Author Topic: [IC] Ark68 R2 by Ark Studio - 65% Gasket Mounted  (Read 29330 times)
Offline kcching
« on: Sun, 21 November 2021, 07:28:36 »
GB Date: 27th January 2022- 8th Feburary 2022 [Unlimited]
Time:  27th January 2022, 10AM (GMT+8)
GB Post
Introduction
Ark Studio was established in China by a group of keyboard enthusiasts since 2019.
We had run 7 successful group buys in China to date.
Please join our Discord server to discover our previous works: https://discord.gg/UvuTHkHvww
With our own CNC machining factory, all the group buys in China were all delivered earlier than expected (within 4 months).
We are confident that our production quality is in line with international standard.
Here we introduced you our latest product:- Ark68 R2.
Exploded View
We understand that its all about personal preferences in terms of sound and feel.
Hence we provide the foams so that you can use according to your liking.
Case Specification
  • 65% with top right blocker
  • Gasket mounted
  • PCB foam, case foam and switch foam
  • 7 degree typing angle
  • Seamless design
  • Unbuilt base kit is about 1.1kg; Built kit with PVD brass weight and PVD backpiece is about 2.8kg
PCB Specification
  • 1.2mm flex cut
  • Unified USB-C daughterboard
  • VIA supported
  • Solder and Hotswap options
  • Hotswap PCB only support WK, ANSI layout with 7u spacebar
Solder PCB Supported Layout
PCB Prototypes
Hotswap
Solder
** PCB color is not finalized.
Plate Options
  • FR4
  • PC
  • Aluminum
Packaging Specification
    CNC EVA form, anti-dust PE wrapping
Prototypes
We skipped the rendering and go straight to prototypes production.
Some of the prototypes will be send to keyboard enthusiast(s) for build and review (Yes! We are arranging now).
Due to the many components in this board, and we have more than 25 colors to choose from, we haven't decide on the colorway combination yet.
We will create an IC form to gather input from the community before we finalize the colorway.
Here are the actual prototypes photos:
Sound Test
Lubed Cream switches, OW stabilizers, Aluminum plate
Not a valid vimeo URL
Flex test with case foam
Flex test W/O case foam
Piano switches L/F with Sprit 63.5 slow2 spring swap W/O case foam
Banana Split switches L/F , aluminum plate, GMK Wild, NO FOAM
Neapolitan Ice Cream switch L/F , aluminum plate, CRP C64, NO FOAM
Neapolitan Ice Cream switch L/F , aluminum plate, GMK Modo Light, NO FOAM
H1 switch L/F , FR4 plate, GMK Oblivion, NO FOAM
To Do
  • IC Form
  • Colorway and Options
  • GB
« Last Edit: Mon, 07 February 2022, 04:22:21 by kcching »
Offline kcching
Re: [IC] Ark68 R2 by Ark Studio - 65% Gasket Mounted
« Reply #1 on: Sun, 21 November 2021, 07:29:52 »
CHANGE LOG
2021-11-22
- Fix typo for Hotswap PCB, hotswap only support WK, ANSI layout with 7u spacebar
2021-11-23
- Update IC form
2021-12-01
- Sound test and flex test with PC plate, without case foam
2021-12-02
- Sound test with Banana split on aluminum plate, NO FOAM except anti-static sheet beneath PCB
- Sound test with Neapolitan Ice Cream Switch on aluminum plate with CRP C64, NO FOAM except anti-static sheet beneath PCB
- Sound test with Neapolitan Ice Cream Switch on aluminum plate with GMK Modo Light, NO FOAM except anti-static sheet beneath PCB
2021-12-03
- Sound test with H1 Switch on FR4 plate with GMK Oblivion, NO FOAM except anti-static sheet beneath PCB
« Last Edit: Fri, 03 December 2021, 12:02:49 by kcching »
Offline treeleaf64
    • treeleaf64
« Reply #2 on: Sun, 21 November 2021, 08:07:23 »
Suspicious flex cuts
Suspicious amount of foam
Time to do more bad word posting
Everyone must pay the cat tax
Offline actress
« Reply #3 on: Sun, 21 November 2021, 08:47:04 »
please no
« Reply #4 on: Sun, 21 November 2021, 11:31:21 »
Why does the hotswap PCB say it only supports ISO, when based off the hotswap PCB proto it looks like it supports ANSI.
Offline SDKCAMPING
« Reply #5 on: Sun, 21 November 2021, 14:27:55 »
that exploded view bluew my mind, so many layers it's crazy. too many!
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline HappyB0T
  • I'm a Piggie
« Reply #6 on: Sun, 21 November 2021, 19:02:27 »
Lol I did the same thing. Mind exploded. Then I tried to count the layers. I think I saw 4 layers that were not pcb, plate or case.
Offline Fraaaan
« Reply #7 on: Sun, 21 November 2021, 19:33:38 »
4 pieces of foam? Jesus... Did it really sound so bad that you had to eliminate every last bit of the case sound?
Offline kcching
« Reply #8 on: Sun, 21 November 2021, 20:39:44 »
It was a typo. Amended.
Hotswap only support WKL, ANSI with 7u spacebar.
Offline kcching
« Reply #9 on: Sun, 21 November 2021, 20:53:29 »
Hi! All foams are optional.
Offline kcching
« Reply #10 on: Sun, 21 November 2021, 20:55:51 »
Offline finalarcadia
« Reply #11 on: Sun, 21 November 2021, 21:09:12 »
I like the case design, good job. Would’ve loved your tkl better tho :p
Offline kcching
« Reply #12 on: Sun, 21 November 2021, 21:21:28 »
Thanks for the kind word!
We do plan to bring Ark87 again but with different design elements
« Last Edit: Sun, 21 November 2021, 22:30:10 by kcching »
Offline bahm
« Reply #13 on: Sun, 21 November 2021, 23:18:27 »
Really digging the dark mirror/pink backside
Offline Stilou Studio
  • Formerly Seo
  • Danish Designed Keyboards
« Reply #14 on: Mon, 22 November 2021, 03:35:40 »
Looks awesome! GLWIC
Offline kcching
« Reply #15 on: Mon, 22 November 2021, 08:17:46 »
Offline kcching
« Reply #16 on: Mon, 29 November 2021, 10:06:37 »
Update - Sound test and flex test with PC plate, without case foam
Offline unusuaL_
« Reply #17 on: Tue, 30 November 2021, 11:02:20 »
we need a lot of foam to keep our keyboards warm this winter i suppose
collection: hibike 1/1, casper60, hhkb pro2, matrix 2.0additional, cw88
Offline kcching
« Reply #18 on: Thu, 02 December 2021, 02:44:46 »
Updated sound test with Banana split on aluminum plate, NO FOAM except anti-static sheet beneath PCB.
Hope you like it!
Offline kcching
« Reply #19 on: Thu, 02 December 2021, 02:45:58 »
Update sound test with Banana split on aluminum plate, NO FOAM except anti-static sheet beneath PCB.
Hope you like it!
Offline kcching
« Reply #20 on: Thu, 02 December 2021, 12:15:53 »
Added sound test with Neapolitan Ice Cream Switch on aluminum plate with CRP C64 / GMK Modo Light, NO FOAM except anti-static sheet beneath PCB
« Last Edit: Thu, 02 December 2021, 13:01:47 by kcching »
Offline kcching
« Reply #21 on: Fri, 03 December 2021, 12:03:15 »
Added sound test with H1 Switch on FR4 plate, GMK Oblivion, NO FOAM except anti-static sheet beneath PCB
Offline lovebee.co
« Reply #22 on: Fri, 03 December 2021, 14:06:52 »
any idea for price point yet?
Offline kcching
« Reply #23 on: Sat, 04 December 2021, 09:58:14 »
Est. around USD 300 for base kit
Offline Neprawdda
« Reply #24 on: Sat, 04 December 2021, 12:58:15 »
Will there be a plate file? or can you make a pom plate? and carbon.
Offline kcching
« Reply #25 on: Wed, 08 December 2021, 04:22:45 »
No plan for POM and carbon plate at the moment.
But we will release the plate file.
Offline kcching
« Reply #26 on: Tue, 25 January 2022, 04:16:01 »
We are very excited to announce that we are going to start the group buy by 27th January! It will be a 2 weeks unlimited group buy.
Offline Neprawdda
« Reply #27 on: Tue, 25 January 2022, 09:18:55 »
For three weeks?)
