Author Topic: [IC] Space65 R3  (Read 226735 times)
Offline KNz
Re: [IC] Space65 R3
« Reply #100 on: Fri, 07 January 2022, 03:21:59 »
Hotswap on the space 65 ?
Seriously can't wait for this :D
Offline bas72
Re: [IC] Space65 R3
« Reply #101 on: Fri, 07 January 2022, 05:46:10 »
YES! With hotswap PCB please. I'll take both. :-D
Offline eatanygoodbooks
Re: [IC] Space65 R3
« Reply #102 on: Fri, 07 January 2022, 17:52:02 »
A full view of the keyboard would be appreciated. Less of an IC and more of a teaser.
Agreed, I don't have an instagram to even see what else is out there for this. I'm very eager to get my hands on this but I'm so curious as to what colors will be available.
Offline Convergence
Re: [IC] Space65 R3
« Reply #103 on: Fri, 07 January 2022, 19:37:54 »
+1 to the other WKL enjoyer in the thread.
Offline fairypenguin
  • zzz
Re: [IC] Space65 R3
« Reply #104 on: Fri, 07 January 2022, 22:53:21 »
Really not sure how going screwless enhances the aesthetic. I'd rather have them, personally, as I've never had a good experience with a build that opted otherwise. That said, still pretty excited for this. Was super bummed when I missed out on V1.
Also, pls hotswap
« Last Edit: Fri, 07 January 2022, 23:14:12 by fairypenguin »
Offline jivex5k
Re: [IC] Space65 R3
« Reply #105 on: Fri, 07 January 2022, 23:05:45 »
price?
Offline Leopard223
Re: [IC] Space65 R3
« Reply #106 on: Sat, 08 January 2022, 13:38:08 »
Space65 is the pinnacle of keyboard designs in my opinion, I'll even say iconic.
I'm unable to join the GB but good luck with it! I'd love to see more of it in the future.
Offline CLAP_STUDIO
Re: [IC] Space65 R3
« Reply #107 on: Sun, 09 January 2022, 01:41:20 »
Lets gooooo!
Offline depressedkeebs
    • Depressed Keebs
Re: [IC] Space65 R3
« Reply #108 on: Sun, 09 January 2022, 11:37:25 »
I don't think hotswap is that important, at least to me. Specially with the chip shortage, if you manage to go hotswap is just a nice plus
Offline oldcat
  • 65% is Life
Re: [IC] Space65 R3
« Reply #109 on: Mon, 10 January 2022, 14:19:46 »
Yes if it happens it will be an option. The solder PCB version should be available.
Offline aimhigh
Re: [IC] Space65 R3
« Reply #110 on: Tue, 11 January 2022, 04:45:50 »
+1 with hotswap pcb
Offline lonalde
  • Leicaaaaa
Re: [IC] Space65 R3
« Reply #111 on: Tue, 11 January 2022, 23:01:55 »
+1 to hotswap
Offline noxtace
Re: [IC] Space65 R3
« Reply #112 on: Wed, 12 January 2022, 00:13:21 »
My biggest problem with the space 65 design is the fact that it only had leds on the left side. Will the r3 have an led on both sides this time?
Offline Jay_dez
Re: [IC] Space65 R3
« Reply #113 on: Wed, 12 January 2022, 12:26:36 »
+1 to hotswap if it also supports ISO
Offline the_useless_turtle
Re: [IC] Space65 R3
« Reply #114 on: Thu, 13 January 2022, 03:04:48 »
I would love to see a lilac colorway - might actually buy
Offline alper_maestro
Re: [IC] Space65 R3
« Reply #115 on: Thu, 13 January 2022, 16:06:32 »
If it comes with hotswap, I'm in.
Otherwise goodluck.
Offline Struth
Re: [IC] Space65 R3
« Reply #116 on: Thu, 13 January 2022, 21:24:38 »
I N T E R E S T E D !
Offline codog
Re: [IC] Space65 R3
« Reply #117 on: Thu, 13 January 2022, 21:32:38 »
Get rid of the fake screws though.
Offline Engedi_
Re: [IC] Space65 R3
« Reply #118 on: Thu, 13 January 2022, 22:20:56 »
Neeeed hotswap
Offline MiladDSP
Re: [IC] Space65 R3
« Reply #119 on: Fri, 14 January 2022, 00:16:30 »
Build video here
The group buy is running soon in China for 2300 yuan.
I think the build is interesting, its a three piece screw less design. Has silicone gaskets and daughter board this time. They have four options of fr4, pc, pom and possibly peek.  I dont know how a PEEK plate is like, never seen one.
There is no weight measuring in the video, it looks too light to me. It looks alright but it's probably going to be like $400 for international? That's a bit much. If it's in $350 ish I might get one. This looks like to be same price as something like Mr.Suit from OwLab but doesnt look that nice, OwLab Spring is cheaper than this for example. They have lots of fans so I dont think they have a problem selling this either way.
« Last Edit: Fri, 14 January 2022, 00:36:00 by MiladDSP »
Offline Jefff
    • jlabs.co
Re: [IC] Space65 R3
« Reply #120 on: Fri, 14 January 2022, 00:52:57 »
Screwless design but there’s a CNC’d slotted-head screw on the weight on the bottom. What’s the point?
Great point, they might as well make those real screws. It looks a bit cheap and toy-ish with faux screws on the weight.
Offline crzone
Re: [IC] Space65 R3
« Reply #121 on: Sat, 15 January 2022, 06:36:21 »
I have skimmed through the thread I am not sure if this has been asked before, but here we go: would a hotswap PCB from R3 fit into a R1 or R2 case?
Offline MiladDSP
Re: [IC] Space65 R3
« Reply #122 on: Sat, 15 January 2022, 23:25:07 »
You can see the build video, the pcb has change quite a bit. The side LEDs are now on the main pcb, not on a separate vertical board. While that might still work. the usb port is also different. It now connects to a daughter board unlike previous run. I guess you might be able to jam the daughter board into the USB hole of the R2 with hot glue or something and have it work but its clearly not intended to be compatible.
Offline __init__
Re: [IC] Space65 R3
« Reply #123 on: Sun, 16 January 2022, 00:52:46 »
100. Would gladly pay extra if this happens.
Offline crzone
Re: [IC] Space65 R3
« Reply #124 on: Sun, 16 January 2022, 02:44:41 »
Yeah, you are right, I missed the daughter board part. Maybe a hotswap PCB compatible with R1 and R2 could be considered, I am currently mil-maxing a Space65 board and it is a really painstakingly slow process.
Offline SafeAtShore
Re: [IC] Space65 R3
« Reply #125 on: Sun, 16 January 2022, 17:16:28 »
Yeah, hopefully it stays in the $3XX range, but as long as it's cheaper than the aftermarket, people will buy.
Also +1 for no fake screws; absolutely pointless.
Offline atisitkungza12
  • AuTHER
Re: [IC] Space65 R3
« Reply #126 on: Sun, 16 January 2022, 21:51:53 »
+ 1 hotswap
Offline lakeboredom
Re: [IC] Space65 R3
« Reply #127 on: Mon, 17 January 2022, 03:00:32 »
Definitely don't want hotswap unless you are going to add standoffs and screws to hold the pcb/plate assembly together. Ruins the typing experience imo.
Sent from my MotoG3 using Tapatalk
Offline OptimusPrime00
Re: [IC] Space65 R3
« Reply #128 on: Mon, 17 January 2022, 19:28:20 »
yesss!
+1 Hotswap
Offline PotatoFury
Re: [IC] Space65 R3
« Reply #129 on: Thu, 20 January 2022, 05:28:19 »
Let's Go!
Offline keebsalad
Re: [IC] Space65 R3
« Reply #130 on: Thu, 20 January 2022, 05:29:37 »
have been waiting for this one!
Offline Gnurt
Re: [IC] Space65 R3
« Reply #131 on: Thu, 20 January 2022, 08:53:28 »
is this GB live yet?
Offline AshF
Re: [IC] Space65 R3
« Reply #132 on: Thu, 20 January 2022, 10:35:28 »
Offline tyypo
Re: [IC] Space65 R3
« Reply #133 on: Fri, 21 January 2022, 12:35:11 »
HOT SWAP YASSSSSSS When will the GB open?
Offline Keeblet_257
Re: [IC] Space65 R3
« Reply #134 on: Fri, 21 January 2022, 14:14:42 »
never  :(
Offline POMChamp
Re: [IC] Space65 R3
« Reply #135 on: Mon, 24 January 2022, 15:24:53 »
Really looking forward to R3's international group buy. Is there any chance of the mid pieces being sold separately? Deep Ocean is beautiful, but the wine red mid plate limits what you can put on the board in my opinion.
Offline Botty212
Re: [IC] Space65 R3
« Reply #136 on: Tue, 25 January 2022, 02:21:42 »
I don't think that potter will do that since it would decrease the amount of work, stress and increase shipping time. The Space will for sure get ordered a lot I would even say in the high 4 digit to 5 digit area. By dont having the option to select the mid part he can fullfill this GB faster. You can easily order 2 boards swap one midpart out and just sell it. There will be ppl who'll still miss the GB and would happily take it from you even for a small 30% increase in reatail price.
Gesendet von iPad mit Tapatalk
Offline kcching
Re: [IC] Space65 R3
« Reply #137 on: Tue, 25 January 2022, 04:17:53 »
Just received email notification that international GB will resume shipping after Chinese new year =) Can't wait!
Offline Botty212
Re: [IC] Space65 R3
« Reply #138 on: Tue, 25 January 2022, 05:16:17 »
Fake news since international GB hasnt even started yet. You mean the international GB for Apollo, but R3 hasnt been in the GB phase
Offline Neoshooter
  • Hi
Re: [IC] Space65 R3
« Reply #139 on: Wed, 26 January 2022, 12:14:03 »
I'd really like to have a solder option available. I've had too many HS pads pop off on me, and I genuinely enjoy the security that a soldered joint provides.
Plus Solder PCBs let you decide if you want split spacebars, split backspace, and other minor changes that HS PCBs can't.
Offline Keeblet_257
Re: [IC] Space65 R3
« Reply #140 on: Wed, 26 January 2022, 14:30:01 »
easy way to prevent it from happening is to support the socket with ur finger when pressing the switch in if you do that the socket will never pop btw hotswap is just an option doesnt mean that it is the only option
Offline Jho
Re: [IC] Space65 R3
« Reply #141 on: Thu, 27 January 2022, 20:46:28 »
I am intrigued. I would also want a hotswap pcb.
Offline aodioxp
Re: [IC] Space65 R3
« Reply #142 on: Sat, 29 January 2022, 20:54:26 »
Yeah, I think they will keep the solder option. hot-swap is optional and costs extra. I am pretty sure because Chinese GB has already been concluded.
Offline Wa1fu
Re: [IC] Space65 R3
« Reply #143 on: Sun, 30 January 2022, 10:31:09 »
+1 for hotswap, but the fake screws on the weight are pointless IMO and make it feel cheap
Offline xc0mr4de
Re: [IC] Space65 R3
« Reply #144 on: Mon, 31 January 2022, 07:54:11 »
whole else happy to see a r3 happen?
Translucent PCB (possibility for hotswap option) - anyone wants hotswap?
Yes hotswap!
Offline MrLi
Re: [IC] Space65 R3
« Reply #145 on: Tue, 01 February 2022, 06:21:21 »
Missed out on the R2s. Yessss to hotswap :)
Offline mr_foggy
  • neue = nope
Re: [IC] Space65 R3
« Reply #146 on: Tue, 01 February 2022, 17:01:49 »
I dont need hotswap but it's 2022 and big GBs like this should offer solder/hotswap option, so yay for hotswap.
Offline Briaireous
Re: [IC] Space65 R3
« Reply #147 on: Thu, 03 February 2022, 06:18:38 »
Hotswap please and thank you!
Sent from my LYA-L09 using Tapatalk
Offline Therien
Re: [IC] Space65 R3
« Reply #148 on: Thu, 03 February 2022, 16:53:42 »
I can totally live without hot swap if I can get it as an ISO.
Offline mikrobyte
Re: [IC] Space65 R3
« Reply #149 on: Fri, 04 February 2022, 10:01:42 »
YES! hotswap please  :thumb:, save me the time and effort to millmax the pcb like i did with the Think 6.5v2  :D
