen build
                Andy V Nguyen review
Join our Discord
Rendered Image
E-White with WKL blockers
E-White with HHKB blockers
E-White with Aluminum PressBars
Color Variants with Brass/Aluminum PressBars
E-White
Anodized Black
Anodized Ruby
Anodized Navy
Dimension:
  • Length: 298.7mm, width: 109mm, front-height: 17.02mm, rear-height: 29.02mm
  • Typing angle: 6.5 deg
  • Wall thickness: 6mm
  • Brass pressbar thickness: 6.5mm
  • Weight: 1kg (Case+PCB+FR4Plate+Press-bars)
Features:
  • Split top enclosure
    • Two brass press-bar is used instead of a entire top enclosure
      • This allows detachable blocker design become practical and simple
      • Minimize the waste of material, hence retain the cost in budget build range
      • Allows color and texture contrast of overall look (with Brass PressBars)
  • Normal, WKL and HHKB Press-Bars (7U bottom row)Updated 18 Nov
    • Normal Press Bar: will be clean of side-screw holes
    • WKL Press Bar: will have WKL blockers integrated into the bottom Press Bar
    • HHKB Press Bar: will have HHKB blockers integrated into the bottom Press Bar
Specs:
  • Case: Gasket mount
    • Centered USB-C socket
    • 17.02mm Front-height
    • Bottom: CNC machined out of whole piece of aluminum
    • Aluminum PressBars machined out of 6061, Same anodized color as case color
    • Brass PressBars(optional) CNC machined out of H62 Brass, PVD Titanium coating, Brushed finish, Nano coating(Oxidization prove)
    • Brass press-bars and brass blocker version press-bar works as weight
  • Plate:
    • FR4 and Carbon Fiber plates are half-plate transformable
    • Long-stripe leaves with flex cut
    • FR4 as default, Carbon Fiber and Aluminum optional
  • PCB:
    • Centered Daughter board with ESD protection
    • Solder version with all layouts compatible, including 'split-backspace', 'ISO enter', 'Stepped capslock', 'split-left shift' and 'split-right shift'
    • Hotswap(optional) version1 with ANSI 60% with 7U bottom row
    • Per-Key RGB light
  • Firmware:
    • QMK driven and VIA enabled
    • Right-hand 'shift', 'fn', 'win' and 'ctrl' keys are arrow keys when tapped
    • Layer lights placed in middle of each row, avoiding blocking, and indecating each layers
  • Color options:
    • E-White
    • Anodized Black
    • Anodized Ruby
    • Anodized Navy
Base Kit Include:
  • Bottom x1
  • Aluminum PressBars x2
  • FR4 Plate x1
  • Solder PCB x1
  • Accessories:
    • Case Foam x1
    • PCB Foam x1
    • Poron Gasket stipes(3.8x114mm) x12 4 extra
    • USB-C Cable x1
    • Cap/switch puller x1
    • Screws x1 set
    • Silicone foot pads x6 2 extra
Optional Parts:
  • Brass PressBars Normal layout
  • Brass PressBars WKL layout
  • Brass PressBars HHKB layout
  • Aluminum PressBars WKL layout
  • Aluminum PressBars HHKB layout
  • Carbon Fiber plate: 1.5mm thickness, matte surface
  • Aluminum plate: 1.5mm thickness, sand blasted, Nano coating
Pricing:
UPDATES - 16th Oct
Gaskets have their own walls, leaving minimum profile for eyes of the gasket chamber, keeps the integrity
Details of the joint of press-bar and case-wall, the Un-flushed joint design is to has a better transfer of different material textures
[/list]
Group Buy Info:
  • Group buy starts at 9:00am PST, 20th Nov.
  • Group buy ends: Estimating GB lasts for 60 days
  • Group buy site: www.quarkeys.com
  • Quantity: MOQ: 100pcs, No caps.
  • Lead time: 90-120 days depends on order quntity
  • Estimating shipping in Q1 2022
  • Shipping time: 10-15 working days depending on regions
« Last Edit: Fri, 14 January 2022, 22:02:27 by tommyamoszhao »
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
approved
Offline Qeeke Studio™
Is the yellow part made of pure copper?
Hi, it's made of brass.
Offline ravermeister
the red looks super nice 8)
Offline nick779
Yolo I guess. Bought black and white in full ano with additional blockers for that brass touch.
EDIT: Might want to join the discord. Were trying to get the runner to switch back to South facing LEDs. He said that the final production pcb was planned to have north facing LEDs which causes Cherry profile interference.
EDIT2: Runner said he will keep South LEDs as of 12:57PM EST 11/28/2021 on Discord. https://imgur.com/a/IBD5pMu
« Last Edit: Sun, 28 November 2021, 11:59:08 by nick779 »
Offline RitzKeys
Keyboard looks fire especially the ruby, may be my first groupbuy board. Best of luck with the group buy!
Thank you so much.
Thank you very much for the appreciation and the update :)
Thank you for the support
We are HALF WAY through!! ;D ;D GB ends on 20th Jan, 2022. Pretty good pace! We'd like to thank all the support from GH and you all.  ;) ;) ;)
Quick update, folks :)
1. Thanks to all the supporters, Z60 GB has reached it's MOQ already, GB ends on 20th Jan, 2022 (about a month to go).
2. A new build & review available on Z60 ruby sample, need to point out that this ruby is early sample, blockers will be integrated into press-bar in production, and color will be slightly darker.
3. More build & reviews are coming out, so stay tuned. :)
Quick updated
    1. New build and reviews from Andy V Nguyen at the beginning of this post
    2. We have exceeded MOQ already!! Thanks for all the support
    3. Acrylic Popsicle stick will be added as one of the accessories
    4. More reviews are coming on TikTok
    5. Z60 GB ends on 20th Jan, few days left
