Author Topic: DNA 59 Keyboard kit  (Read 6791 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
DNA 59 Keyboard kit
« on: Thu, 09 December 2021, 02:11:38 »
DNA65 has a bunch of followers among the community. It is one of the good-choice mechanical keyboards under $100.
With requests from the community, DNA59 is finally coming.
4-layer  acrylic case, aluminium-alloy plate, RGB and hot-swappable.
SPEC
  • Dimensions: 246 x 113 x 30 mm
  • Weight: 373g
  • Case: acrylic
  • Plate: anode aluminium
  • LED: 1680M RGB
  • Storage ROM: 32K ROM
Taking reference to the Preonic layout, DNA59 is designed with a 2u spacebar and 58 1u keys.  As for the RGB effect, it is basically as same as what DNA65 has, like breathing effect, wave effect, Snake effect, etc.
Kits Details:
  • Barebone Edition, you will get Kit without Keycap and switch.
  • Gateron XXX Switch Edition, you will get DNA59 Barebone Kit + Gateron XXX Switch x60
Software Download here
Purchase now
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: DNA 59 Keyboard kit
« Reply #1 on: Thu, 09 December 2021, 02:12:58 »
