Author Topic: [GB] NFR-70 by Nyhxis - A 70% DIY kit - Delivered, extras available  (Read 5274 times)
Offline Xonuss
Group Buy for the NFR-70
Extras available at EuroKB
Hello there, it's me again, Xonuss, this time to announce that the group buy for the NFR-70 is finally live.
The NFR-70 is a ProMicro/Elite-C powered 70% DIY kit, essentially a 60% with F-row.
Details
  • Available over at EuroKB.com
  • The group buy runs from January 29th and ends on Tuesday March 1st at 8PM CET
  • Estimated shipping: End of July, hopefully before.
  • QMK and VIA compatible
  • Typing angle: ~5.8 degrees
  • Available in Black and White
Stay in touch over on Discord
281778-0281782-1
281780-2281784-3
Price:
DKK: 549.99 kr. incl. Danish VAT (25%)
EUR: ~€59 excl. VAT
USD: ~$66 excl. VAT
Layout Support
Apart from standard ANSI, the NFR-70 also supports the following:
  • Tsangan bottom row
  • ISO enter
  • Split left shift
  • Split right shift
  • Split backspace
281776-4
Due to the limited amount of I/O pins, regular ANSI bottom row and split right shift are unusable at the same time, as the right Alt on ANSI bottom row and the fn key on split right shift are using the same signal trace.
The Kit Includes
  • Switch plate and bottom plate, in selected color of your choice
  • PCB, colored black
  • Elite-C v4 microcontroller
  • Diodes and a reset switch
  • Standoffs and screws, colored black, and rubber bumpons.
« Last Edit: Wed, 17 August 2022, 14:51:36 by Xonuss »
Offline Xonuss
Re: [GB] NFR-70 by Nyhxis - A 70% DIY kit
« Reply #1 on: Thu, 10 February 2022, 15:54:10 »
Reserved
Offline Xonuss
« Reply #2 on: Tue, 01 March 2022, 23:25:04 »
Hello there.
Just a quick notice as I will be extending the group buy a little bit. As stated, it was supposed to end last night, but I ended up having to move house at the start of March, so right now, the most of my home is still in boxes. I expect it to be set back up by the end of the week, so I decided to just let the group buy run until then.
I apologize for this small inconvenience, however, if you haven't joined yet and wished to do so, now is your chance.
I'll be in touch.
Offline Xonuss
Re: [GB] NFR-70 by Nyhxis - A 70% DIY kit - Delivered, extras available
« Reply #3 on: Wed, 17 August 2022, 14:55:16 »
So I figured that I didn't put this here, but as all the orders have been delivered, extras are available.
