Author Topic: [IC] Keychron Q0 - Numpad  (Read 15120 times)
Offline cheswick
  • https://cheswick.dev/
    • cheswick.dev
« on: Wed, 12 January 2022, 07:44:12 »
Q0
by Keychron
Website
Discord
  • Full aluminium body
  • Out of the box QMK & VIA support
  • Keychron screw-in stabs
  • 5Pin hotswap PCB [southfacing]
  • Barebones: 69$
  • Fully assembled: 79$
A mini custom all-metal number pad, that can be used so conveniently in many use cases.
We made it fully support QMK and VIA, making it easy for everyone to program every keystroke.
It's fully customizable for everyone.
Options
Board options
  • Fully assembled version including Gateron Pro switches and PBT keycaps OSA profile [OEM height and SA look]: 79$
  • Barebone: 69USD
Case colors
  • Carbon Black
  • Space Gray
  • Navy Blue
Size
  • Width: 128.84mm
  • Lenght: 88.77mm
  • Front Height: 18.20mm
  • Back Height: 29.93mm
  • Feet Height: 2.4mm
  • Angle: 5.26 degree
Informations
We are working on the first prototypes; this will be an unlimited run of the board, and real-life photos of the numpad will be available later.
The estimated launch for this is expected to be March 2022
« Last Edit: Mon, 17 January 2022, 03:35:14 by cheswick »
Offline vinorodrigues
Re: [IC] Keychron Q0 - Numpad
« Reply #1 on: Wed, 12 January 2022, 08:00:32 »
now this i would buy  :thumb:
Offline Valarius
« Reply #2 on: Wed, 12 January 2022, 08:07:00 »
Absolutely interested in this. I love my Q1 but the missing numpad hurts my productivity with work. I'd probably buy it regardless but if a bluetooth/wireless option was available, it would be my dream.
Offline Handke
« Reply #3 on: Wed, 12 January 2022, 09:46:42 »
Intersting, I would like to pair it (screw/ attach it) to the upcoming Q3 (on the left of the keyboard... or on the right if it's not possible).
Offline JQ27
« Reply #4 on: Wed, 12 January 2022, 10:09:31 »
Good thing they're eventually going to be doing a fullsize anyway in the Q-series.
Offline soundstage
« Reply #5 on: Wed, 12 January 2022, 10:10:00 »
Will Keychron India have this for sale on their site?
Offline Handke
« Reply #6 on: Wed, 12 January 2022, 10:29:37 »
Really???? Seems great. Any source? thanks
Offline JQ27
« Reply #7 on: Wed, 12 January 2022, 11:12:17 »
Cheswick has posted about them in the Keychron discord in the Q-Series channel, work a look around. There are also some mockups of some of the upcoming boards as well.
Offline moh18one
« Reply #8 on: Wed, 12 January 2022, 13:45:07 »
Nice! I hope that the others will have their front height reduced as well
Offline fishbiscuit13
  • do you realize ???
« Reply #9 on: Wed, 12 January 2022, 15:29:05 »
Is this tray mounted or gasket? The exploded image looks like a tray mount but the description reads like it's isolation gasket.
Offline indiceiris
« Reply #10 on: Wed, 12 January 2022, 17:43:21 »
Always nice to see more dedicated numpad options on the market. I both like and dislike the fact that the plate/pcb isn't reversible.
Offline Shutter_Shock
« Reply #11 on: Wed, 12 January 2022, 18:11:01 »
Oh yes. I'm down for this. I've been wanting a high quality numpad with VIA, and this fits the bill nicely.
Offline cheswick
    • cheswick.dev
« Reply #12 on: Thu, 13 January 2022, 02:05:13 »
My bad I fixed the text its Tray Mounted
Offline alper_maestro
« Reply #13 on: Thu, 13 January 2022, 16:08:40 »
RGB?
Offline cheswick
    • cheswick.dev
« Reply #14 on: Fri, 14 January 2022, 07:51:47 »
RGB?
It will have RGB like all other Q series Boards
Offline Joshua_VB
« Reply #15 on: Fri, 14 January 2022, 16:56:18 »
It would be good if you can do some renders of it next to the Q1 and Q2. I like my numpads to seemlessly sit next to my keyboard on the left.
Sent from my CPH2025 using Tapatalk
Offline HelloThisIsDog
« Reply #16 on: Fri, 14 January 2022, 18:32:01 »
If wireless is possible that would be amazing
Offline Shahdoost
« Reply #17 on: Sun, 16 January 2022, 13:54:36 »
A version with 1 fewer row to match the q2 would be great. Otherwise, it'll only really match the q1.
Offline hussar_name
« Reply #18 on: Sun, 16 January 2022, 15:52:02 »
What kind of numpad would be that
Offline Shahdoost
« Reply #19 on: Mon, 17 January 2022, 03:33:49 »
One without the top row with the x,o,square, and triangle. Like a normal numpad.
Offline Handke
« Reply #20 on: Mon, 17 January 2022, 04:26:58 »
tkl is more popular
Offline Shahdoost
« Reply #21 on: Mon, 17 January 2022, 13:22:05 »
tkl is more popular
Sure, I'm not saying that they don't make this. Just that a version to match the q2 and other relevant layouts would be great.
Offline cheswick
    • cheswick.dev
« Reply #22 on: Mon, 17 January 2022, 15:25:49 »
tkl is more popular
Can already tell this will not happen. Its just not doable to get one numpad per board.
Offline Shahdoost
« Reply #23 on: Tue, 18 January 2022, 03:00:48 »
tkl is more popular
Oh, to be clear, by "other relevant layouts" I meant any layouts that might have same number of rows as a 65% (so still just two versions of the numpad). Sorry for being unclear. Obviously one numpad per different layout is not happening.
« Reply #24 on: Wed, 19 January 2022, 14:10:47 »
What is the total weight of it when it's assembled?
Offline hussar_name
« Reply #25 on: Wed, 19 January 2022, 22:37:01 »
It makes you 79 dollars lighter
Offline haengwoonie
« Reply #26 on: Thu, 20 January 2022, 14:46:36 »
Definitely would love a bluetooth version!
Offline Handke
« Reply #27 on: Fri, 21 January 2022, 02:23:40 »
Would love some screws to attach it to another keychron keyboard.
Offline Uki
« Reply #28 on: Sat, 11 March 2023, 08:54:32 »
Please make Q0 Pro (wireless). You're the only one who can make a decent wireless numpad. I'm so tired of IC that last for 2 years and die. Keychron please. You can do it
