Author Topic: [IC] Pengu68 - A WKL, TKL, FRL board that has a knob  (Read 2852 times)
Offline _ystem_
« on: Fri, 10 December 2021, 15:49:54 »
Hello!
279746-0
279748-1
279750-2
279752-3
So I wanted to create a FRL, WKL, TKL keyboard so I created the Pengu68. Named after your favorite clumsy clay penguin that goes "noot noot", the Pengu68 is kind of everything I want, but can't currently get.
Heres a list of features:
  • Tenkeyless (TKL) without an F-row
  • Winkeyless (may have a version for a window key not sure yet)
  • Gasket-mounted using the typical gasket strips
  • Rotary Encoder
  • 7 degree typing angle
  • 7u spacebar
  • Material will most likely be Aluminum with no plans for Brass weight option (more details below)
* thumbnail image.JPG (87.78 kB. 1378x601 - viewed 10 times.)" alt="" class="bbc_img" />
Planned Colors:
  • Black
  • White
  • Navy
Planned Materials:
  • Aluminum
I'm deciding to go with only aluminum as many manufacturers are charging more for polycarbonate. I'm also avoiding a brass weight option as I don't want to add extra cost to the board. My current target price is between $200-$250 (will change as time progresses).
Currently working on:
  • PCB (both Hotswap and Solder)
  • Prototypes (3d printed first then to the factories)
  • VIA support
  • Pengu detailing and engraving
Future:
  • Sorting out price and talking to vendors
  • Finalizing Board Design and PCB
  • Getting final renders for the board
  • LITERALLY EVERYTHING ELSE
thanks y'all and check out tauntyyt on YouTube. 279744-5
« Last Edit: Fri, 10 December 2021, 15:53:20 by _ystem_ »
Offline stidal
  • milo#3939
Re: [IC] Pengu68 - A WKL, TKL, FRL board that has a knob
« Reply #1 on: Fri, 10 December 2021, 16:05:15 »
i wish people would stop throwing knobs on the flavor of the month layout
transition tkl // aksara ce // bully // valhalla // voyager // rs60 // adiuvare // ciel60 // jules // prime e // ut47.2 // sequence // bumper // q1 // gaff60
Offline _ystem_
« Reply #2 on: Fri, 10 December 2021, 18:14:33 »
Awww man. I just want a knob on my board :(
