Author Topic: [IC]Tyche75  (Read 14005 times)
Offline chaucer
[IC]Tyche75
« on: Wed, 01 December 2021, 00:09:33 »
:)Hello, World
I'm Chaucer.
Hello everyone
I'm back again,
after a period of hard work Tyche75 this work is about to meet with you!
The name Tyche
comes from the Greek goddess of fate,
who is said to throw good luck and bad luck at people. Like fate,
Tyche is pronounced close to the sound of keyboard tapping. So we decided to name it Tyche75
The whole design uses the most suitable 7° cut for big data. And keep parallel lines as much as possible.
This will make the sensory overall unity stronger. The head retains the horizontal cut, and the three-dimensional angle is also vertical sense.
But the trouble with such a design is that it brings a lot of processing difficulties.
So after the first draft and again revised the internal structure, and finally achieved the initial desired design characteristics.
 And in terms of overall weighting, it will form a more stable knocking feel, but of course you can just put it up on the table.
In addition, the design of the nameplate,
 the author wanted to be more in line with the theme of fate,
drew an artistic illustration, and produced in the form of PCB,
the bottom part of the nameplate to make the whole design looks more interesting.
I have started to enter the production phase
Expected to meet you in 45 days
I have prepared 4 colors
Next is the detailed configuration
Finally, thank you for your comments on the last IC
Basic Info.
- Layout. 75%
- Color: Aluminum with anti-oxidation surface treatment
- Material. Top and bottom case aluminum, logo is Brass
- Degree: 7°.
- Structure: no plate spring washers
- PCB: Hot-swap and C-type PCB (including LED part)
- Plates:1.5mm PC
- Weight: Nickel-cobalt alloy
- Logo:Brass
- Spacer: 3mm poron
- Will use Type-C
- Supports Bluetooth
Offline expensive
Re: [IC]Tyche75
« Reply #1 on: Wed, 01 December 2021, 00:11:05 »
o
Sent from my SM-N960U using Tapatalk
Offline chaucer
Re: [IC]Tyche75
« Reply #2 on: Wed, 01 December 2021, 00:19:52 »
o
Wow, you reply so fast
Offline expensive
Re: [IC]Tyche75
« Reply #3 on: Wed, 01 December 2021, 00:20:34 »
o
lool got notifications on
Offline super_tu
Re: [IC]Tyche75
« Reply #4 on: Fri, 03 December 2021, 18:12:24 »
Can there be a stepped caps option? Loving everything else!
Offline ToSylph
Re: [IC]Tyche75
« Reply #5 on: Sat, 04 December 2021, 09:28:54 »
will there be an option for different coloured cases?
Offline 傻子
Re: [IC]Tyche75
« Reply #6 on: Sat, 04 December 2021, 20:54:52 »
WARNING:
Tyche 75 and chaucer are notorious in China that he have no experience running a group buy and is actually not a kbd enthusiast(according to his correspondence with other people, he dont even know what is a F row, PCB, FR4 Plate before he was asked of detailed information of these items).
And for his deception he was permanently banned on chinese kbd board Zfrontier.
!!! so plz check if there is such an inclination for you to be a victim.
Offline alper_maestro
Re: [IC]Tyche75
« Reply #7 on: Mon, 03 January 2022, 16:36:22 »
I'm thinking to understand why there is little interest because I see a few people warning others about the designer.
So before getting excited about the pictures, lets wait for real footage and a working prototype.
same topic:
https://geekhack.org/index.php?topic=115106.0
« Last Edit: Tue, 04 January 2022, 14:15:33 by alper_maestro »
Offline hussar_name
Re: [IC]Tyche75
« Reply #8 on: Mon, 03 January 2022, 16:41:30 »
Just erase one topic
Offline QWER|key
Re: [IC]Tyche75
« Reply #9 on: Tue, 04 January 2022, 01:20:34 »
This is the second IC thread on this board. I'm beginning to have serious doubts about this one....  just got a feeling it's someone designing things with no intention of building anything.
Offline Packkkk
Re: [IC]Tyche75
« Reply #10 on: Sat, 05 March 2022, 19:51:36 »
This one looks great. Looking forward to see the prototype.
Offline marici22
Re: [IC]Tyche75
« Reply #11 on: Sun, 06 March 2022, 17:48:31 »
Entering production phase soon yet no prototype photos and videos? That sounds a bit fishy but I'll give it the benefit of the doubt.
Offline Gerzerker
Re: [IC]Tyche75
« Reply #12 on: Sat, 23 July 2022, 05:55:54 »
Would love to see this keyboard
« Last Edit: Thu, 11 August 2022, 22:54:14 by Gerzerker »
Offline rofam
Re: [IC]Tyche75
« Reply #13 on: Thu, 28 July 2022, 08:35:54 »
This product is not available on my location  :(
Offline PuNkShoO
  • I make keyboard switches.
    • Check out my projects!
Re: [IC]Tyche75
« Reply #14 on: Thu, 28 July 2022, 12:49:47 »
Loving the weight and RGB accent.
Offline Gerzerker
Re: [IC]Tyche75
« Reply #15 on: Fri, 12 August 2022, 02:27:36 »
This is a legit keyboard in China. Got a hold of a video in bilibili:
https://www.bilibili.com/video/BV1sg41117Qf?spm_id_from=333.337.search-card.all.click
