Author Topic: IBM Model M AT vs PS2 Cables  (Read 3369 times)
Offline Zefix
« on: Sat, 15 January 2022, 09:49:31 »
Ok keyboard nerds, I could not find this answer with a simple google search so I hope yall can help clarify this for me. So the model M was released during the end of the Personal Computer AT and the beginning of the Personal System 2. Meaning that model Ms can either come with a black cable that has a 5-pin din for AT or a concrete PS2 cable.
So what I'm curious about is can I take a normal model M with a PS2 cable and swap it with a black AT cables that came on the early model Ms?
If not, what inside the keyboard makes these two generations of model Ms use different sets? Could this be accomplished with swapping a single chip on the inside of the keyboard?
Here's some proof of detachable black cables in case y'all are confused.
skip to 2:40
my babies
Online fohat.digs
Re: IBM Model M AT vs PS2 Cables
« Reply #1 on: Sat, 15 January 2022, 10:23:30 »
My experience is that both of the cables can be be plugged into the SDL socket and work properly.
- D Trump 2026-10-24
Offline Zefix
« Reply #2 on: Sat, 22 January 2022, 18:59:57 »
update: bought model M black industrial cable.
It works perfectly with the orihalcon converter that I use to drive my Model FAT!
https://www.ebay.com/itm/302711725609
my babies
