Author Topic: [IC] Keychron K8 Pro - Wireless/Wired TKL with QMK/VIA support  (Read 19075 times)
Offline cheswick
  • https://cheswick.dev/
    • cheswick.dev
« on: Tue, 07 December 2021, 14:01:31 »
K8 Pro
by Keychron
Keychron
Discord
  • TKL layout
  • Wireless and Wired useable
  • Connects up to 3 devices via Bluetooth
  • Out of the box QMK & VIA support
  • 5Pin ANSI/ISO hotswap PCB [southfacing]
  • Added sound absorbing foam and silicone bottom pad
  • South facing LEDs
  • Physical switch to switch between layers *Explanation down belown
  • Two-level adjustable feet
The Keychron K8 Pro is our newest addition that may revolutionize the way you use a mechanical keyboard. For the first time ever, you can enjoy both wireless connectivity and QMK/VIA customization capabilities on a Keychron keyboard right out of the box. The K8 Pro is designed to take productivity to the next level.
*You don't have to use this switch, you can also switch through the layers purely by using VIA, it's just something on top where u can switch between 2 set layers.
As an example:
Switch state 1: VIA layer 1
Switch state 2: VIA layer 3
Options
Board options
  • K8 Pro Hot Swappable RGB Backlight Barebone - Black $79
  • K8 Pro Hot Swappable White Backlight - Black $89*
  • K8 Pro Hot Swappable RGB Backlight - Black $99*
  • K8 Pro Hot Swappable RGB Backlight Aluminum Frames - Black $109*
* version including Gateron Pro switches and PBT keycaps OSA profile
Size
  • Width: 127mm
  • Lenght: 359mm
  • Front Height: 25.12mm
  • Back Height: 34.01mm
  • Feet Height: 2.7mm
  • Angle: 6 and 9 degree
  • Weight: 0.91 Kilogramm
Informations
We are working on the first prototypes; this will be an unlimited run of the board, and real-life photos of the boards will be available later.
The estimated launch for this board is expected to be Q1 2022
« Last Edit: Tue, 18 January 2022, 02:02:05 by cheswick »
Offline te-ce
Re: [IC] Keychron K8 Pro - Wireless/Wired TKL with QMK/VIA support
« Reply #1 on: Tue, 07 December 2021, 14:06:51 »
please put the USB Port somewhere on the back. All the K-Series boards with the USB port on the side look do not look good..
Offline of_sam
« Reply #2 on: Tue, 07 December 2021, 14:07:24 »
Silence brand.
Typing on: HHKB Pro 2 - Stock :aware:
Collection: F1.69, Police, Jubi, RF 87U, En Dash, Rosenthal, Soulless, Frog, Calliope, GAF 910, Sabre, W1-AT
Offline Rafa_n
  • stuffforrectangles.etsy.com
« Reply #3 on: Tue, 07 December 2021, 14:18:58 »
In terms of pricing, this doesn't seem competitive at all even with your own Keychron Q3
Offline cheswick
    • cheswick.dev
« Reply #4 on: Tue, 07 December 2021, 14:22:55 »
K8 Pro is for the people who dont need a heavy board made out of full alu. And who want to use it in wireless mode. Q3 dont offer this option atm. Q3 is more labeled for peoples home workstation for a single PC.
Offline the flying penguin
« Reply #5 on: Tue, 07 December 2021, 18:52:50 »
Where's the battery?
Offline kahlilnc
    • KNC Keys LLC
« Reply #6 on: Tue, 07 December 2021, 23:58:33 »
I owned a K6 in the past. The battery from I remember was in the board, on the left side closest to the usb port and windows/mac toggle.
Offline SDKCAMPING
« Reply #7 on: Wed, 08 December 2021, 02:01:33 »
The fact that this will come with a set of OSA keycaps is great, I am sold
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline Kaernos
« Reply #8 on: Wed, 08 December 2021, 06:31:39 »
That's not an IC, there's no room for feedback. That's an announcement.
Offline HappyB0T
  • I'm a Piggie
« Reply #9 on: Wed, 08 December 2021, 07:14:04 »
Can a mod please create a vendor forum for Keychron? Thanks.
Offline phinix
« Reply #10 on: Wed, 08 December 2021, 09:34:35 »
25.12mm front height?!
I would need a ladder to type on this... and break wrists after a minute.
Offline cheswick
    • cheswick.dev
« Reply #11 on: Wed, 08 December 2021, 13:43:21 »
If there is feedback, than this will be implemented, we started with the Q1, took feedback and made a lot of changes for it and even pushed back the release multiple months. This is just the baseline we have right now.
Offline JQ27
« Reply #12 on: Wed, 08 December 2021, 14:57:22 »
Currently use a K8 as my beater board for work so loving to see it's getting some upgraded features. Would be nice to see slight differences, such as F13 or 7u bottom row. Make it stand out a bit more. Otherwise loving the ISO support you guys do. Said it before, will say it again. Thanks for it! Much appreciated.
Offline xuyiguanyinsi
« Reply #13 on: Thu, 09 December 2021, 19:18:34 »
oh,,fianally QMK and wireless
Offline unusuaL_
« Reply #14 on: Sat, 11 December 2021, 12:03:56 »
Price kinda high for a board that is not much different to other boards in your lineup, namely the C1 and the K8. Haven't even started on the injection-molded plastic boards that are much better value.
collection: hibike 1/1, garderie tkl, casper60, hhkb pro2, matrix 2.0additional, f1-8x og
Offline cheswick
    • cheswick.dev
« Reply #15 on: Sun, 12 December 2021, 14:33:50 »
- Better switches
- double shot PBT caps insteat of ABS
- new and way better stabs
- silicon pad + new foam
- Better chip which is compatible with QMK/VIA and BT
Its an increase of 30USD
Offline deadwolfbones
« Reply #16 on: Mon, 13 December 2021, 12:18:19 »
Are the stabs plate mount or screw in?
Offline atl22033
  • Signature art by Shima
« Reply #17 on: Mon, 13 December 2021, 17:24:41 »
screw in it looks like from the pcb
Offline 4milk
« Reply #18 on: Tue, 14 December 2021, 17:08:59 »
Are they paying you yet cheswick? 18 million in revenue last year
Offline cheswick
    • cheswick.dev
« Reply #19 on: Wed, 15 December 2021, 03:50:15 »
My "payment" is 20 boards per released board Im giving them all away trough giveaways or to others who want one etc. My main job is paying pretty good and I get the chance to test out a lot of stuff like cnc cases, anodizing and other stuff without having to pay a single cent. So for me atleast to this point its fair imo but thats a personal decision I guess.
Offline cheswick
    • cheswick.dev
« Reply #20 on: Tue, 18 January 2022, 02:02:17 »
Price adjustment:
Offline Handke
« Reply #21 on: Wed, 19 January 2022, 04:02:47 »
too many keyboards, each one with a lower quality than the other
Offline cheswick
    • cheswick.dev
« Reply #22 on: Wed, 19 January 2022, 06:34:56 »
Lower quality? Keychron released the Q2 and everyone who tested it will tell you it improved, check any review out there. And those are all ICs its not those will be released all in the next 2 weeks
Offline Handke
« Reply #23 on: Thu, 20 January 2022, 03:58:55 »
When I see your website, I understand immediately that there's no clear direction in keychron work, there are what, 20 different keyboards? They want the lower tier of the market, and the enthusiasts; they offer cnc, but not in WKL because there would be too many versions while the enthusiasts want WKL because they have OG sets. It's like a schizoid timeline, with keyboards made from some OEM following the trend of the moment. They don't understand what the market wants, so they sell half finished products and see which one sells the most, and then decide to make that one and to throw away the others; it's quite crazy.
Offline HungerMechanic
« Reply #24 on: Thu, 20 January 2022, 16:44:17 »
I'm weirdly curious about this board. How well does the factory-dampening work?
It could be a basis for silent switches, or quiet down Ergo Clears. My Archon AK89 does that.
Someone commented on the height of the board. Would this be awkward on a high desk?
Offline WhatsForLunch
« Reply #25 on: Thu, 20 January 2022, 17:06:42 »
The high outside edge makes it look fugly ngl.
Offline Handke
« Reply #26 on: Fri, 21 January 2022, 02:20:44 »
Looks like a cheap frame from ikea. Screws, dust and all. Should have made the plate ticker, to stay on the same level of the border, cnc'd to 1.5mm to make the switch click in place.
Sometimes it's inspiration, sometimes it's just perspiration.
« Last Edit: Fri, 21 January 2022, 02:22:46 by Handke »
Offline synchromatik
« Reply #27 on: Sun, 13 February 2022, 02:54:09 »
Plus complete dust catcher. Pair that with some non-box switches and an average family with a kid/pet - you got yourself a maintenance nightmare of a keyboard.
Offline cheswick
    • cheswick.dev
« Reply #28 on: Tue, 15 March 2022, 08:41:58 »
Offline Handke
« Reply #29 on: Tue, 15 March 2022, 10:04:51 »
+1 This keyboard is horrible and ignores any aestethic standard. Plus it's going to be dirty and impossible to clean.
Offline Ryohka
« Reply #30 on: Tue, 15 March 2022, 16:38:01 »
So finally we have some brave people trying QMK and bluetooth together?
