Author Topic: [IC] Eau - A 75% Keyboard with decoration F Row Module  (Read 31443 times)
Offline CHAOSERA
    • official website of chaosera
« on: Sun, 02 January 2022, 23:01:49 »
Eau
A Gasket Mount 75% Keyboard with decoration F Row Module
Hi Everyone,
We are the new customization team "CHAOSERA". In 2021, 75% keyboard becomes more and more popular. Since this is the first keyboard from our team, and we want to make something different.
Gallery
Highlight
- Clean Case Design
We aimed to finish the keyboard free of any visible screws on both sides, both top, and bottom.
- Magnet F-row decoration block
We use a magnet base to make the F-row decoration block hot-swappable. It is easy for users to change the decoration block to keys without and screws. There also will be more kinds of decoration blocks in the future. Users can even create their own decoration block.
- All Included
Plate poron foam, bottom poron foam, aluminum plate, PC plate, F-row decoration block, and stabilizers are all included. Users just need to buy switches and good to go.
- Easy to assemble
We rethought and redesigned the assembly method of the inner part of the gasket structure. Users do not need to stick the poron foam to the case anymore.
Features
-Typing angle: 7 degrees
- Layout: 75%/65%
-Material: 6063 Aluminum
-Mounting Method: Gasket Mount
Kit Contents
- Aluminum Top Case
- Aluminum Bottom Case
- Magnet F-row decoration block protection film
- PC Plate
- Aluminum Plate
- RGB Hotswap PCB
- Everglide V2 Screw-in stabilizer set
- PORON gaskets
- Silicone gaskets
- PORON dampener between plate and PCB
- PORON foam between PCB and bottom case
- Anti-cutting silicone strip between PCB and bottom case
- Individual PORON foam between PCB and switches (100)
- Screws and silicone feet
Prototype
GB INFO
GB Date: Q1/Q2 (In Stcok)
Amount: 150 (Ready to ship)
Price: ETA Below 400$(Not Including Shipping)
Assembly and Typing Sound
More Information and Updates
Discord Server Invite: https://discord.gg/eYBJpC8Zbf
Please join the Discord server if you would like to get updates on the project as soon as possible.
« Last Edit: Sat, 19 February 2022, 02:35:36 by CHAOSERA »
Offline expensive
Re: [IC] CHAOSERA - Eau
« Reply #1 on: Sun, 02 January 2022, 23:03:03 »
hello
Sent from my SM-N960U using Tapatalk
Offline Stilou Studio
  • Formerly Seo
  • Danish Designed Keyboards
« Reply #2 on: Mon, 03 January 2022, 02:18:42 »
Very cool idea, looks sweet as well!
GLWIC
Offline bigoldbox
« Reply #3 on: Mon, 03 January 2022, 03:19:26 »
I don't really understand how the magnetic piece is supposed to work, any prototypes that show this feature?
Offline Fraaaan
« Reply #4 on: Mon, 03 January 2022, 06:18:08 »
ne prototype?
Sent from my Xiaomi Robot Vacuum MOP Essential using Tapatalk
Offline CHAOSERA
« Reply #5 on: Mon, 03 January 2022, 10:41:15 »
GLWIC
Prototype Updated!
Offline C_L | Soup
« Reply #6 on: Mon, 03 January 2022, 20:30:14 »
Very unique take on the 75% layout, as well as a cool badge to alter the layout further. Are there any more renders/photos of the badge applied? does one have to take the switches out for the badge to be applied? GLWIC
Offline ohwe
  • no
« Reply #7 on: Mon, 03 January 2022, 20:40:02 »
I am quite a fan of this take on a 75. Only thing I kind of wished it had was a 7u bottom row, but aside from that, very interesting. Will keep an eye on the progress on this one.
Current rotation: Rama U80-A, Rama Kara, Mode65 (Maroon/Brass)
Offline Sax_______
« Reply #8 on: Mon, 03 January 2022, 20:43:55 »
Are you going to keep the north facing PCB?
Offline CHAOSERA
« Reply #9 on: Fri, 07 January 2022, 14:04:48 »
Yes, the switches are needed to be taken away to apply the badge.
Offline CHAOSERA
« Reply #10 on: Fri, 07 January 2022, 14:05:59 »
The PCB is not the final version. we will do the interest check later to decide the final PCB.
Offline w1ndkk
Re: [IC] Eau - A 75% Keyboard with decoration F Row Module
« Reply #11 on: Sun, 09 January 2022, 05:58:28 »
Great design, looking forward to the video about this keyboard.
Offline CHAOSERA
« Reply #12 on: Sun, 09 January 2022, 20:15:18 »
Video Updated
Offline treeleaf64
    • treeleaf64
« Reply #13 on: Sat, 29 January 2022, 00:38:11 »
Poron foam thock thock! poron foam thock thock! :) ;) :D ;D :( :-[ :-X :-\ :-* :'( >:D ^-^ :)) :cool: :confused: :mad: :rolleyes: :eek: :p :blank: :thumb:
Everyone must pay the cat tax
Offline DaaDaa
« Reply #14 on: Sat, 29 January 2022, 01:09:24 »
cool design, PE foam option please
piggy60 red upgraded PVD w/ GMK umka zaku | tiramisuit w/ GMK noire JWK silk emerald | mr.suit black/chrome glossy chamfers w/ GMK minimal cow POM stem | jelly epoch w/ SA oblivion zaku | mode80 deco w/ gmk boneyard alpaca | mode 80 imperial with ePBT origami alpaca| MODE80 viridian /w CRP boba LT | RAMA thermal kuro w/ GMK muted 2 pewter | BBox60 C64 wih marshmellows and c64 keycaps | MODE Sonnet green /w MW voynich gateron ink box pink
Offline gtg465x
« Reply #15 on: Sat, 29 January 2022, 07:41:55 »
Seems like full size right shift, 2 column nav cluster keyboards are catching on. Might have to start calling them 77% ;D.
Offline marici22
« Reply #16 on: Sat, 29 January 2022, 15:42:11 »
Cool concept
Offline Botty212
« Reply #17 on: Mon, 31 January 2022, 01:38:56 »
buy some PE foam for like 5$ and ur good to go for the next 100 boards all you need to do then is cut it to shape and maybe some holes for the stabhousing. Unless ur so lazy that u would rather pay 15$ for one small sheet of it.
Gesendet von iPad mit Tapatalk
Offline WarlordGorguts
« Reply #18 on: Mon, 31 January 2022, 07:47:49 »
Cool looking board and interesting color choices.
Offline CHAOSERA
« Reply #19 on: Sat, 19 February 2022, 02:36:09 »
New Photo updated!
Offline SeraphimKnight
« Reply #20 on: Tue, 15 March 2022, 20:59:14 »
Super interested in this, please make the PCB south-facing!
Offline dacostajs
« Reply #21 on: Tue, 15 March 2022, 23:30:15 »
Very interesting and unique design.
Offline CHAOSERA
« Reply #22 on: Sat, 19 March 2022, 02:00:58 »
Hello everyone, sorry for waiting a long time. Many people want to know the time of GB. Because lots of person hope us can change the north-facing to south-facing flex with cut on PCB. We did it but because of the epidemic, the factory is closing. The photo looks like simple, because it only has texting sample of PCB board patch. So it has not SMT.  After we will put better one on.
We change the RGB light , only the F row module has.
And because of the epidemic, the factory is closed, the release day will be later,We will announce the specific time according to the actual progress again.(about 30-45 days).
We promise to do our best about “EAU-chaosera”. Not to disappoint everyone's wait, thank you!
Offline Barbadus
« Reply #23 on: Thu, 24 March 2022, 15:00:49 »
Thanks for the update and a very interesting concept. Looking forward to the next update and hopefully everything can resume soon!
Offline superjackie
« Reply #24 on: Fri, 01 April 2022, 09:52:24 »
Is there a weight to this board? If I decide to keep using the F rows all the time, can the block be used as weight(having the block with heavier materials like brass)?
Offline CHAOSERA
« Reply #25 on: Mon, 25 July 2022, 13:17:10 »
EAU in stock GB is start at July 31 at 12 am(EST).
