Author Topic: [IC] Tilde 60 | 60% Top / Gasket Mount Keyboard  (Read 11097 times)
Offline BobRoss2025
« on: Mon, 10 January 2022, 14:09:33 »
Hi Everyone!
I'm Bob, Bob Ross#2025 on discord.
Glad to be able to finally present to you the 60% project I've been working on for the last few months, the Tilde 60
Status
Project on backburner
Tilde 60
281053-0
Features
Mount: Relief-Top or Gasket mount
Front Height: 18.43/20.07mm (Bottom to top of lip)
Adjusted front height: 20.16mm
Effective keyboard height: 23.65mm
Typing angle: 6 degrees
Seamless
VIA Supported
Dimensions
281177-1
PCB Layout
281055-2
Plate Design
281057-3 281059-4
Exploded view
281061-5 281063-6
Inventory
6063 Aluminium Top and Bottom case
PVD Black Brass Weight (Matte)
5052 Aluminium plate ( matching case colour )
Hard carrying case with microfiber cloth
Cascade PCB ( Tilde60 Solder Edition ) w/ JST cable and DB by kbye from Studio Kestra
Case Foam
Gasket strips
Nylon gasket tabs
Screws
3M Bumpons
Colours (TBD)
PANTONE 18-0601 TCX [Charcoal Grey]
Black
Silver
GB Details
Units: 50
Price estimate: $350-400
Date: TBD
Proxies: TBD
GB timeframe: ~3-5 months to ship ( will give a more concrete timeline during actual GB )
Renders
281067-8
281069-9
281071-10
281073-11
281075-12
281079-13
Prototype Pictures
Please pardon me with the low quality of the pictures taken!
281081-14
281083-15
281085-16
281087-17
281089-18
281181-19
Sound tests
Disclaimer: Sound tests are not always representative of how a keyboard should/will sound like in person
PC Case with Aluminium half plate with CRP Keycaps ( Lavenders L&F )
Alu Case with PP full plate and GMK Keycaps ( 8008 Inks L&F )
Q&A
Why the name Tilde? Friend suggested it because of how the sides looks like a tilde during the early phases of designing, thought it was pretty accurate so here we are
PC? - I will not be running full PC cases due to the high rate of failure. However i'm considering including/making PC bottom a possibility if there is enough interest in it
Nylon tabs? - These are 3d printed tabs for the gaskets to sit on for the bottom case so that the board can be easily swapped between gasket and top mounting. Which also means, there will be a gasket paste on the top case for both gasket/top mount configs. Additional gaskets will be provided in the case that you decide you do not want them
Two plate designs? Plastic plates will be the ones without the relief cuts on the mounting tabs to prevent over flexing on materials like PP and PC
Plate files? - Will be released once GB ends
Foam? - Purely added for experimental sakes here, the PC sound test is without case foam while the alu sound test was with the case foam. Will be included with the gb so people can choose to opt out or not.
PVD? - PVD for the weight will be matte, something more in line with other keyboards like jubi, jag in black pc etc. Will not be glossy to prevent easy scratches etc. Though this will be a fingerprint magnet unfortunately.
Proto scuff? - Manufacturer for the group buy will be one previously used in extremely high end and popular boards before, undisclosable for obvious reasons.
« Last Edit: Thu, 24 March 2022, 07:15:04 by BobRoss2025 »
Offline BobRoss2025
Re: [IC] Tilde 60 | 60% Top / Gasket Mount Keyboard
« Reply #1 on: Mon, 10 January 2022, 14:11:04 »
RESERVED
Offline Alejo1707
  • Gimme some more caps!
« Reply #2 on: Mon, 10 January 2022, 14:25:07 »
Looks like a keyboard alright
Sent from my GM1917 using Tapatalk
Offline stewfayew
« Reply #3 on: Mon, 10 January 2022, 15:51:28 »
Looks good to me! GLWIC
Offline WhatsForLunch
« Reply #4 on: Mon, 10 January 2022, 16:22:15 »
Looks clean, love it
Offline rossi94
« Reply #5 on: Fri, 25 February 2022, 00:46:37 »
I like the board. Any chance for ISO?
Offline C_L | Soup
« Reply #6 on: Sat, 26 February 2022, 23:47:55 »
This looks like a 60% rectangle. I enjoy that, GLWIC
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #7 on: Sun, 27 February 2022, 11:30:12 »
+1 :cool:
«How much wood could a woodchuck chuck if a woodchuck could chuck wood?»
Offline rossi94
Offline ninio
« Reply #9 on: Sun, 20 March 2022, 17:39:16 »
Love it, opting for the HHKB
