Author Topic: [IC] GMK CYL Prussian Blue - 2024 Relaunch!  (Read 232993 times)
Offline NoPunIn10Did
    • NoPunIn10Key
« on: Tue, 30 November 2021, 11:23:55 »
W1AT by GEON. Render by Beesley. (Full Size)
Please fill out the Interest Check Survey Form!
What is GMK CYL Prussian Blue?
GMK CYL Prussian Blue is a custom keycap set to be manufactured in the Cherry profile by GMK Electronic Design GmbH. These MX-compatible keycaps will be made from ABS plastic and doubleshot legends (with UV front-print where needed). GMK Prussian Blue uses a simple color scheme with a GMK stock white (CP) for its legends and a custom color for the base: RAL 230 20 20 (Preußischblau).
GMK CYL Prussian Blue celebrates the languages of Poland and Germany, as the former Kingdom of Prussia intersected both of these modern nations. Likewise, I want to celebrate my own family heritage; my grandmother and generations before lived in the Prussian town of Bublitz, which is now the Polish town of Bobolice.
Vendors
For the relaunch, we will be working with an updated list of vendors. This list is not final, but we hope to have wide locale coverage.
Updates
29 Aug 2024 - Relaunch of updated IC.
09 Jun 2022 - Cancellation of original GB.
01 Jun 2022 - Start of original GB.
09 May 2022 - Updated international kit, added vendor list, and announced GB date.
11 Mar 2022 - Updated spacebar kitting to include both types of 6u bar; removed 1.75u bars.
04 Mar 2022 - Submitted for quotes via primary US vendor.
Additional Background
Prussian Blue, the chemical
Prussian Blue is a chemical compound originally discovered in Berlin at the turn of the 18th century. It has been used in a variety of settings from art (Japanese woodblock painting) to architecture (a traditional blueprint dye) to medicine (a treatment for heavy metal poisoning).
Prussian Blue was also used for nearly two centuries to dye the military uniforms of the Kingdom of Prussia. The RAL standard and this keyset draw from this darker variant, and GMK Prussian Blue’s kitting takes further inspiration from the history of the Kingdom of Prussia itself.
The Kingdom of Prussia
The Kingdom of Prussia was established circa 1701 and existed until approximately 1918. Its borders changed frequently, with many of its parts split into separate enclaves and exclaves. Though it was ruled by a German-speaking monarchy, its reality was far more diverse, including regions of Germans, Poles, Lithuanians, and Silesians. For most of its existence, however, the majority of Prussian territory lay within the current borders of Germany and Poland.
Base Kit
Base Kit. Render by Beesley (Full Size)
The Base Kit will support both standard US ANSI and the modern Polish Programmers’ keyboard localizations. This kit provides support for 60%, 65%, 75%, TKL, Alice, and 1800 layouts as well as “4-key” physical support for many 40% layouts.
More details about the base kit
Child Kits
Compatibility kit. Render by Beesley (Full Size)
German Macros & Mods. Render by Beesley (Full Size)
NorDEUK Kit. Render by Beesley (Full Size)
The Compatibility Kit kit provides additional size and legend compatibility beyond what is included in the base kit, including a 6u spacebar, 1.5u System keys, numpad equals, more 40s support, et cetera. This kit is the one most likely to change pending user feedback. Please note in the survey if there are specific keys you wish to be added to this kit.
The German Macros & Mods kit provides macro column keys with legends based on the classic Cherry G80-2551 keyboard. When combined with the base and NorDEUK kits, it provides the keys necessary to recreate several full German-language keyboard layouts (like ANSI-DE and HHKB-DE), similar to the German Base Kit previously offered in 2022.
The NorDEUK Kit provides support for German, Swedish, Danish, Norwegian, and UK/Irish localizations. It follows a new international kitting standard created in collaboration between GMK and vendors.
In addition to the kits pictured above, we are considering producing an ESFR Language Pack for French AZERTY and European Spanish localization. The inclusion of this kit is tentative; if offered, it will only be available through Eloquent Clicks. (ESFR Kit Diagram)
Board Renders
Full resolution renders are available on the GMK CYL Prussian Blue Home Page.
All 2024 renders provided by Beesley.
Renders may contain inaccuracies and should not be considered the final authority on the appearance of the caps.
W1AT by GEONWORKS. 6500K and 5400K lighting. Requires Base, NorDEUK, and German Macros & Mods kits.
MB-44 by Melonbred. 6500K and 5400K lighting. Polish alpha layout, requires base kit only.
FURTHER BOARD RENDERS COMING SOON
Set Comparison Chart
GMK Prussian Blue will include one new custom color (RAL 230 20 20). Its legends will be GMK stock white CP. Below is a diagram that compares the estimated RGB hex colors of several prior and upcoming GMK and Signature Plastics keysets with those of GMK Prussian Blue.
Full Size
Acknowledgements
Thanks to my amazing wife, who has remained supportive even as my home office fills with more keyboards, keycaps, color standards, and cardboard boxes.
Thanks to my adorable daughter, who brings me such joy.
Thanks to Beesley for the beautiful updated renders.
Thanks to Afresh & konstantin for their immense help with getting the ogoneks right.
Thanks to Manzel for the original 2022 renders.
Thanks to hunghingdailo, who gifted me with a brilliant logo.
Profile Signature Code
If you would like to show your support and help advertise GMK Prussian Blue here on Geekhack!
Code: [Select]
[url=https://nopunin10did.com/gmk-prussian-blue/][img width=135 height=120]https://diplomacyvariants.files.wordpress.com/2021/12/gmk-pb-logo-135x120-1.png[/img][/url]
« Last Edit: Thu, 20 March 2025, 12:58:22 by NoPunIn10Did »
Offline Ella
  • Why is it called an oven
Re: [IC] GMK Prussian Blue
« Reply #1 on: Tue, 30 November 2021, 11:26:39 »
Very cool, nice to see sets with focus on language support!
Offline Fredington
    • Instagram
« Reply #2 on: Tue, 30 November 2021, 11:29:50 »
Excellent work as always
Offline MIGHTY CHICKEN
« Reply #3 on: Tue, 30 November 2021, 11:32:19 »
Let’s go
Offline ad4m
« Reply #4 on: Tue, 30 November 2021, 11:33:43 »
so nice. from the kitting god himself
Offline paperassgasket
« Reply #5 on: Tue, 30 November 2021, 11:34:55 »
Offline ZavaZ86
« Reply #6 on: Tue, 30 November 2021, 11:51:12 »
Lez go
Offline nFaiz
« Reply #7 on: Tue, 30 November 2021, 12:02:20 »
great set nopun!
Offline Michabc
« Reply #8 on: Tue, 30 November 2021, 12:02:54 »
Sehr schön!
Offline MaybeUnique
« Reply #9 on: Tue, 30 November 2021, 12:07:25 »
Nice colour, I like  :thumb:
Dont combine international kits plz, thx  :thumb:
    • NoPunIn10Key
« Reply #10 on: Tue, 30 November 2021, 12:14:05 »
Out of curiosity, which one do you need?
Offline Anthixious
« Reply #11 on: Tue, 30 November 2021, 12:36:42 »
Here we go again, NoPunIn10Did coming out with another great set. I love this hue of blue, I can definitely see myself using this.  :thumb:
Offline Xerunox
  • Xerunox
    • Xerunox's Profile
« Reply #12 on: Tue, 30 November 2021, 12:57:09 »
ZAMN
40% is the biggest I will go
Offline VoodooBear
« Reply #13 on: Tue, 30 November 2021, 12:58:38 »
Just gonna shoot my shot here: Please please pleeeeeease add at least 3-key (1.25u Tab, 1.75u BS, 1.5 Enter) 40's support to the German kit as well.
Offline novelflyer
« Reply #14 on: Tue, 30 November 2021, 13:04:07 »
Nice colour, GLWIC  :thumb:
Offline jtqx
« Reply #15 on: Tue, 30 November 2021, 13:06:05 »
i want this. can we move this up to q1 instead of q3 :stocks:
Big boys: JER1800, Cypher, IBM Model M, W1-AT
TKLs: F1-88, F1-8x_722, F2-84, EO87, Matrix ME, IBM 'SSK', Bias, NCR80
Small boys: HHKB Pro 2, KWa.6, Maggio
Others: Praxis, LZ Phase, Sagittarius
65% and 75% bad
Offline The0rigina1
  • fumoposting
« Reply #16 on: Tue, 30 November 2021, 13:08:15 »
wow oh wow i love this color
    • NoPunIn10Key
« Reply #17 on: Tue, 30 November 2021, 13:23:04 »
I will consider it, but it's highly unlikely.  The German base will probably need to aim for a lower MOQ, so I am keeping it quite trim.
Offline XiXora
« Reply #18 on: Tue, 30 November 2021, 13:23:55 »
Oooh. I like the concept behind this… including the kitting.
I'd suggest moving the R4 [|\] from US base to UK/Subless kit and the R4 [><] from the Nordic kit to the US base kit for Terminal ISO as default that most modern kits support this layout for ISO :)
Or is the double slash thing a Polish programmer thing? I'm not that up on many ISO layouts other than UK and Mac :P
(Ps. 1.5U Systems! woo!)
Offline Tweec
« Reply #19 on: Tue, 30 November 2021, 13:27:00 »
Interesting take on the no "fully" latin base kit, otherwise, amazing colors!
Offline herbologist
  • beige enjoyer. send help.
« Reply #20 on: Tue, 30 November 2021, 13:28:12 »
What a gorgeous color. Normally I prefer icon+text but I'm feeling this.
Offline Bachoo
« Reply #21 on: Tue, 30 November 2021, 13:32:57 »
Very well done nopun, best of luck with the IC -- I love the blue  :thumb:
Offline mymeepo
« Reply #22 on: Tue, 30 November 2021, 13:51:23 »
Wow, German support in a base kit. You have my Unterstützung.
    • NoPunIn10Key
« Reply #23 on: Tue, 30 November 2021, 13:57:30 »
So the double slash thing is indeed an intentional design decision.  I was reading up on the Polish Programmer's layout, and it seems like they are still officially an ISO layout even though it's built to resemble ANSI more.  I suspect that is the case so as to physically support Poles who need to revert to the old QWERTZ-based ISO layout.  So the second backslash isn't solely a Windows shortcut in this case, but a baked-in part of the spec.
    • NoPunIn10Key
« Reply #24 on: Tue, 30 November 2021, 13:59:39 »
I mean, it's still Latin.  Just not English.
Offline vishydesigns
« Reply #25 on: Tue, 30 November 2021, 14:34:29 »
Awesome set NoPun! Love the simplicity, and all the extra touches. Will definitely be picking this up!
Offline boneandbee
« Reply #26 on: Tue, 30 November 2021, 14:41:30 »
digging on the deep teal - can't wait to see it on a white board! GLWIC!
Offline phinix
« Reply #27 on: Tue, 30 November 2021, 14:44:27 »
Uuuu.. pierwszy raz widze polski set :)
Offline stewfayew
« Reply #28 on: Tue, 30 November 2021, 15:25:31 »
Edit: there's no Ñ I'm blind
BUT still beautiful color and logo :)
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #29 on: Tue, 30 November 2021, 16:04:52 »
Awesome work here, definitely one of the more interesting sets I've seen recently. I was planning on not getting any GMK sets for awhile due to their insane lead times recently, but this will be worth the wait!
Offline TyPo.mk
« Reply #30 on: Tue, 30 November 2021, 16:08:19 »
That is a nice blue. 2 base kits might be rough in this market though
Offline honoka
« Reply #31 on: Tue, 30 November 2021, 16:19:20 »
Super progressive kits.
I'm a sucker for sets without accented mods AND ISO-DE. So this is instantly a banger.
Offline mmayhem17
    • Steam profile
« Reply #32 on: Tue, 30 November 2021, 16:19:48 »
gmk stargaze is another set you should compare the blue imo.
Overall very good quality, i will consider.
Offline noorejji
« Reply #33 on: Tue, 30 November 2021, 16:38:07 »
Isn’t centered 6u stem more common than off-centered? I see that you want to support some classic Cherry boards; personally I have two boards using 6u centered (7V and FC660C).
Offline TomatoMan
« Reply #34 on: Tue, 30 November 2021, 17:33:58 »
killer minimal set, love the color as well   :thumb:
    • NoPunIn10Key
« Reply #35 on: Tue, 30 November 2021, 17:35:31 »
I’m considering adding the 6u centered. I have a Cherry board that uses the off-center stem.
    • NoPunIn10Key
« Reply #36 on: Tue, 30 November 2021, 17:36:55 »
Maybe?
The advantage here is that there’s a lot less crossover in the audiences. The two are less likely to cannibalize sales from each other.
    • NoPunIn10Key
« Reply #37 on: Tue, 30 November 2021, 17:57:15 »
Do you know the color standard for that?
Offline sub0001
« Reply #38 on: Tue, 30 November 2021, 18:04:49 »
This is lovely, GLWIC! :thumb:
Offline Kacperoni
« Reply #39 on: Tue, 30 November 2021, 19:09:05 »
Imma get one please
« Last Edit: Tue, 30 November 2021, 20:15:26 by Kacperoni »
Offline noorejji
« Reply #40 on: Tue, 30 November 2021, 19:16:15 »
Thank you for your consideration. I suppose it wouldn't be a deal-breaker, since those that I have boards doesn't have ISO anyway, and this kit looks very choice for norde. Nice color, and quite unique with the special characters and mods.
Offline IOVERCALLHISTIOCYTES
« Reply #41 on: Tue, 30 November 2021, 20:07:29 »
Can we get a pic of the plastic chip for 230 20 20 at some point? Love the color chart, but sample next to the sets themselves is always my favorite.
If the German kits could use 3 key 40s from the other one, I’ll ship mine cheap from the states. Maybe others would too.
    • NoPunIn10Key
« Reply #42 on: Tue, 30 November 2021, 20:39:08 »
I can get a picture of the sample in my D2 book, but last I checked RAL was out of the plastic for this specific color (CORRECTION: they don’t offer official plastic for this color at all). Also I don’t own those other sets.
« Last Edit: Tue, 30 November 2021, 23:28:55 by NoPunIn10Did »
« Reply #43 on: Tue, 30 November 2021, 22:49:59 »
I’ve got 3 or 4 of those at home and if you want when I’m back (w my dad who’s very sick) I can mail you a cap of each.
    • NoPunIn10Key
« Reply #44 on: Tue, 30 November 2021, 23:27:33 »
That’s a very kind offer. Message me on Discord and we can work out the details.
Offline knbbl
« Reply #45 on: Wed, 01 December 2021, 00:51:54 »
Very well done!
Is there no F13 in the German base for a particular reason?
Offline stidal
  • milo#3939
« Reply #46 on: Wed, 01 December 2021, 03:40:19 »
been waiting for a prussian blue set. so nice
transition tkl // aksara ce // bully // valhalla // voyager // rs60 // adiuvare // ciel60 // jules // prime e // ut47.2 // sequence // bumper // q1 // gaff60
    • NoPunIn10Key
« Reply #47 on: Wed, 01 December 2021, 06:04:48 »
Very well done!
The German base kit is likely to need to run at a lower MOQ, so I had to make a number of cuts. F13 didn’t make the cut.
Offline Afresh
« Reply #48 on: Wed, 01 December 2021, 06:46:30 »
Dziękuję :)
Great seeing polish subs!
    • NoPunIn10Key
« Reply #49 on: Wed, 01 December 2021, 13:58:16 »
I've added a forum signature version of the GMK Prussian Blue badge if anyone would like to help me promote the set on Geekhack.
Code: [Select]
