Author Topic: [GB] RGB Knob - 1 knob, 6 custom layers, unlimited fun. ENDED (27th).  (Read 9660 times)
Offline SmoothFaces
Welcome, introducing the
(All pictures above are real)
Experience a smoother way of controlling your device without having to use keyboard shortcuts or manually controlling it on your screen.
The RGB Knob is a compact and beautiful case that lets you use the most common controls at a click of a button.
With 6 easily accessible layers, you can control your volume, brightness, scrolling, RGB modes, changing between screens, adding custom shortcuts for your favourite software, and more! Works on your phone too.
Connected via magnets, the RGB Knob is a compact and minimalistic controller that sits perfectly on your desk, with its 30 mini RGB LEDs that bring a beautiful ambient to your setup.
6 Costumizable Layers
With 6 layers, you can customize each one individually for all your needs. Creativity is your only limit (well, almost).
To see the layers on your knob hold & rotate, 6 colors will be displayed as you do it. To select one, point the knob to the color of your choice (the brightest color is the one being selected).
Configuring each individual layer is just as easy. Your RGB Knob comes flashed with QMK software and you will have 6 functional layers right out of the box but you can edit what each actions does in a click of a button with our custom built-in-browser "software. Go to rgbknob.epkb.design with a chromium based browser and connect your RGB Knob. (To connect, press Connect to device > RGBKnob > Connect).
Succeeding the connection, you will be greeted with the same colors as in your knob. You can select each one and specify what your actions do for: left-turning, right-turning and press.
In the pictures below you can see the menu where you can edit the layers, and all the commands you're offered for each.
The amount of commands you can add into a single knob is amazing. If you're curious, here are my personal current layers on the RGBKnob:
- Layer 1: Volume up & down, press to stop all sounds
- Layer 2: Left & right arrows, press for spacebar - Use to fast-forward/rewind videos (YouTube, prime, Netflix, etc..) and stop/start when needed
- Layer 3: Page up & down - Use to scroll on website
- Layer 4: Volume up & down, press for shortcut to mute/unmute my microphone on Zoom calls and control the audio from it.
- Layer 5: Screen brightness up & down
- Layer 6: RGB modes and toggle off/on to go trough all the RGB modes or to turn it off when I don't want to see light
You can easily customize your Knob to fit your needs and add any shortcuts for apps (Illustrator, Photoshop, Games, Work, etc...)
MAGNET MOUNTED
For the top and bottom of the case we used magnets to hold both. Makes the opening of the RGB Knob much easier and it's definitely a very nice feeling to let the case close on it's own.[the side of the knob has a hole for the screw to hold on the encoder, no wobble exists when using your knob](video from our old prototype, rose color does not exist & the texture on the actual concept is smoother)
PRICE & INFO
Prices:
80 USD (black, grey, pine green, dark blue, dark purple) - anodised aluminium 6061
90 USD (e-white) electrophoresis aluminium 6061
Shipping & customs not included.
Pre-orders available now at kbdfans.com. Ends 27th of January, 2022.
(pictures from the first prototypes made by KBDfans)
Fun fact, few weeks ago we had the knob with 8 layers instead of 6 which was insane. We are keeping at 6 because we feel it is a great number of layers already for a single knob. Unless....if a lot you want more layers, we will do a google form soon to confirm that so anyone who wants can have 6 or 8 layers. (I assume 30 layers would possible too lol)
_
LINKS
If you're interested, you can check our initial IC (some minor details might be out of date)here
Code: [Select]
[url=https://geekhack.org/index.php?topic=113534.0][img width=306 height=112]https://i.imgur.com/kyBaAox.png[/img][/url]Link if you want to use our signature thumbnail
« Last Edit: Sat, 29 January 2022, 16:52:52 by SmoothFaces »
Offline SmoothFaces
Re: [GB] RGB Knob - 1 knob, 6 layers, unlimited fun. Pre-orders end Jan 27th.
« Reply #1 on: Sun, 02 January 2022, 10:10:40 »
Reserved
« Last Edit: Tue, 25 January 2022, 19:16:37 by SmoothFaces »
Offline SmoothFaces
Offline lecorsair
« Reply #3 on: Wed, 05 January 2022, 13:07:45 »
So just bought one from KBDFans and got hit with California tax, weird never seen that from a foreign retailer before. $110 shipped to CA, kind of pricy - but +1 for a very interesting product 👍.
« Last Edit: Wed, 05 January 2022, 13:11:00 by lecorsair »
Offline SmoothFaces
« Reply #4 on: Thu, 20 January 2022, 16:40:28 »
Sorry about that bud. Definitely not expected, but unfortunately since it is KBDfans that deals with the pricing part, I can't really help. But we really appreciate your support and I'm confident the purchase you made will turn out to be worth it!  :)
Offline SmoothFaces
Re: [GB] RGB Knob - 1 knob, 6 custom layers, unlimited fun. Ends 1 day!
« Reply #5 on: Tue, 25 January 2022, 19:17:02 »
Ends tomorrow!  :eek: ;)
Offline Snoman1391
Re: [GB] RGB Knob - 1 knob, 6 custom layers, unlimited fun. Ends 1 day! (27th)
« Reply #6 on: Wed, 26 January 2022, 12:58:12 »
I'll probably join the group buy regardless, but I was curious if the RGB lights can be set to a single color instead of always being rainbow? For example, if I want the lights to always show orange instead, is that possible? I can't quite tell from the description, unfortunately. I know the rainbow helps with layer selection, but a single color would look cleaner on my desk  :D
Offline pyomaung
« Reply #7 on: Thu, 27 January 2022, 08:45:41 »
In for the white. Hopefully the rgb toggle can do single colour and rgbs matching volume bar/level when its on the volume layer would be a really nice feature. Looking forward to it.
Offline SmoothFaces
« Reply #8 on: Thu, 27 January 2022, 09:35:18 »
Thank you for joining! Yes you can definitely have any color you want as static or moving pattern  ;)
Offline MajorEngi
« Reply #9 on: Thu, 27 January 2022, 12:54:46 »
I am not sure if I missed it, but can the RGB be turned off and slowly fill the bar as you rotate the knob.  For example if you are controlling sound and you want to turn it to 50% can you rotate the knob and the rgb light would only fill up to the 50% along with the turning of the dial?
Hope that made sense.
Offline SmoothFaces
« Reply #10 on: Sat, 29 January 2022, 16:57:07 »
Hey MajorEngi, that would be an amazing idea but unfortunately it won't be possible. In order to do that, we would basically have to make a custom program that would run 24/7, essentially a custom driver. That would be needed so the computer could communicate with the RGB Knob and tell what percentage of volume it currently has. :thumb:
Offline alper_maestro
Re: [GB] RGB Knob - 1 knob, 6 custom layers, unlimited fun. ENDED (27th).
« Reply #11 on: Mon, 31 January 2022, 09:13:22 »
Bummer, I thought it was live until the end of the month.  :-[
