Author Topic: ORION v3 owners help !  (Read 4702 times)
Offline NightFox99
« on: Mon, 29 November 2021, 08:52:41 »
How do you reset the keyboard (hotkey or swith on PCB) for QMK ?
Thank you,
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: ORION v3 owners help !
« Reply #1 on: Tue, 30 November 2021, 08:40:10 »
Thank you,
Hold backspace while plugging in
Offline NightFox99
« Reply #2 on: Tue, 30 November 2021, 11:00:49 »
Thank you,
Thank you, worked perfectly ! And another one question if you permit : what are hotkeys that allow you to control RGB lights ?  (I tried those indicated in QMK but they don't work... )
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #3 on: Tue, 30 November 2021, 13:46:41 »
Thank you,
RGB_TOG for on/off
RGB_MOD / RGB_RMOD for modes
RGB_HUI / RGB_HUD / RGB_SAI / RGB_SAD / RGB_VAI / RGB_VAD for hue, saturation, brightness
https://beta.docs.qmk.fm/using-qmk/hardware-features/lighting/feature_rgblight#keycodes
You should be flashing it with a qmk-enabled hex file though
Offline NightFox99
« Reply #4 on: Tue, 30 November 2021, 14:52:30 »
Thank you,
RGB_TOG for on/off
There should be something wrong. I do every step in QMK configurator then in the QMK toolbox. The parameter keys you mentioned are all set. Yet, when I press BL_TOGG (Tab) plus BL+ (W) or BL- (E) nothing happens... Same for other RGB underglow mode. What am I doing wrong ? Maybe I miss something very basic ? Sorry for bothering it drives me mad
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #5 on: Tue, 30 November 2021, 15:01:15 »
BL only covers backlighting which is in-switch LEDs (the two-pin ones)
RGB controls the underglow (SMD RGB LEDs on the PCB). You could just try flashing the VIA hex file located here, and just use VIA with the JSON file uploaded in the Design tab: https://github.com/Natac24/orion-v2.5-qmk-via
--> Code --> Download zip
Offline NightFox99
« Reply #6 on: Tue, 30 November 2021, 15:32:44 »
Thank you from the bottom of my heart. It now works just perfectly well : your workaround is 100% functional.Truly the Elevated elder you are.
« Last Edit: Tue, 30 November 2021, 15:37:53 by NightFox99 »
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #7 on: Tue, 30 November 2021, 16:33:52 »
Glad to hear. Enjoy your Orion!
Offline NightFox99
« Reply #8 on: Sat, 04 December 2021, 07:26:27 »
One last question if I may about individual LED backlights. I'm on Orion v2.1 PCB and I soldered on every spot, through the switch, a LED diode to the PCB (1.8mm). I then install firmware as you explained me earlier but no lights are turning on. Have you expericnced such an issue ? What might be the problem here ?
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #9 on: Sat, 04 December 2021, 18:53:52 »
If it's on VIA already, you could try turning the backlights on through the Lighting tab, I'd imagine. If not, there may be a keycode for backlight toggling as well that you could map onto the PCB and try pressing that.
