Author Topic: [IC] Polaris V2 - Reference 60% Keyboard - Updated based on survey data  (Read 124466 times)
Offline ai03
  • I do not reply to PMs; contact me via website
    • Website
Polaris V2
Reference 60% keyboard by Kevinplus and ai03
In 2019, we changed the keyboard scene forever with the release of Polaris, bringing much-acclaimed typing acoustics and comfort in an accessible package which holds its own even today.
Fast-forward three years, and Polaris is back - retaining everything that made the original legendary, while redesigning it thoroughly to stand yet again as a reference against ever-evolving standards.
Latest status:
- Units will be produced with and without rear logo
- Hotswap PCB has been changed to default 2U backspace with optional 1U positions
- Base kit now has a choice between hotswap and soldered options.
Details here
To improve communications, all updates regarding this project will be centralized on its webpage and mirrored to Discord for push notifications.
Since I often forget to check and post updates to every single location, please use the update page for guaranteed latest status updates.
Top-Tier Typing For All
Polaris V2 brings the battle-tested fully isolated gasket-mounted internals from Vega back to the original 60% form factor, with tweaks to further enhance acoustic performance while maintaining its absolute comfort for countless hours of usage.
With improvements to ease of assembly, Polaris V2 ensures that you can enjoy the input benefits regardless of keyboard experience.
Reference Aesthetic Outside and In
The proven elegant, clean, and minimal exterior free of any visible screws has received much-needed modernization from Vega, while quietly improving internally for streamlined manufacturing and simplified assembly.
Along with its matte PVD-coated stainless steel weight, Polaris V2’s visuals are designed to withstand the test of time, carrying its elegance forward many decades while blending seamlessly into any environment.
To Fulfill Your Desires
Every custom keyboard is different, and Polaris V2 is designed to be different - with multiple plate options, optional hotswap standoffs, and three optional layers of internal foam, you can tune Polaris V2 exactly the way you desire, ranging from anywhere between switch choice tester to dialed-in finalized build.
Every small detail was designed with much care to make Polaris V2 your ideal keyboard, down to the custom-designed screws, custom-designed rubber feet, and accent logo on the rear.
Hassle-Free Yet Extensible
The thin, flex-slotted hotswap PCB comes ready-to-go out of the box with VIA Configurator compatible firmware, requiring no soldering or driver headaches to assemble.
A solderable PCB kit is available for those who prefer to tailor the layout exactly to their preferences, and a much-requested replaceable USB daughterboard aids in extending the lifespan of the board.
Preparing For What’s Next
A lot has changed since 2019 when Polaris V1 was announced - the keyboard community has grown exponentially, the world has changed permanently, and keyboard variety has skyrocketed.
We’ve combined both everything we’ve learned as well as brand-new knowledge to create the successor of the board which started our journey. Albeit against high expectations, we’re confident that Polaris V2 will fit in as a faithful member of your keyboard collection both for the present and for the future - whether as your single endgame build or among a family of other boards.
Specifications
Case weight: ~1.2kg
Plate materials: Aluminum, Polycarbonate
Case top variants: Regular, WKL, Corner Blocker
Case colors: Black, Grey, White, Yellow-Orange, Red, Blue
Dimensions: 296 x 110 x 28mm
Typing angle: 6.5deg
Sale method: To be announced
Price: To be announced
Vendor: TypePlus
Stock configuration: Case + choice of either hotswap PCB + hotswap plate kit or solderable PCB + universal plate kit
Hotswap PCB layout:
Solderable PCB layouts:
« Last Edit: Sat, 25 December 2021, 04:33:59 by ai03 »
Offline ai03
    • Website
Re: [IC] Polaris V2 - Reference 60% Keyboard
« Reply #1 on: Tue, 21 December 2021, 17:04:22 »
Reserved just in case
Offline unusuaL_
« Reply #2 on: Tue, 21 December 2021, 17:06:56 »
Yes please
collection: hibike 1/1, garderie tkl, casper60, hhkb pro2, matrix 2.0additional, f1-8x og
Offline Gavzers
« Reply #3 on: Tue, 21 December 2021, 17:07:54 »
I've been waiting for so long and it's finally here. Can't wait for more details!
Offline MonsterM
« Reply #4 on: Tue, 21 December 2021, 17:08:09 »
Yes!!!
Offline Sax_______
« Reply #5 on: Tue, 21 December 2021, 17:08:25 »
I'll take 2
Offline ilikerustoo
« Reply #6 on: Tue, 21 December 2021, 17:08:25 »
Nice
Offline are2dcrz
« Reply #7 on: Tue, 21 December 2021, 17:08:41 »
Of course!!!
Offline novelflyer
« Reply #8 on: Tue, 21 December 2021, 17:09:31 »
Nice   :D
Offline Zyrophr
  • https://zyrophr.com
    • zyrophr.com
« Reply #9 on: Tue, 21 December 2021, 17:10:38 »
I'm in.
French keyboard streamer
Offline Woovie
« Reply #10 on: Tue, 21 December 2021, 17:12:33 »
back engrave bad
Offline OJtheTiny
« Reply #11 on: Tue, 21 December 2021, 17:15:02 »
god I really wish the back engraving wasn't there, just destroys the otherwise clean and minimal look
Offline sourmk
« Reply #12 on: Tue, 21 December 2021, 17:16:50 »
Been wanting one since the original run. Looking forward to this. Will the available the colors be ano or planning some coats also? Going right to buy or showing protos prior? The V2 on the rear provides a little visual imbalance imho. Cheers
Some Work: GMK Wasabi | GMK Pono | GMK Dandy | ePBT DuO | GMK Hooty | Petals Sixty
Some Collabs: ePBT Ivory | GMK Deep Navy | GMK Fundamentals | GMK Polybius | GMK Blurple | GMK Deepwell | GMK Fuji | GMK Pacific
Some Boards: Daji Seis Cinco, Ocho Quattro, Seis Cero | MatrixLab 2.0 ADD + CP, 2.0 Xmas + CP, 1.2OG | Keycult 1/60 | Hiney Ladybird | QXP | Noxary 268.2
Discord - https://discord.gg/j3PxfJ4rBC | Instagram - https://instagram.com/sourmk | Web - https://www.sourmk.com/
Offline two
« Reply #13 on: Tue, 21 December 2021, 17:17:36 »
yes please
Offline sub0001
« Reply #14 on: Tue, 21 December 2021, 17:19:28 »
hot damn, this is going to be huge.
that said, echoing those above me re: the engraving. does not fit with the clean look of the case at all, in my opinion.
« Last Edit: Tue, 21 December 2021, 17:24:43 by sub0001 »
Offline ddnomad
« Reply #15 on: Tue, 21 December 2021, 17:21:35 »
Yes please
Offline solarce
« Reply #16 on: Tue, 21 December 2021, 17:23:54 »
so good
Offline wired
« Reply #17 on: Tue, 21 December 2021, 17:30:52 »
can't wait!
Offline Entity.
  • Entity#1234
« Reply #18 on: Tue, 21 December 2021, 17:36:32 »
OMG YES!
Offline 7empest
  • ༼ つ ◕ ◕ ༽つ
« Reply #19 on: Tue, 21 December 2021, 17:37:48 »
this is cool but i will admit, i could do without the engraving on the back
« Last Edit: Tue, 21 December 2021, 17:42:49 by 7empest »
Offline of_sam
« Reply #20 on: Tue, 21 December 2021, 17:37:55 »
Definitely interested in picking one of these up. I agree with Sour, not crazy about the logo on the back. Am I understanding correctly that you’re forcing split backspace in the stock configuration? I guess I get you’re going off survey results but that seems kind of extreme.
Typing on: HHKB Pro 2 - Stock :aware:
Collection: F1.69, Police, Jubi, RF 87U, En Dash, Rosenthal, Soulless, Frog, Calliope, GAF 910, Sabre, W1-AT
Offline benox
« Reply #21 on: Tue, 21 December 2021, 17:43:58 »
Been waiting for this!  :thumb: ;)
Offline 7empest
  • ༼ つ ◕ ◕ ༽つ
« Reply #22 on: Tue, 21 December 2021, 17:47:22 »
I am surprised by this myself. I did not think split backspace would be as popular. This stock hotswap layout is exactly how I use all of my 60% boards with one exception, stepped capslock. I just cant bring myself to use a non-stepped capslock configuration these days, so I will still have to buy the solder pcb.
Offline santela
« Reply #23 on: Tue, 21 December 2021, 17:47:37 »
This. Split backspace users seem to be a minority.
Offline ai03
    • Website
« Reply #24 on: Tue, 21 December 2021, 17:52:10 »
Regarding the engraving on the rear, I decided to add it knowing that it would yield mixed opinions. The biggest reasons for adding it were being able to differentiate the board from the original V1 without lifting the board off the desk, and that it looked fairly nice in a physical prototype sample. Managed to lose the photo somehow the night before the IC, so I'll post it if I come across it again and remember to do so.
Since it's on the rear entirely out of view from regular use positions, hopefully it'll be one of those things ignored 99.9% of the time.
Yes; as much as I'm a 2U backspace user myself, I decided to opt for popular choice and maximizing functionality for the default configuration.
Regular backspace is available via the solderable PCB.
The yellow-orange will likely end up being via a very fine powdercoat which Kevinplus has tested in person and recommends visually; the white is still being decided between the previous e-coat and the new powdercoat. The rest will be anodized as usual.
Offline mr_foggy
  • neue = nope
« Reply #25 on: Tue, 21 December 2021, 17:54:29 »
everything is absolutely perfect, but add stepped capslock in the stock configuration and I'll buy two.
best news I've heard today
Offline brudder
« Reply #26 on: Tue, 21 December 2021, 18:02:23 »
Can't wait for this! Love the inclusion of a daughterboard and split BS coming standard with HS :)
Offline uhugo
« Reply #27 on: Tue, 21 December 2021, 18:04:00 »
Yes! :) Love to see forced split BS on the HS pcb
« Last Edit: Tue, 21 December 2021, 18:06:14 by uhugo »
Offline snicket
  • Formerly lucalink
« Reply #28 on: Tue, 21 December 2021, 18:07:40 »
yes please!
Offline vicious7
« Reply #29 on: Tue, 21 December 2021, 18:25:11 »
Ah man, another 60? I already have 5!
Okay, Im in...
Offline heyimpanda
« Reply #30 on: Tue, 21 December 2021, 18:37:25 »
technically wouldn't the USB port positioning also differentiate the board? I suppose that would be a lot more subtle, but the engraving does kill a lot of it for me unfortunately. Maybe I'll reserve my opinions until you manage to find that photo though, but I am in the group of disliking it.
Offline dino97
« Reply #31 on: Tue, 21 December 2021, 18:49:21 »
not a big fan of the 'polaris v2' engraving
« Reply #32 on: Tue, 21 December 2021, 19:08:29 »
incredible bait
Offline brantaniguchi
« Reply #33 on: Tue, 21 December 2021, 19:28:04 »
That back engraving is an odd, and to be honest, somewhat lazy choice. If it were an interesting design to give it some flair, sure. But just putting POLARIS V2 is pretty lame.
If I'm going to enter a GB that is going to take over a year I need to really be into a board. Unfortunately that engraving ain't it.
Offline Tulesto
« Reply #34 on: Tue, 21 December 2021, 19:34:16 »
I don't mind the back engraving as much as the others seem to. I will for sure be picking one up! Excited for the GB!
Sangeo/Suit/Spring/Angle/CW88/Kohaku/Unikorn/Navi/Corsa
Offline Draxion
« Reply #35 on: Tue, 21 December 2021, 19:34:58 »
Time to start collecting Polaris, got v1 now I need v2
Offline GMK83
« Reply #36 on: Tue, 21 December 2021, 19:45:53 »
I have the V1 but that back engraving on the V2 is a hard pass for me.
Offline ChrisJoy
« Reply #37 on: Tue, 21 December 2021, 19:50:45 »
I'm still waiting for the shipment of VEGA 65.
Offline hottnucks
« Reply #38 on: Tue, 21 December 2021, 20:15:57 »
Please ditch the 'polaris v2' engraving on the back
Offline hover0423
« Reply #39 on: Tue, 21 December 2021, 20:21:04 »
I am in for the red
Offline nasp
« Reply #40 on: Tue, 21 December 2021, 20:25:26 »
Will you please make the plate file available to modify? I'd like to make a Plexus75 type plate for this.
Thanks for considering ai03!
Offline SE7EN_ate_NINE
« Reply #41 on: Tue, 21 December 2021, 20:25:46 »
I have to echo all the others that I'm not a fan of the back engraving at all. The reference boards (I own both a Vega and Polaris and love them) are classic, classy and clean and that logo just looks like a cheesy afterthought detracting from a very clean and evolved design. You've earned your place high at the top of the ranks of respected designers in this hobby, no need to remind us what board we're typing on by the rookie designer move of plastering the board name on the board. Keep it clean.
I 100% applaud the 7U, split right shift and split backspace on the hotswap as standard though. Switching to stepped caps (or both sockets for both caps) would make it even more perfect, but certainly not a deal breaker.
One last thing...bring back purple!!
Offline bluuz
« Reply #42 on: Tue, 21 December 2021, 20:28:04 »
Could we have clearer renders of the different colors?
Is split backspace really that more popular? That's a head scratcher.
Offline bigapplepietart
  • Topre Convert
« Reply #43 on: Tue, 21 December 2021, 20:37:08 »
Very clean
Current:
Heavy Grail (Purple DES V1) | hiney tkl one PC (Orange SKCM Alps) | Lunar II (Green SKCL Alps) | Sho S60 V2 (Purple DES V1) | HHKB Hybrid Type-S (45g Stock Domes)
Past:
Razer Blackwidow (MX Blues) | FC660M (MX Blues) | GH60 (Ergo Clears) | 8x mkI (Vintage Blacks) | Klippe (Sakurios) | Equinox (Sakurios) | MGA (Silent Alpacas) | Kei (Creamsicles) | KFE CE (Alpacas) | Rukia R1 (Durock L7) | H60 (Silent Blacks) | E80-1800 (MX Blacks) | Ottantaquattro (Vintage Blacks) | hbcp (Vintage Blacks) | HHKB Pro 2 (45g Aged Domes) | ADK64 (Blue SKCM Alps) | Palmetto (Ultraglides)
Offline aaronlau
« Reply #44 on: Tue, 21 December 2021, 21:13:24 »
Hopefully in stock option!
Offline yuki9609
« Reply #45 on: Tue, 21 December 2021, 21:18:24 »
nice! very good.
« Last Edit: Tue, 21 December 2021, 21:49:28 by yuki9609 »
Offline Techlet
« Reply #46 on: Tue, 21 December 2021, 21:36:44 »
Fantastic board as always from ai03. It's just a shame about the back engraving. Having the "v2" there date stamps and cheapens the board when it's supposedly "designed to withstand the test of time."
Feels unnecessary when it's already engraved internally on the weight.
People aren't going to mistake this for anything other than a Polaris when looking at it from the back. And the screwless exterior and center USB port should be more than enough to differentiate this from the v1 Polaris.
Offline PuddingPug
« Reply #47 on: Tue, 21 December 2021, 21:53:56 »
Can't wait to have this next to my Polaris v1! :D
Offline Tree_
« Reply #48 on: Tue, 21 December 2021, 22:17:07 »
Not a fan of the engraving.
Not a fan of split backspace being the default.
Not a fan of the fact that there's a rose gold render shown but it's not an available colour.
Other than that I love everything about this.
Offline santela
« Reply #49 on: Tue, 21 December 2021, 22:25:44 »
The Vega is such a classy board with its seamless screwless design and simple yet classic aesthetics.
The Polaris is everything the Vega is, except for the engraving. It is really unfortunate as it cheapens the board.
