Author Topic: [IC] Fox Lab - Sand Glass Ergo (GB soon)  (Read 54600 times)
Offline senter
« on: Wed, 29 December 2021, 14:29:09 »
Our First Ergo Layout Kit
Render:
Prototype:
Sand Glass Ergo is an 80% ergonomic layout keyboard kit design we designed in collaboration with designer KeepCalm.
I've always been hoping to create an ergo kit, and this is my first attempt.
We name this kit Sand Glass Ergo for the shape of its top exterior outline.
Layout
Even though I've been using an Alice-like layout (60% with arrow keys) keyboard for more than half a year now, I'm less experienced with ergo layout keyboards in general.
The present layout is obviously similar to many existing kits, but it is also personalized to KeepCalm's and my preferences.
This design isn't outrageous or exaggerated in any way.
We hope that it will be a board that most people can quickly become accustomed to, and that it will be a board that most people, including me, are willing to use as a daily driver.
That being said,
Plate & mounting & Structure
I like the skeleton plate design that we initially tested on Leaf 65.
Skeleton plates with improved flexibility will be available on Sand Glass Ergo.
The PCB will be 1.2mm thick for softer bottom out with the skeleton plate.
The mounting method is PORON sandwich.
To make the typing experience as even as possible, both the PCB and plate have been split into left and right parts.
Wrist Rest
Although the front of the board is not particularly high (18mm), I found that a wrist rest is still necessary for maximum comfort.
Because there is no compatible wrist rests on the market, the kit includes a specially developed wrist rest.
The kit was named Sand Glass also because of the way it looks with the wrist rest.
Forged Composite is considered as the material for the wrist rest.
Basic information:
1. Typing angle: 8 degree
2. Front height: 18mm without the wrist rest
3. Estimated price: 525 USD for the kit with the wrist rest
Highlights:
1. 80% Ergo layout
2. PORON sandwich + skeleton plate
3. No visible screws
To Do:
1. Collect feedbacks
2. Finish the skeleton plate design
3. Prototyping
We have a discord server now: https://discord.gg/gr6ZBB9xXy
« Last Edit: Sat, 07 May 2022, 20:08:45 by senter »
Offline pngu
  • send noots
Re: [IC] Fox Lab - Sand Glass Ergo
« Reply #1 on: Wed, 29 December 2021, 14:37:19 »
https://en.wikipedia.org/wiki/Farfalle
Offline MIGHTY CHICKEN
« Reply #2 on: Wed, 29 December 2021, 14:38:30 »
So down for this
Offline Vono
« Reply #3 on: Wed, 29 December 2021, 14:40:04 »
Looking nice, definitely an unique layout  :thumb:
« Reply #4 on: Wed, 29 December 2021, 14:40:35 »
Looking good!! Love my ergo tkls
Sent from my SM-N975W using Tapatalk
Offline lukelex
« Reply #5 on: Wed, 29 December 2021, 14:41:08 »
I’m in
« Reply #6 on: Wed, 29 December 2021, 14:47:42 »
unironically i think this board is a perfect candidate for second Y
still rules regardless. fox lab forever
Offline CookieFlow
« Reply #7 on: Wed, 29 December 2021, 14:50:41 »
Looks very good.
But I would maybe look into another accent color than black for the blue and beige models.
The Black/Red and White/Black works really well, but I feel there could be a better match than black for the blue and beige ones.
Offline Damage
« Reply #8 on: Wed, 29 December 2021, 14:57:53 »
I just got ~$525 lighter, at some point in 2022. :)
Offline Zurg Eon
« Reply #9 on: Wed, 29 December 2021, 15:07:33 »
Looks good! Thank you for bringing the left spacebar closer to the centre. It's really what's missing from the standard alice layout.
Offline dudewth
« Reply #10 on: Wed, 29 December 2021, 15:19:31 »
Nice! I'm interested
Offline Zyrophr
  • https://zyrophr.com
    • zyrophr.com
« Reply #11 on: Wed, 29 December 2021, 16:11:37 »
Looks cool with the wrist rest!
French keyboard streamer
Offline zea
  • yeh
« Reply #13 on: Wed, 29 December 2021, 16:48:50 »
would it be possible to have the option of a 1u key next to the left spacebar instead of the 1u key next to the right spacebar?
Offline vi0till
« Reply #14 on: Wed, 29 December 2021, 21:18:32 »
This will be all aluminum construction with no weight? Also, would appreciate if you can consider to use unified daughterboard.
Offline UberPlatypus
« Reply #15 on: Wed, 29 December 2021, 22:53:38 »
Was the name perhaps meant to be Hourglass which is the name of the object in reference I presume?
Personally I think it sounds better too.
Great looking board! Very inclined to get one.
Sent from my HD1925 using Tapatalk
Offline catamscott
« Reply #16 on: Wed, 29 December 2021, 23:15:07 »
looking super nice. curious to see what the color and plate material options will be
Offline tngpq
« Reply #17 on: Thu, 30 December 2021, 00:06:26 »
Any chance of full right shift?
Offline lovetree
« Reply #18 on: Thu, 30 December 2021, 03:28:27 »
I'm in!  :thumb: :thumb: :thumb: :thumb: :thumb:
Offline the_useless_turtle
« Reply #19 on: Thu, 30 December 2021, 04:29:27 »
I really like how this looks, I am just a little worried about its size. 80% Ergo sounds like it will be really wide. Any info on dimensions yet?
Offline Faceman76
« Reply #20 on: Thu, 30 December 2021, 04:43:13 »
This is absolutely beautiful.
Sent from my SM-G975U using Tapatalk
1800s and heavy springs
Offline darthcapn
« Reply #21 on: Thu, 30 December 2021, 04:57:44 »
Lit! Waiting for gb!
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline kisstheringz
« Reply #22 on: Thu, 30 December 2021, 08:54:31 »
This nice.
Offline Damage
« Reply #23 on: Thu, 30 December 2021, 10:42:08 »
Hey, folks. Just a quick note. Not sure whether it's been pointed out yet or not, but the name "sand glass" is probably not the best choice. In English, we'd typically call this sort of sand timer an "hourglass." The "hourglass" shape is commonly referenced to describe objects with this sort of profile.
I don't know if it matters or is too late or whatever, but calling it "hourglass" might be more elegant and appropriate in English.
« Last Edit: Thu, 30 December 2021, 10:44:28 by Damage »
Offline deathjester
« Reply #24 on: Thu, 30 December 2021, 12:57:36 »
I need one of these!
Offline OhKeycaps
    • OhKeycaps
« Reply #25 on: Thu, 30 December 2021, 13:25:35 »
I don't think I'll ever understand the whole 'B' on both sides thing. Just learn to use your left hand for b and be done with it.
Offline aa212121
« Reply #26 on: Thu, 30 December 2021, 13:30:34 »
i like sand, and glass too; but "egg timer" sounds way better than both sandglass or hourglass.
Offline Faceman76
« Reply #27 on: Thu, 30 December 2021, 14:26:32 »
It's tough to un-learn after 30 years of touch typing the wrong way.
« Reply #28 on: Thu, 30 December 2021, 15:35:52 »
Absolutely agree. Especially when adding Ergo to the end. Saying 'Hourglass Ergo' or referring to the board "Hey have you seen the new Hourglass Ergo" etc may be a bit more appropriate.
Offline Tree_
« Reply #29 on: Thu, 30 December 2021, 17:46:56 »
This is the one. Forget all the Hourglass requests.
Offline Ashardalon
  • Ashkeebs
    • Ashkeebs Lubing Service & Shop
« Reply #30 on: Thu, 30 December 2021, 21:00:49 »
As always, Fox Labs continues to impress! The layout is well done and the wrist rest designed along with it is fantastic. I've just recently started typing on an AVA and certainly wouldn't mind having a rest for it, so this will be a welcome addition for the Sand Glass Ergo.
Offline hottrout
  • I'd Hit Dat Key
« Reply #31 on: Fri, 31 December 2021, 04:34:48 »
Hell yes.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline OhKeycaps
    • OhKeycaps
« Reply #32 on: Fri, 31 December 2021, 11:19:56 »
When I was about 27 I switched to a split kb. I realized right away that I had been typing 'Y' with my left hand instead of my right. I got used to typing the right way within a day or two. So I don't really buy what you're saying. People just don't want to attempt to make the change, but it's really not hard.
Offline DraconicVision
« Reply #33 on: Fri, 31 December 2021, 12:00:16 »
Dude this is sick!
I am super interested, how can we get pinged when this drops for GB?
Offline avtar
« Reply #34 on: Fri, 31 December 2021, 14:09:37 »
This looks great but I feel the 1u key should be next to the left spacebar instead of the right one. The right side of the keyboard already has a Fn key. The left side could use that botton row Fn key.
Offline Poesjuh
« Reply #35 on: Sat, 01 January 2022, 17:48:31 »
Hot. Friggin unit but hot.
Offline Tyson
« Reply #36 on: Sat, 01 January 2022, 18:08:09 »
100% will be jumping on this one! Can't wait!
Offline peacdesign
  • Design Studio
    • Peac Design
« Reply #37 on: Sat, 01 January 2022, 18:12:53 »
Great looking board! Individual plates for each half looks interesting and look forward to seeing more!
Offline geshuni
« Reply #38 on: Sun, 02 January 2022, 00:32:35 »
I'm interested. This would be my first ergo board =)
Offline gloomycloud
  • me enjoy 60s
« Reply #39 on: Sun, 02 January 2022, 02:52:05 »
A separation between insert-home cluster and print screen cluster would be nice, it looks too busy now
HHKB Pro Hybrid || Polaris || Kei || Meridian || Leviatán
Offline Faceman76
« Reply #40 on: Sun, 02 January 2022, 10:22:30 »
That separation is helpful for touch typers.
Offline 10peaches
« Reply #41 on: Sun, 02 January 2022, 19:03:59 »
Please make the right spacebar compatible with 2.75u too. As a right thumb spacebar user, this is very important for me.
Offline linell
« Reply #42 on: Mon, 03 January 2022, 04:45:37 »
best layout ever  :-*
bro this a **** set, just be thankful you even getting 1 base running fr
Offline maximm
« Reply #43 on: Mon, 03 January 2022, 05:09:10 »
ISO option please
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #44 on: Mon, 03 January 2022, 10:19:41 »
«How much wood could a woodchuck chuck if a woodchuck could chuck wood?»
Offline Nurseh
  • Sorry for always apologizing
« Reply #45 on: Mon, 03 January 2022, 10:27:42 »
Snazzzy, I like it. Good work!
Offline senter
« Reply #46 on: Mon, 03 January 2022, 14:05:36 »
I'm not sure about this. Isn't an hourglass basically a sandglass that can count for about 1 hour?
Offline senter
« Reply #47 on: Mon, 03 January 2022, 14:08:01 »
ISO option please
Hmm, that will need a different top case.
Offline senter
« Reply #48 on: Mon, 03 January 2022, 14:10:46 »
Yes, it's much wider than a regular 80%. Leaf 80 was 360mm wide and ergo is 415mm.
Offline gwailo
« Reply #49 on: Tue, 04 January 2022, 15:00:22 »
Love the design! Will it support full right shift?
