Author Topic: [IC] Lumberjack PCB Kit R2 - Ortholinear through-hole aesthetic 60% PCB  (Read 21987 times)
Offline peej
  • I'm a lumberjack and I'm okay
Hello Geekhack.
Earlier this year I ran a successful group buy for the Lumberjack PCB kit, we had a huge response and shipped over 150 kits to people around the World. Thanks to everyone who took part. It's been 9 months, so it's perhaps time to start thinking about a round 2.
The plan is to pretty much do the same thing as last time but with some optimisations and tweaks here and there, but if there are any suggestions for additional features or quality of life improvements, let me know in the comments below.
I need to do one more round of prototypes, so hope to be ready for GB beginning of next year so the PCB order can be run straight after Chinese New Year.
Price will be €22 + postage (€7-11) send through the mail in a padded envelope, just like last time.
Lumberjack PCB Kit
https://github.com/peej/lumberjack-keyboard
* Ortholinear 5x12 PCB (grid or 2x2u space)
* Unsoldered with all through-hole components (like the Plaid)
* Fits into tray mount 60% cases (GH60 PCB mounting points), some light switch modification will be necessary
* Kit will contain all components, acrylic component cover and associated hardware (just add switches, caps & case)
* FR4 plate (black)
* ATMEGA328P using USBaspLoader and pre-flashed with VIA compatible QMK firmware
* Mini-USB or USB-C
Changes for R2
* All kits will come with a USB-C connector. Since the majority of people wanted USB-C last time, it is no longer optional, all kits will include a USB-C connector and resistors. You will still get a Mini-USB connector and have the choice to not use the USB-C if you do not want to.
* All kits will come with FR4 plates. Since the majority of people wanted plates last time, it makes things easier just to include them for everyone this time.
* PCB revision is increased to rev1.5 (https://github.com/peej/lumberjack-keyboard#rev-15)
* The shape of the PCB will have cutouts to make it Bakeneko 60 compatible (as shown in render image below)
* PCB colour is really important to people, so the plan is to offer all the colours: black, blue, red and white like last time and now also green, yellow, and purple.
« Last Edit: Mon, 20 December 2021, 13:56:38 by peej »
Offline mmayhem17
    • Steam profile
Re: [IC] Lumberjack PCB Kit R2 - Ortholinear through-hole aesthetic 60% PCB
« Reply #1 on: Fri, 17 December 2021, 03:53:14 »
Hype
Offline stoffelduss
« Reply #2 on: Fri, 17 December 2021, 04:07:23 »
22€? woah
I don't even use ortho anymore but this looks really fun to build :) :) :) :)
Offline Klexos
« Reply #3 on: Fri, 17 December 2021, 04:40:29 »
I finally built my Lumberjack just last month and have been loving it! Count me in for another, especially with some of the included changes.
Offline guill3m
  • Shut up and take my money
« Reply #4 on: Fri, 17 December 2021, 04:42:10 »
I was too slow last time, won’t happen this time. Thanks for adding more colours, eyeing the yellow  ;D
Offline DerBonk
  • I'm just this guy, you know.
« Reply #5 on: Fri, 17 December 2021, 06:08:20 »
In for two more! My favorite >40% board. Thanks so much for running it again!
Offline Alejo1707
  • Gimme some more caps!
« Reply #6 on: Fri, 17 December 2021, 06:32:40 »
You know I'll be there sir!
Sent from my GM1917 using Tapatalk
Offline Tinoo46
« Reply #7 on: Fri, 17 December 2021, 08:04:53 »
When will the GB start? I am interessed
Offline robotictomato
« Reply #8 on: Fri, 17 December 2021, 09:46:11 »
Very interested. Any chance of adding support for Choc switch footprints in as well?
Offline YoungTerror
« Reply #9 on: Fri, 17 December 2021, 10:05:01 »
Yes yes yes I've been waiting for this. +1 from me.
Offline AlexLimPage
« Reply #10 on: Fri, 17 December 2021, 11:29:08 »
Hell yes, count me in.
What other cases would this lovely fit in except Bakeneko60?
Offline bloodparticle
  • A through hole keyboard fan!
« Reply #11 on: Fri, 17 December 2021, 11:50:11 »
I'm in! o(^▽^)o
Offline Alejo1707
« Reply #12 on: Fri, 17 December 2021, 11:56:59 »
Any tray mount sir, for those, you don't even need switch plates, given you solder the switches of course
Offline peej
« Reply #13 on: Sat, 18 December 2021, 06:47:16 »
I hadn't even considered Choc switches, they are not something I am familiar with. It feels like you can create a hybrid footprint without too much trouble.
Do people use the V1 switches or is it all about V2 now? Presumably for V2 the switch spacing and plate cutouts are the same as for MX?
Offline ILikeShorts
« Reply #14 on: Sun, 19 December 2021, 10:38:28 »
I’m such a fiddler, and I’ve yet been able to commit to a build with soldered switches. Any interest in making a hotswap version? I’ve been trying to will myself to commit to soldering switches in because I love the throughhole aesthetic.
Offline Alejo1707
« Reply #15 on: Sun, 19 December 2021, 11:14:24 »
Why not mill-maxing the PCB? Those are already superior to Kaihl hot-swap sockets either way.
Offline ggggggg
  • schmeiß die forties durch den club
« Reply #16 on: Sun, 19 December 2021, 12:11:30 »
Except in terms of cost.
Offline Alejo1707
« Reply #17 on: Sun, 19 December 2021, 13:01:29 »
0305 sockets cost 12 cents per-socket approximately, without shipping considered. 150 for a full Lumberjack build will set you back 17.70 USD.
Kaihl hot-swap are 1.50 for 10. 9 bucks for 60 sockets. You have a difference of 8.70 dollars for less resilient and less compatible sockets. Not worth IMO, and as demonstrated, not really an issue of cost either.
EDIT: removed caps from "socket"
« Last Edit: Sun, 19 December 2021, 13:42:53 by Alejo1707 »
Offline ggggggg
« Reply #18 on: Sun, 19 December 2021, 14:54:54 »
I'm not here to argue Kailh over MillMax sockets, the latter are obviously better. But they are twice as expensive, and that's for 0305 as you say, which come with their own caveats.
On a potentially cheap build like this, 25c extra per switch is kind of a lot. I think it's worth considering a north-facing Kailh hotswap socket footprint to supplement the soldered footprint.
Offline qeebored
« Reply #19 on: Mon, 20 December 2021, 14:40:29 »
I would love to see support for Alps switches, maybe something like Kyria's MX/Choc/Alps footprint,.
Offline Quni
« Reply #20 on: Tue, 21 December 2021, 05:17:26 »
Let's GO! Definitely in.
Offline zwartho
« Reply #21 on: Tue, 21 December 2021, 17:28:06 »
I was also too slow last time. Is the max order quantity still going to be the same?
Offline lunatictaco
« Reply #22 on: Tue, 21 December 2021, 17:58:22 »
Can’t wait for this one again
Offline Mecxs
« Reply #23 on: Tue, 21 December 2021, 21:14:29 »
Definitely keen - would be great to see Rosaline kits available too if that's still a possibility!
Offline XCaellaX
« Reply #24 on: Wed, 22 December 2021, 02:08:51 »
Super interested! Would finally be able to test ortholinear layout on a Tofu60.
Sent from my XQ-AS52 using Tapatalk
Offline peej
« Reply #25 on: Wed, 22 December 2021, 06:33:35 »
I'm looking into using a hybrid MX/Alps/Choc footprint, it makes sense to add Alps and it'd be nice to also support Choc v1 too. I don't think Choc v2's are compatible with MX footprints which seems a shame.
I'm hoping to be able to go unlimited quantity this time having learnt from round 1. The main issue is putting the kits together, but I can package and ship orders as I complete them like I did with the extras from R1, so some people might have to wait longer than others but I won't have to turn people away.
This could definitely be a thing for those who want one since it's just a different PCB and component cover. You'd probably have to build and flash the firmware yourself however. If there's only a few people interested, I have a few prototypes that people could have once I have components.
Offline tiramichu
« Reply #26 on: Fri, 24 December 2021, 10:45:05 »
Definitely interested in Rosaline as well! And I'll be in for another Lumberjack, too  :)
Offline iwanoo
« Reply #27 on: Sat, 25 December 2021, 10:33:07 »
I would be in for a purple Lumberjack and Rosaline :)
Offline AlexLimPage
« Reply #28 on: Sat, 25 December 2021, 10:43:25 »
I'm in super FOMO mode!!
When would it be ready for GB? I keep checking this page almost two-three times loool please at least give us a date.
Offline Frayne
  • For deskmat inquiries: illu_zn
« Reply #29 on: Sat, 25 December 2021, 16:58:50 »
Oooo lets gooooo ive been waiting for this
Offline peej
« Reply #30 on: Sun, 26 December 2021, 03:39:27 »
I've added Alps and Choc footprints and ordered a prototype PCB from JLCPCB.
GB will be in the new year, depends on how long the the prototype takes to arrive. If you are worried about not seeing the GB, I have a mailing list you can join which I'll send an e-mail to when the GB goes live: http://eepurl.com/hyPSt9
Offline AlexLimPage
« Reply #31 on: Sun, 26 December 2021, 03:43:55 »
awesome, thanks for the mailing list.
Offline Alejo1707
« Reply #32 on: Sun, 26 December 2021, 07:45:17 »
BTW, and to anybody that is interested. A while back I asked peej to help me with a plate that can be used on a Cannon Keys Brutal60 case. I still have the files and the boss can help you with those as well.
Unfortunately I have not been able to test them yet, but the public files for those plates were used to create them. Hopefully it will serve somebody else <3
Offline Magnificent Bureaucrat
  • Sooooo much red tape
« Reply #33 on: Sun, 26 December 2021, 11:03:26 »
I'd also be interested in a lumberjack/rosaline multi-pack. Both such cool ideas
Offline HappyB0T
  • I'm a Piggie
« Reply #34 on: Mon, 27 December 2021, 19:12:45 »
I have 2 printed bakeneko cases on hand - this would be super fun to try out. I'll take 1 or 2 :D
« Last Edit: Mon, 27 December 2021, 19:15:42 by HappyB0T »
« Reply #35 on: Sun, 02 January 2022, 15:47:17 »
So the leds are for: plug and caps right? Thinking to make it all white, yap will use white leds 😉
Offline orange.island
« Reply #36 on: Tue, 04 January 2022, 22:54:05 »
Wow, THT board with case? I'm in! Just one minor question: what are the color options for PCB??
« Reply #37 on: Wed, 05 January 2022, 14:30:28 »
The FR4 plates will be in the color of the pcb or only black?
Offline bigoldbox
« Reply #38 on: Wed, 05 January 2022, 21:43:20 »
Will there be a NA vendor or is it retailed from you directly?
Offline peej
« Reply #39 on: Thu, 06 January 2022, 09:09:21 »
The default firmware has one LED activate for any keypress and the other for layer change, but you can of course change them to whatever you want in QMK.
Black, white, blue, red, yellow, purple, or green. Although if only a few people want a certain colour, I might drop it.
I had some issues with the white soldermask in the last round, lots of PCBs where the soldermask had filled the switch holes or had marks in it, but people seem to love white so I'll just have to ensure I order plenty of spares.
All the plates will be black.
Not sure yet, could be possible if there is demand and it makes financial sense. Since the majority of the GB time is me putting kits together and packaging them up, I'm planning on shipping kits as they are complete rather than waiting for them all to be done like last time. Orders via a proxy would have to all be done at once and thus would be quite a bit slower into people's hands, but if it saves on postage it might be preferable for some people.
Offline skurvi
« Reply #40 on: Sun, 09 January 2022, 04:18:22 »
I am so in. Have been waiting for this since the day I realized I missed r1 😄
Offline ravenousrhino
« Reply #41 on: Wed, 12 January 2022, 02:18:55 »
Can you add an option to order extra plates. I was able to get 2 lumberjacks last time due to extras but they didn't come with plates. I'm planning on getting a new color this time but I also hope I could get extra plates for the ones I already have.
Offline panka
« Reply #42 on: Wed, 12 January 2022, 05:00:00 »
i want it i want it i want it i want it i want it i want it i want it
Offline nahccire
« Reply #43 on: Thu, 13 January 2022, 12:27:00 »
I'm in, also what do you think about adding different plate materials (brass, pom, etc)
Offline peej
« Reply #44 on: Thu, 13 January 2022, 13:54:03 »
Received the prototypes from JLCPCB but haven't had time to put one together yet. The bottom side silkscreen looks nice without being annoying or over the top. Not sure that I'm a fan of the yellow soldermask
Of the 5 proto boards, 3 had issues with the drilling of the USB-C pin holes, I'm in communication with JLCPCB about this cos that's a pretty big failure rate that'd be a real bummer on a production run.
Testing the fitting of Choc switches. I had an extra support pin drill hole in my footprint which I think is for v2 Choc switches which are not compatible anyway, so I will be removing that extra hole unless I'm missing why it's there.
The addition of Choc switch footprints mean that both MX and Choc switches don't grip into the PCB as well as previously, but the plate helps keep them aligned.
There'll be a free text box in the order form where you can ask for extra things (as long as you know the secret handshake).
Not gonna happen I'm afraid, just trying to keep things simple for myself.
Offline jonathanraime67
« Reply #45 on: Thu, 13 January 2022, 16:11:49 »
I was going to purchase the keebd.com lumberjack kit so this is exciting news!!
Offline qeebored
« Reply #46 on: Thu, 13 January 2022, 16:37:34 »
I'm happy you added Alps footprint to the PCB, but remember to also make Alps plates. The holes need to be a bit different for Alps switches than for MX.
Offline SyzygyXVII
« Reply #47 on: Thu, 13 January 2022, 19:42:37 »
Count me in.  Missed R1 so looking forward to supporting R2.
Offline peej
« Reply #48 on: Fri, 14 January 2022, 12:42:40 »
That's a good point. I don't have any Alps switches to test with, can I get away with just making the switch holes wider or do I need to have the corners shaped like SwillKB plate builder shows? I'd rather avoid having to have a different Alps plate, but I want to ensure that it will actually hold Alps switches securely.
Offline TheWonderBubble
« Reply #49 on: Fri, 14 January 2022, 18:39:40 »
Already holding 2 of the V1's waiting on cases to come in to build them out, but you have me for at least a 3rd with the Bakeneko 60 compatibility, possibly even a 4th to send a build or two out to some friends!
Shhhhh...my wallet doesn't know I'm here.
