Author Topic: In need of an EVA-01 Unit inspired TKL housing/kit recommendation  (Read 1885 times)
Offline ribowski
« on: Fri, 31 December 2021, 09:48:40 »
First of all hi everyone!
Ive decided to build an EVA-01 themed TKL keyboard - got the GMK Mecha caps already, I know about the EVA-01 linear switches which I'll probably go with (or tactile Cyberswitches as an alternative, if I find them available for purchase).
Is there any polycarbonate volt yellow / violet tinted TKL kit worth looking into? Preferably with hot-swappable switches and RGB PCB. I'd like this build to be high quality, so a plastic cheap housing / kit won't do (unless there's something awesome I'm not aware of). Your recommendations / opinions are more than welcome! I'm not dead set on polycarb housing but semi-transparent, volt yellow tinted, high quality housing would be awesome
Just discovered Endless-80 and Space80 Apollo. These would have been perfect -_-
« Last Edit: Fri, 31 December 2021, 12:12:57 by ribowski »
