Author Topic: Filming/lubing Gateron Black  (Read 4024 times)
Offline sandywind
« on: Wed, 19 January 2022, 04:46:55 »
Hello! I have about 80 standard black switches by Gateron (not the Ink) and a hot-swap keyboard with less than 50 switch sockets.
Is filming and lubing, and changing springs to those Gateron blacks worth it? I have recently tried the JWK/Durock pre-lubed L4 and they are quite good stock, I am wondering if all considered (price of components, shipping, time, final result compared to what could be achievable with newer switches) it is worth doing.
I am aware it's not a technical question with a definite answer, but I would really appreciate it if you could share your opinion. What would you do in my place (if you had the time to film/lube)?
Corsair Vengeance K65 w/ SP DCS Twilight Keycaps | Poker II w/ Danger Zone keycaps | HHKB Pro 2 | Realforce 87UW55 | IBM PC BS 80's | OLKB Planck | IC WhiteFox | Varmilo VA87ML
Offline StripeArtz
Re: Filming/lubing Gateron Black
« Reply #1 on: Thu, 20 January 2022, 08:28:32 »
I think lubing is definitely worth it, but filming may not be necessary. Films are cheap but a bit annoying to put in imo, and Gateron switches usually are fine.
Offline sandywind
« Reply #2 on: Fri, 21 January 2022, 09:17:53 »
Why is filming tricky? I have read comments about films getting out of position when the switch is closed, is that the issue?
Offline phinix
« Reply #3 on: Sat, 22 January 2022, 15:10:13 »
Would cherry hyperglide blacks need filming?
Offline Sup
« Reply #4 on: Sat, 22 January 2022, 15:15:31 »
No Cherry and Gateron are fine the top housing is not loose like some JWK housings.
current
Coming soon
Offline phinix
« Reply #5 on: Sat, 22 January 2022, 15:47:23 »
Cool, thanks.
