Author Topic: [IC] KHカイリ  (Read 6285 times)
Offline Konpeito.caps
[IC] KHカイリ
« on: Sat, 15 January 2022, 19:56:49 »
"Don't ever forget. Wherever you go, I'm always with you."
IC Form
Introduction:
Hello everyone! This is my very first keycap set design inspired by Kairi from Kingdom Hearts! With the beautifully composed music and the character developments of each of the lights, I gotta say I am soo glad I played through most of the games! Except the mobile and web one.... (//▽//)
Please feel free to give me honest feedback in either the comment section or even better, completing the IC form!
Or join me at my discord!
To be updated
- Adding rows next to keycap set, novelties, spacebars
- Adjusting colours on the legends
- Renders
- Vendors(?)
- Samples
- Manufacturer process
Updates:
Kits
Base kit covers most common layouts and includes accent keys.
Novelties
The novelties are supposed to highlight some of the special features you can find in Kairi, like the star fruit and the blade! (´• ω •`) ♡
Colourway
Please keep in mind that the colours shown on screen will be lighter than actual product.
Bars
Specs
- Cherry profile (1-1-2-3-4-4)
- Dye Sublimation
Renders
More to come!
Artisans
Coming soon!
Collaborations!
Coming soon!
Board
Phoenix WK from ImperfectLink (https://imperfectlink.gumroad.com/l/KeyboardRenderKit)
« Last Edit: Sun, 16 January 2022, 16:31:07 by Konpeito.caps »
Re: [IC] KHカイリ
« Reply #1 on: Sat, 15 January 2022, 19:59:28 »
Feel free to join my discord server as well! (https://discord.gg/ddynKhGa)
Offline FishyKeebs
  • hey
Re: [IC] KHカイリ
« Reply #2 on: Sat, 15 January 2022, 20:09:11 »
reserved
Offline Baka Bot
Re: [IC] KHカイリ
« Reply #3 on: Sat, 15 January 2022, 20:45:03 »
No thanks
Offline Magnificent Bureaucrat
  • Sooooo much red tape
Re: [IC] KHカイリ
« Reply #4 on: Sat, 15 January 2022, 20:48:22 »
As soon as I saw the IC title my first thought was "I wonder what shades of pink, purple and/or pale blue it uses?". I was not disappointed
Offline marshmellohs
Re: [IC] KHカイリ
« Reply #5 on: Sat, 15 January 2022, 20:52:11 »
I highly recommend getting your renders professionally done - many community members provide rendering services. It's very hard for me to visualize how this set would turn out with the current renders. Your buyers will likely not have a Pantone book on hand to reference the colors directly.
Would also like to know what manufacturer/manufacturing process you envision for this set. I assume PBT since all colors are uncoated... that's a lot of reverse dyesub though.
Offline linell
Re: [IC] KHカイリ
« Reply #6 on: Sat, 15 January 2022, 20:56:36 »
please get better renders
information is very lackluster (make it obvious to the readers too)
you don't even have the keycap material listed
props for listing color codes tho
bro this a **** set, just be thankful you even getting 1 base running fr
Offline herbologist
  • beige enjoyer. send help.
Re: [IC] KHカイリ
« Reply #7 on: Sat, 15 January 2022, 21:07:41 »
Echoing what others have said about the renders really needing work. Kitting will vary by manu so you need to work that out as well. Seems a little premature.
Re: [IC] KHカイリ
« Reply #8 on: Sat, 15 January 2022, 21:52:22 »
Thank you for the rendering advises! I will definitely reach out to some members for better renders to show everyone! :)
Offline crystal
Re: [IC] KHカイリ
« Reply #9 on: Sat, 15 January 2022, 21:57:35 »
Please include a manu, a keycap profile, whether it is doubleshot or dyesub, and the nov keycap sizes. Also you novs might not be achievable depending on manu. Kitting might also not cover many boards.
Offline treeleaf64
    • treeleaf64
Re: [IC] KHカイリ
« Reply #10 on: Sat, 15 January 2022, 22:38:20 »
dude ship moment
Everyone must pay the cat tax
Offline Pensa73
Re: [IC] KHカイリ
« Reply #11 on: Sat, 15 January 2022, 23:50:49 »
I'd recommend choosing a manufacturer so you'll know how to properly work with your novelties.
Offline C_L | Soup
Re: [IC] KHカイリ
« Reply #12 on: Sun, 16 January 2022, 00:16:59 »
echoing previous comments. Additionally, I don't know if forcing accent spacebars in base is the play. Comes more into question when a manufacturer and subsequently pricing is disclosed.
Offline Sax_______
Re: [IC] KHカイリ
« Reply #13 on: Sun, 16 January 2022, 05:16:57 »
I'm quite conflicted on the Novelties...
Have you checked that the manufacturers you're looking into (I'm assuming you're going for a manufacturer that does PBT) can actually do novelties that require front top and back prints to be aligned without too much issue?
Apart from that like multiple people pointed out earlier, you should look into choosing a manufacturer and getting some proper renders done before continuing so that you can show a proper visualization of how it will turn out if it's produced.
Re: [IC] KHカイリ
« Reply #14 on: Sun, 16 January 2022, 05:57:33 »
IC will be on hold for now as I am currently reaching out to multiple renderers and might need more time to rework on the novelties, as well as the colour of the legends! I really appreciate everyone’s comments and the effort on telling me how to showcase this keycap set better! Filling in the IC form is still greatly appreciated! Hopefully I can update this post a.s.a.p., and bring better graphics to everyone! (*≧∀≦*)
Offline sirieous
  • help
Re: [IC] KHカイリ
« Reply #15 on: Sun, 16 January 2022, 16:14:52 »
While I've been meaning to see a KH inspired keyset sometime, I did not imagine it would look this bland..
Offline Kotahh
Re: [IC] KHカイリ
« Reply #16 on: Mon, 17 January 2022, 01:43:55 »
Second B can might as well go into spacebars kit instead of base
Offline jagger27
  • ne 1.5U supers???
Re: [IC] KHカイリ
« Reply #17 on: Mon, 17 January 2022, 14:14:42 »
lmao yep
