Author Topic: [IC] DCS Reaper - Hibi reveal and GB Date Announced.  (Read 30404 times)
Offline clayclws
Re: [IC] DCS Reaper - Vendors Announced - Kitting Changes Incoming
« Reply #50 on: Wed, 02 February 2022, 04:21:55 »
Aw… was wishing for some Mac keys but I’ll cop these nevertheless, like Nightfall and Soldark. Moooaarrr DCS please!
Offline Tulesto
« Reply #51 on: Wed, 02 February 2022, 12:42:39 »
Quite possibly the coolest DCS set I have ever seen. 100% in.
Sangeo/Suit/Spring/Angle/CW88/Kohaku/Unikorn/Navi/Corsa
Offline TypeBis
« Reply #52 on: Thu, 03 February 2022, 09:48:57 »
can't wait for this!
Offline joro1662
    • GMK Gargalon
« Reply #53 on: Fri, 04 February 2022, 08:50:19 »
Love the custom font, cant wait for this set!
Offline oilpapers
« Reply #54 on: Fri, 04 February 2022, 09:27:18 »
Is this PBT or ABS, doubleshot?
Offline Aiwanei
    • ThocKeys.com
« Reply #55 on: Fri, 04 February 2022, 10:09:31 »
This is actually the classic/default DCS font, used in old Wyse boards, it's called Gorton. They do offer a cherry like font as well but I prefer the classic Gorton legends personally.
ThocKeys.com
Offline Aiwanei
    • ThocKeys.com
« Reply #56 on: Fri, 04 February 2022, 10:11:53 »
SP only offers ABS for doubleshot, PBT is dyesub (and not reverse dyesub), though both can be pad printed. This set will be doubleshot ABS.
ThocKeys.com
Offline ibankais
« Reply #57 on: Fri, 04 February 2022, 20:18:05 »
Any updates on a potential Alps kit? Super interested  :D
Offline Aiwanei
    • ThocKeys.com
« Reply #58 on: Mon, 07 February 2022, 10:12:53 »
Here is a preview of the updated novelties kit. Please be aware that the ISO Novelty enter may have to be cut, there was a miscommunication when originally getting quoted and it didn't include it being pad printed and uv coated which is the only way to do a novelty ISO enter that takes up the full ISO enter surface. Currently weighing options and looking at alternatives but not sure if it will have to be cut.
ThocKeys.com
Offline Tulesto
« Reply #59 on: Mon, 07 February 2022, 18:47:18 »
I like the updates, personally would prefer 2 of each design 1.5u mods but otherwise great improvements.
Offline IOVERCALLHISTIOCYTES
« Reply #60 on: Mon, 07 February 2022, 18:51:31 »
DCS Death >>> DCS Deadbeats
Hyped
Offline DeMechanica
« Reply #61 on: Mon, 07 February 2022, 21:57:02 »
Awesome except for the comic sans font, I would have bought if not for that
Offline Aiwanei
    • ThocKeys.com
« Reply #62 on: Mon, 07 February 2022, 22:07:52 »
The font is actually called Gorton which is the classic DCS font that was found on Wyse Terminal keyboards.
ThocKeys.com
Offline butternutz
« Reply #63 on: Mon, 07 February 2022, 22:13:02 »
new novelty keys are awesome. Definitely gonna buy with the black-on-black novelties now.
Offline FatefulStranger
« Reply #64 on: Mon, 07 February 2022, 23:23:58 »
I'm more inclined to get the novelty kit now, however the possibility of the ISO novelty being cut is sad. Additionally, I'd prefer if the ISO novelty was grey on black rather than black on white (that is if it's still being kept).
Offline Aiwanei
    • ThocKeys.com
« Reply #65 on: Wed, 09 February 2022, 11:22:25 »
So as it stands right now, since it has to be pad printed, and pad printing adds a decent chunk to the cost, I am looking to see if we can come up with a more intricate ISO novelty design that can take advantage of this.  I really love the ISO Novelty as well, and really want it to stay, but I also don't want to price people out of the set by adding up to $10 to the cost of the kit(final pricing isn't determined for that kit so can't say the exact change to price but it would be around there) just for the Novelty ISO.
I have updated the main post with the updated kitting.
ThocKeys.com
Offline rndr
    • Keyboard Enthusiast Writeups
The novelties should have been grey on black. White on Black sort of goes against the theme of this set
Offline Aiwanei
    • ThocKeys.com
The idea is that it represents the bone white off the grim reaper skeleton, I have also added grey on black versions for most novelties to the set.
ThocKeys.com
Offline autocast
Lord that deskmat is killer
Nice update with the non-accent colored novelties and Super keys  :thumb:
Offline Zanhana
would it be possible to add size labels to the minibars (or at least list the sizes in the post) for the kits that have them? I find it difficult to know what they are by eye.
Offline ggggggg
  • schmeiß die forties durch den club
2.25u and 2.75u in the base kit, 2x3u, 2x1.75u, 2u, 1.25u, and 2x1u in the bars kit is my guess.
Offline konstantin
  • Formerly constexpr
There is also one 2u space in the base kit, but otherwise you are correct.
@Aiwanei: Consider moving the 2× 1.75u spaces to the 40s/ortho kit since only 40s boards use that size. Similarly, only ortho boards use 2× 1u and 2× 2u, so I suggest moving those keys out of spacebars and into ortho/40s. This way, 40% users will not need to buy the spacebars kit; buying just 40s and base will give them all the spacebar sizes they need. This streamlines the purchasing experience and reduces the number of unnecessary keys for everyone.
In place of those keys, I suggest putting a 6u centered stem space in the spacebars kit. One 1u space should also be kept for Alice boards even if 2× 1u is moved to ortho/40s.
Really nice kitting otherwise. I'm liking the inclusion of R3 1.75u Function in the extension kit. :)
Offline Aiwanei
    • ThocKeys.com
The issue with the DCS(and DSA also) 6u centered spacebar is that it has unusual stem placement, it is actually made for 5u Stabilizers not 6u, so the compatibility list is some vintage boards and the Razer Blackwidow.
I'll take your other suggestions under consideration for sure though.
ThocKeys.com
Offline WarlordGorguts
Re: [IC] DCS Reaper - Updated Kitting w/ Pricing - 2nd and 3rd Deskmat Reveal
« Reply #73 on: Fri, 11 February 2022, 10:44:22 »
Novelties and deskmats looks amazing. Waiting on artisan reveals)
Offline konstantin
Ah, I wasn't aware. Makes sense!
Offline Aiwanei
    • ThocKeys.com
« Reply #75 on: Sun, 13 February 2022, 19:05:56 »
Since the ISO Novelty as it stood was potentially on the cutting block, we took this opportunity to reimagine it before making the final decision and we are very happy with how it came out. We (OCM and myself) tried a few different ideas, but this is the one that worked out the best. In order to do a design on all of a DCS ISO enter key, it has to be pad printed, so this design is pad printed and UV coated but designed to fit in with the doubleshot design language on the other novelty keys.
I would love your feedback on this new design.
ThocKeys.com
Offline Zanhana
« Reply #76 on: Sun, 13 February 2022, 19:24:46 »
so good I would almost use ISO—really, excellent job with it
« Reply #77 on: Sun, 13 February 2022, 21:50:04 »
ISO novelty looks nice, but now the concern as mentioned before is the price of the novelty kit. Is it possible to cut some keys out in order to reduce the price? Because I don't see myself using all the black and white novelties or even the black and gray novelties. Just a thought.
Offline Al3417
« Reply #78 on: Sun, 13 February 2022, 22:05:14 »
Definitely love the ISO novelty, I don't even use the layout but it's such a satisfaction just looking at that Enter :p
Offline Zanhana
« Reply #79 on: Mon, 14 February 2022, 17:43:32 »
on the other hand, I love the options & flexibility in the current novelty kit and am happy to add it to my order unless it's comically exorbitantly expensive
Offline Belled
  • I like shoobs
« Reply #80 on: Mon, 14 February 2022, 19:00:55 »
Nice set, I'm in, like the relegendables
Offline gisigwilgwelk
« Reply #81 on: Mon, 14 February 2022, 20:14:03 »
Very cool keyset. Not for me personally but I'm all in on those deskmats!
Offline touch
« Reply #82 on: Tue, 15 February 2022, 08:41:42 »
Any chance for a Colevrak+ kit?
Offline Aiwanei
    • ThocKeys.com
Re: [IC] DCS Reaper - Hibi reveal and GB Date Announced.
« Reply #83 on: Mon, 21 February 2022, 13:35:29 »
I am excited to announce the group buy date for this set will be from March 12th until April 12th!
We also have a reveal of the Hibi design:
Animated Link
ThocKeys.com
Offline Bl4ck
« Reply #84 on: Mon, 21 February 2022, 15:06:54 »
Any news on Alps?
Offline 7empest
  • ༼ つ ◕ ◕ ༽つ
« Reply #85 on: Mon, 21 February 2022, 15:51:13 »
man im loving this set! nice work!
Offline Sup
« Reply #86 on: Tue, 22 February 2022, 04:23:33 »
Are the spacebar sizes in the spacebar kit both 2.5u?
current
Coming soon
Offline Mecxs
« Reply #87 on: Tue, 22 February 2022, 05:14:56 »
The kit contains:
2x 1u
1x 1.25u
2x 1.75u
1x 2u
2x 3u
All will be concave unfortunately because SP spent their annual mould budget on 10u bars I think.
Offline Aiwanei
    • ThocKeys.com
« Reply #88 on: Tue, 22 February 2022, 05:21:42 »
The kit contains:
2x 1u
1x 1.25u
2x 1.75u
1x 2u
2x 3u
They are actually going through profile by profile adding convex small bars, they have done SA already; DSA is next I believe, than DSS and DCS was last on the list, so it will be a while.
ThocKeys.com
Offline robotictomato
« Reply #89 on: Tue, 22 February 2022, 09:20:55 »
Still hoping for an Alps base kit at least! Relegendables and spacebars would be a huge plus for Alps compat as well.
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #90 on: Tue, 01 March 2022, 09:26:31 »
Base kit with Alice support and Novelties, wow, you got me!  :thumb:
Offline rndr
« Reply #91 on: Tue, 01 March 2022, 11:57:01 »
Death for my wallet for sure. Definitely copping this.
Offline Aiwanei
    • ThocKeys.com
« Reply #92 on: Tue, 01 March 2022, 14:54:01 »
Just a few updates to announce. After doing an informal poll on IG about Alps kitting, to see how much support there would be, I have decided to add in an Alps Base Kit that will be equivalent to the MX Base Kit + Numpad Kit for $135-140.  There will also be a version of the Relegendables Kit for Alps that will be ~$35.  Finally I am adding a basic NorDe kit to the set that will be ~$30.
ThocKeys.com
« Reply #93 on: Wed, 02 March 2022, 16:13:04 »
That is great! Very excited about the Alps kit and the Alps relegendables. Thank you!
Offline ggggggg
« Reply #94 on: Fri, 04 March 2022, 12:50:59 »
Just to make sure, the 10u bar takes 7u stabs, right?
Offline Aiwanei
    • ThocKeys.com
« Reply #95 on: Fri, 04 March 2022, 12:53:10 »
That is correct
ThocKeys.com
Offline Aiwanei
    • ThocKeys.com
« Reply #96 on: Tue, 08 March 2022, 13:29:57 »
With just a few days until the GB, I have posted the final kitting, and the US prices for everything (except the Mouse collab).  I am excited to share the NorDE kit, Alps Kit, Alps Relegendables Kit, and we added the RIP 1u R2 to the 40s kit after multiple requests.  We are also happy to announce that zFrontier will be the vendor for this set in China.  Please expect reveals of the keybees, artisan labs wrist rest and mouse over the next few days.
ThocKeys will be running a special promotion for the first 72 hours of the Group Buy (from the 12th through the 14th), if you buy a base kit, you will get 10% off the Deskmats.
ThocKeys.com
Offline Robert.Lussier5
« Reply #97 on: Tue, 08 March 2022, 15:01:12 »
$55 for a numpad, ooooof.
Austin R3 - Green // Austin R3 - Purple // Custom Acrylic Austin - Clear // Rekt1800 - Blue // Cypher r4 - Black // Boston - Sparkle Black // Balance - White // Glitch - Green // Shelby80 - Navy // Odin - Silver // Zoom65  Red // QK65 - Black // Link65 - Lilac
Offline Aiwanei
    • ThocKeys.com
« Reply #98 on: Tue, 08 March 2022, 15:16:01 »
That's a typo, it's 24.99. I've fixed the graphic.
« Last Edit: Tue, 08 March 2022, 15:27:57 by Aiwanei »
ThocKeys.com
Offline tuesdaygloom
  • wait.
« Reply #99 on: Tue, 08 March 2022, 22:42:06 »
The deskmats look so trippy, definitely will be picking one up, maybe a basekit too.  :thumb:
