Author Topic: Drop Alt high profile foam mod advice  (Read 2371 times)
Offline slixils
« on: Tue, 04 January 2022, 06:37:45 »
Hi, I am trying to find tutorial about modding drop alt high profile with sound dampening foam but they are all about using module case and plate foam.
Can I just put a normal foam as case foam without cutting hole at the bottom of pcb to get sound dampening effect?
