Author Topic: KBD67 Lite or the Bakeneko65  (Read 3377 times)
Offline Armanhammer
« on: Tue, 25 January 2022, 15:02:53 »
The price doesn't matter. Curious what people's opinions are. I want to buy one. Ive had my eye on the KBD67 for awhile but I just saw the Bakeneko. I started leaning more towards the Bakeneko.
Offline Pangorin
Re: KBD67 Lite or the Bakeneko65
« Reply #1 on: Tue, 29 March 2022, 09:40:22 »
Bakeneko65 is better than the KBD67 Lite. Because the Bakeneko is aluminium, not like the KBD ones. Moreover, the mounting styles are different. The Bake65 has an oring mount, and the KBD67 Lite has a silicone mute gasket mount. I prefer the oring mount than the silicone gasket mount.
« Last Edit: Fri, 01 April 2022, 01:56:04 by Pangorin »
Finalkey Origin65A || Sundae || JCStudio SAV
Offline granola bar enthusiast
« Reply #2 on: Wed, 30 March 2022, 19:52:10 »
bakeneko is by far the better option, it even has a weight that you can choose the material for.
only spot where 67lite is better is the screw in stabs if you can call it a plus with how crappy kbdfans stabs are
« Last Edit: Wed, 04 May 2022, 21:55:22 by granola bar enthusiast »
